Old 09-01-2010, 05:38 AM   #155
James Rogers's Avatar
1987 34.5' Airstream 345
Dandridge , Tennessee
Hi Brad ,
I have a 1987 Air Stream 345. Do you sell some of the parts off of you Air Stream. I need a replacement in dash blower motor and the knob for the trip odometer. Do you have a fuel Gage? I live in Dandridge, TN.
James Rogers is offline   Reply With Quote
Old 09-09-2010, 02:59 PM   #156
1975 23' Safari
Bull Shoals , Arkansas
Airstream 24
I have a 1982 24' airstream with a 454
Vin# 1GBJP37W0B3318489
A/C #1A9DGAH26CJ009796
Can any one tell me what I have?
gobuda 24
gobuda is offline   Reply With Quote
Old 09-23-2010, 10:39 PM   #157
1989 34.5' Airstream 345
Silverton , Colorado
More info needed...
gobuda 24
Uhm, first guess is a 1982 240...all kidding aside, not sure what specifics you are looking for...I can guarantee that someone on this forums will be able to answer your question(s), and do so quite well, when you can be more specific...gobuda...hmmm...originally from central Texas...?mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 02-18-2011, 07:49 PM   #158
1979 24' Airstream Excella 24
Lake Tapps , Washington
1979 24' Excella VIN
Mine is CPS3793309886.
I can barely make out some faded remnants of large numbers over the back window, so some PO must have belonged to Wally's club, right?
grandparippe is offline   Reply With Quote
Old 07-21-2011, 10:49 AM   #159
keith53's Avatar
barnehurst , Kent. UK
That Vin is close to mine CPS3793309698
24' Airstream 1979, I cant find any numbers on the chassis/under the hood, but I have sticker with some info on it , along with the vin number there is this number 1124R9V5117 not sure what that is, anyone know?
I did find a set of numbers on the chassis next to the lpg tank they read
8-299 an S in a circle then under that 14004164
if any one can make heads or tails of all this then please let me know
Thanks Keith
keith53 is offline   Reply With Quote
Old 07-21-2011, 11:37 AM   #160
keith53's Avatar
Just found the moho number under the hood it was behind a heat sink thing that someone had fitted, it's M24R9V5117. so on that sticker it was a faded M not 11 still no sign of the Vin though
Old 07-30-2011, 06:19 AM   #161
Cape Breton , Nova Scotia
Just got mine a few days ago. The VIN is M24R9V5119
PuffinPotter is offline   Reply With Quote
Old 07-30-2011, 11:02 AM   #162
keith53's Avatar
Wow! thats close to mine, I bet yours is in better shape than mine
Old 08-02-2011, 08:22 AM   #163
1986 34.5' Airstream 345
Bethlehem , Pennsylvania
1986 Classic 345
1A9CGAU34GJ 010607
Now residing in the Lehigh Valley, PA
hirsch22 is offline   Reply With Quote
Old 01-04-2012, 06:46 PM   #164
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
AS Serial Number decoded?
Up here in Alberta the Registries (equivalent to DMV) require the RV manufacturer's serial number as well as chassis manufacturer's VIN, so when I was registering my 345 I was inspired to find out what the heck it meant. I then got deeply immersed in reading this thread, and unless I completely missed it, the AS serial number riddle was not solved within the thread, although someone came quite close. Now, what I am writing here does not apply to the pre-Classic models, but only to the Classics. I believe that Airstream adopted a new VIN-style system with their introduction, and they followed standard automotive industry convention to some considerable degree. so here is my decoding, based upon the specific AS SN examples given in different posts. I do not know if my table formatting will hold up when posted, and I suspect it won't, but I am going to have a stab at it.
