Old 12-16-2015, 05:24 PM   #15
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
Originally Posted by gaiaenviro View Post
Attachment 253935repainted bathroom with lowered toilet
Attachment 253936
Note the lowered box height.
-Bill
LOVE LOVE LOVE THIS! Can you please send instructions, pics, videos on how? So over the dangling of feet/legs while I pee... I feel like I'm two years old on the potty.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 12-16-2015, 08:15 PM   #16
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
bobmiller
I'll take a look tomorrow and let you know, I never even noticed....
-Bill
gaiaenviro is offline   Reply With Quote
Old 12-16-2015, 08:20 PM   #17
gaiaenviro's Avatar
PammieSue:
The PO had replaced the toilet with a tall thetford. I was able to lower the toilet height by dismantling the box (it's just plywood) then cutting the 's' bend at a 45 (the hole in the top of the tank is to the right rear of the toilet flange). I found a toilet flange on a 45, then re-used the rubber collar to join the two. It brought the toilet down about 2-1/2", but then I ended up changing to a low thetford and got the height down a little over 4" overall, which makes it more user friendly (particularly with 2 boys)..😀
-Bill
Old 12-16-2015, 08:22 PM   #18
gaiaenviro's Avatar
Be careful of cutting the apparent 1/2" pex line under the box, it's covering a copper gas line (yes I cut it).....
-Bill
Old 12-17-2015, 05:32 AM   #19
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by bobmiller1 View Post
I'm curious about the double sets of furnace outlets by the entrance door.
I did see that when I was visiting with Bill at the Blanco Ralley and just assumed that some PO installed a different furnace type...
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-17-2015, 08:36 AM   #20
1989 34.5' Airstream 345
Ebro , Fla Panhandle
One is there to blow forward, the other is to be set pointing upwards for the entering woman to have a Marilyn Monroe moment while entering.
Cheers Richard
tevake is offline   Reply With Quote
Old 12-17-2015, 07:25 PM   #21
gaiaenviro's Avatar
Considering the front furnace is the only one that works, it stands to reason that it has been replaced. I do prefer the skirt idea, however have yet to encounter a woman camping in a skirt....
-Bill
Old 12-18-2015, 10:06 AM   #22
-Bill
A suggestion... Don't take you rig camping in Scotland...:0
Old 12-26-2015, 08:46 PM   #23
gaiaenviro's Avatar
Name:	ImageUploadedByAirstream Forums1451187800.769500.jpg
ID:	254673after 12 hours of driving a windy 640 miles, we got set up just in time for the blizzard to start! Kids are having a blast, skiing is gonna be great.....
-Bill
Old 12-27-2015, 07:37 AM   #24
gaiaenviro's Avatar
Name:	ImageUploadedByAirstream Forums1451227021.533025.jpg
ID:	254676this morning...still coming down...
-Bill
Old 12-27-2015, 08:19 AM   #25
Oh wow!
I am split between being envious of such a festive sight and concerned about you and you nice rig! Frozen tanks and pipes, water leaks from the shell, and getting out with no traction! I hope to do some cold weather camping, but would want some drive tires with something more than circumferential grooves!
Old 12-27-2015, 08:48 AM   #26
Airstream Driver
1997 30' Excella
Images: 51
Attachment 254676this morning...still coming down...
-Bill
Hi Bill, brave man, where are you?
Let us know when you need some airdrops. Did you take your car along too or are you guys only in the Airstream?
1996 Airstream B190
AIR #13
Old 12-27-2015, 08:54 AM   #27
gaiaenviro's Avatar
We are in Ruidoso, and have an AWD rental car. We're here til wed or later as weather allows. No leaks yet (tested by TX rainstorms of 20" in a weekend), only the p trap in the shower froze and thawed out so far, there was no snow when we parked, so dry under camper if we need access. LETS GO SKI!!!!
-Bill
Old 12-28-2015, 10:34 PM   #28
gaiaenviro's Avatar
Learning quite a bit about under insulated areas of the 325. Street side rear corner, (conveniently where the pressure regulator and pump reside). All along the bottom edge of the outside walls, particularly where the pipes are, and the storage access areas that penetrate the skin/hull. Solutions to follow.....
-Bill
Almost a 325 owner JerryT94 Airstream Motorhome Forums 16 02-08-2003 02:59 AM
325 MH tire size? TRAPEZE Tires 2 12-12-2002 08:31 AM
gross combined vehicle rating for 1985 - 325 rdm Mechanics Corner - Engines, Transmission & More... 1 10-16-2002 07:01 AM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 08:19 AM
325 MH Tires? TRAPEZE Airstream Motorhome Forums 0 07-03-2002 05:08 PM
