Old 09-12-2015, 07:37 PM   #15
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Heres to a smooth transition!!
Mike
mayco is offline   Reply With Quote
Old 09-12-2015, 07:43 PM   #16
ericpeltier's Avatar
Superior , Colorado
Well darn. I'l take you off my list of locals! (but this might be a good thing for you....I had a list of people to contact when I was stuck)
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 11-18-2015, 11:25 PM   #17
1995 36' Classic 36
Ludington , Michigan
Progress has been slow but it finally done!
https://www.icloud.com/sharedalbum/#B08532ODWJp1FDi
Kota is offline   Reply With Quote
Old 11-19-2015, 02:55 AM   #18
mayco's Avatar
Looks great Dave. Beautiful setting.
Old 11-19-2015, 05:50 AM   #19
Great pics! Working inside is SO much better than the alternative
Old 11-19-2015, 05:54 AM   #20
Kevin245's Avatar
Nice design. Looks fantastic.
Eleanor Roosevelt
Old 11-19-2015, 06:26 AM   #21
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
That a beautiful barn. Like how they incorporated the preexisting structure. Is there a opening inside between the buildings. Also interesting that they erected the wood supports then poured the pad.
Very nice.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-19-2015, 08:11 AM   #22
1995 36' Classic 36
Motorhome Home
Very nice.
An 8' wide opening into the unheated section of the existing and a 42" door into the heated shop.
It was a challenge to get my design implemented and added considerably to the cost. Local code and setbacks from the river limited the option of a separate building. Other locations on the property would interfered with a view of a beautiful valley.
It also incorporates my dad's wood shed that previously occupied the site. I think the feature looks great. I picked green to diminish the size among the spruce trees.
Old 11-19-2015, 06:44 PM   #23
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I really like the way you engineered the addition. I think there is nothing worse than an addition that looks like an addition. You know, when you drive by and say "oh look they put a vinyl sided addition on that brick house. "
Is that an outdoor wood boiler? What kind of heat exchanger are you using? Will it supply hot water to the house as well?
Can't wait to see the work on the Airstream.
Gregsch is offline   Reply With Quote
Old 11-19-2015, 07:33 PM   #24
1995 36' Classic 36
It will heat the shop, house, hot water, and hot tub.
https://hawkenenergy.com/build/trim/...rim=silverhawk
Water to air heat unit in the shop, radiant floors in the house.
Old 11-20-2015, 04:55 AM   #25
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Dave
Looking forward to coming down next year to see the new digs and have a chat.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 11-20-2015, 05:01 AM   #26
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
All I can say is, I have a case of 'shop envy'! Looks absolutely stunning.
martin300662 is offline   Reply With Quote
Old 11-20-2015, 07:04 AM   #27
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Great design Dave, turns a nice little shop into a really nice big one. ( will both of your classics fit in there?).
Like the wood stacking space too, will that wall stay open for access to the wood? Does the wood fired boiler fit under that eve too?
Was that your dad on the tractor , very helpfull.
Cheers Richard
tevake is offline   Reply With Quote
Old 11-20-2015, 12:27 PM   #28
1995 36' Classic 36
I've got basically 56x24 feet of area with ceiling over 12 feet. Two would fit fine. I'll leave the 94 in storage in Boulder until spring. I hope to replace the headliner, flooring, wall covering, and graphics on the outside in time to put it up for sale before summer.
Had too much fun with that Kubota SLV. Moved about 200 yards of fill.
I do have a nice camp site with water and 50 amp. I'll put in a small septic system next spring.
Home Sweet Home deauxrite Upholstery, Blinds, Walls & Interior Finishes 7 11-19-2017 10:23 AM
Home away from home :: 2003 Airstream Safari fman88 Airstream Registry Discussions 0 09-14-2011 05:54 PM
Our Home Away From Home Bobz Hog 1968 Overlander 34 09-05-2009 11:24 PM
A home away from home drjudy Member Introductions 8 10-31-2007 04:58 PM