Digit Serial Number
Yr Model 123 4567 89 10 11 Prod#
1982 24 1A9 DGAH 26 C J 009796
1982 280 1A9 DGAM 26 C J 009819
1982 280 1A9 TDAM 20 C J 009822
1982 310 1A9 BGAR 26 D J 009823
1982 280 1A9 TDAM 22 C J 009868
1982 310 1A9 AGAR 22 C J 009926
1982 280 1A9 DDAM 28 C J 009979
1983 310 1A9 BGAR 26 D J 010034
1983 300 1A9 TDAP 25 D J 010123
1984 310 1A9 BGAR 23 E J 010215
1984 310 1A9 BGAR 22 E J 010212
1984 345 1A9 BGAU 31 E J 010329
1984 310 1A9 ADAR 29 E J 010339
1985 345 1A9 BGAU 37 F J 010465
1985 345 1A9 BGAU 37 F J 010496
1985 345 1A9 CGAU 34 G J 010607
1986 345 1A9 BGAU 3X G J 010705
1987 345 1A9 BGAU 30 H J 010777
1987 345 1A9 JGAU 38 H J 010828
1988 345 1A9 JGAU 30 J J 010991
1989 345 1A9 JGAU 37 K J 011153 This is mine
1990 250 1A9 KGAJ 23 L C 34316
1991 350 1A9 JGAV 33 M J 011281
Digit "1" = always 1, "built in USA", as with GM VIN
Digit "2" = always A, "Airstream" as with GM VIN being always G
Digit "3" = always 9, so probably vehicle type (say Class A, or Motorhome?)
Digit "4" = bed and/or bathroom arrangement T=twin;J=driver-side corner double;D=rear bath; B=rear queen;A=rear twins;
Digit "5" = fuel type D or G
Digit "6" = transmission, always A for automatic
Digit "7" = length H=24 J=25 M=28 P=30 R=31 U=34.5 V=35
Digit "8" = axle number 2 or 3, the latter being tag
Digit "9" = check digit, same position as GM
Digit "10" = year C=82 D=83 E=84 F=85 G=86 H=87 J=88 K=89 L=90 M=91
Digit "11" = assembly plant Jackson Center
I'd like help with the 4th digit, if you have letters C or K in that position please post or PM me what your bed/bath layout is. If my interpretation of any of the other layout designations is incorrect, please do the same.
The 1990 250 with 11th digit C is a problem. Either it should be J and was misread, or something else. If you have a 250 would you be so kind as to check that 11th digit and let me know what it is?
Note that the year letter, 10th digit, uses the same lettering system as GM, but your chassis may be the previous year to your MH; for instance mine is on a 1988 chassis = J, but a 1989 MH = K
Punch is offline   Reply With Quote
Old 01-05-2012, 09:35 AM   #165
Rivet Loser
Punch's Avatar
OOps.... note that
should be 1986. I'm sure that's not the only typo/error
Old 01-05-2012, 08:00 PM   #166
Rivet Loser
Punch's Avatar
Hmmm, that's embarrassing.....
I see in the general MH section that there is this link
http://www.airstream.com/files/libra...d86d618144.pdf
which is a document that answers the whole question definitively. Guess I didn't pay attention. I should get a life I guess.... but then what would I DO with it?
Old 09-25-2012, 07:06 AM   #167
While searching for some info on my 74 Argosy motorhome I came across this site: The Original Airstream E-mail List
One of the items that popped up was how to decode the Argosy motorhome serial number provided by Airstream.
Quoted from a post by Charlie Burke on July 31st 2005.
For the 10 digit serial numbers a typical breakdown of M28T8V5061 is as
follows:
M = Motorhome
28 = 28' length
T = Twin bed floor plan
8 = 1978 model year
V = Versailles, OH were the motorhome production plant was first located
along with Argosy trailers.
5061 = production sequence number.
This number was located behind the front engine access cover either
stamped directly on one of the steel posts running vertically on each
side of the radiator or on a plate riveted to the post. ( Now a days
always the roadside post )
Nothing in the records I have indicate they differentiated between
Argosy and Airstream models in the serial number they assigned.
Another possible reason for the lack of 1980 models was the move of
production from Versailles to Jackson Center.
This information might be listed on Airforums somewhere but I haven't run across it. Anyway I thought it was to good of information to not include here.
Old 09-25-2012, 07:07 AM   #168
I just noticed this is not a Sticky thread. Seems to me it should be. How about it Moderators, can we make it a Sticky thread?
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 51 03-18-2016 01:21 PM
Motorhome club name ViewRVs Airstream Motorhome Forums 9 06-09-2009 07:18 PM
Pets in the motorhome eraffety The Pet Forum 32 03-26-2007 08:04 AM
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Motorhome Mechanix Motorhome Mechanix Airstream Motorhome Forums 1 10-27-2002 12:17 PM
