Old 10-01-2012, 06:34 PM   #1
RichardT's Avatar
Motorhome fuel problems
I was bringing home a 1988 345 today and it had been sitting a year but the PO said fuel stabilizer was added, gauge said 1/2 tank. Started and ran perfect got 4 miles and started to miss and run out of power on first hill. Fortunately gas station I was headed to was right there. Stopped and added 20 gallons and it started right up and ran smooth (flat ground) 60MPH for 10 miles till hill and popped sputtered but made it. Flat ground full speed ahead. Left it at a safe place dark and will go back for it tommorrow.
I am thinking fuel filter.
Can anyone tell me where the filters are on the stock 88 325 and if possible part numbers?
I just need to get it home where it will get the full service and love it needs and deserves.
Thanks in advance for your answers.
RichardT
RichardT is offline   Reply With Quote
Old 10-01-2012, 07:03 PM   #2
1974 Argosy 20
Kooskia , Idaho
I don't know about the 88, but the 83, on a P30 had the fuel filter on the curb side frame rail, about half way forward. It was a simple inline 3/8 filter. Mine was always plugging up and I always carried two spares with me. I would remove it and could not even blow through it, cut it open and it would look just fine. I think it was water saturated filter material which caused the issue.
Go to NAPA or any parts place and get an inline 3/8 filter.
Old 10-01-2012, 07:04 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Look just in front of the fuel tank, the filter should be before the electric fuel pump. You may also have an intermittent electric fuel pump problem. It just a metal inline filter.
Carter P4070 In-Line Electric Fuel Pump - Compare prices, reviews, user opinions - Shopper.com
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-01-2012, 07:19 PM   #4
1994 30' Excella
Mississauga , Ontario
If it's been sitting that long there could be water in the tank from condensation. I assume it has a vented cap.
Add a cup of methyl hydrate and that should help.
Al
Al and Jean
TAC ON-3
Old 10-01-2012, 08:15 PM   #5
RichardT's Avatar
All good info. With the ethanol in fuel today water is always a problem.
I will be getting it in the morning. Wish me luck...
Old 10-01-2012, 09:06 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Check electrical, could be hill incline changing a ground point.
Good advice above about checking filter for crap, if it doesn't have any, it might be in the tank, could have a prefilter screen clogged. Others have had collapsing hose and cracked or split, search line with flashlight from tank to motor.(pushing and prodding could show up old hose.
I still think mine was intermittent electrical, rather than the old fuel or 454's fuel vapor lock problem of old. I checked my tank and it was absolutely clean.
Old 10-01-2012, 11:56 PM   #7
2005 19' Safari
GLENDALE , AZ
We had a 454 in our old 1978 Chevy crew cab pickup, and there was a fuel filter actually in the carburetor where the fuel line entered the front of the carb body. I'd try replacing all of the inline fuel filters and the one in the front of carburetor (if there is one).
Just to clarify, did the engine run OK at idle and slow speeds, and just have problems when under load at higher rpm? Or, was it running rough at all speeds (and perhaps worse at higher rpm)?
Without witnessing your engine running, it is difficult to say; but if runs rough at all speeds, one or both of the carburetor floats could be sticking/stuck, or one or both of the metering jets could be clogged. If either of these is the root cause, the carburetor may need to be rebuilt.
Old 10-02-2012, 07:23 AM   #8
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Just wanted to back up PeterH on this one. Check your fuel filters. On my 86 345 there are two: one on the passenger side frame rail forward of the door (metal canister style as Peter pointed out) and another in the carb itself.
Additionally, ensure that the electric boost pump just forward of the tank is working. Loss of power on hills is usually related to a failure of the pump (if you still have power on flats). Loss of power on hills or under load on flats is usually filters.
Had a long long drive to Florida once because of a bad inline filter....changed it in a parking lot near Atlanta and it was like a new motorhome.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-02-2012, 04:33 PM   #9
RichardT's Avatar
So I went and got it this morning, i picked up a filter and some fuel drier and octane booster. When I was changing the filter (wasn't bad) I noticed the power wire to the fuel pump by the tank was not connected. I hooked it up and it ran perfect with no issues. I made it home
Thanks for all the tips...
Super nice 325
Old 10-02-2012, 05:41 PM   #10
Aww, now that was just too easy
Congrats on solving the problem and picking up a nice Airstream!
Old 10-02-2012, 07:11 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
Super nice 325
Now its time to pay up, you owe us pictures, lots of pictures..
And you already discovered the most favorite game we all like to play: Whilst you are trying to fix something, you will always, without fail find something else that needs to be fixed...
1996 Airstream B190
AIR #13
Old 10-08-2012, 05:04 AM   #12
Brighton , sussex
Glad you fixed it. I had a no start problem just after I used mine for it's first trip.
I have a 310 but no electric fuel pump. Is this normal.
I found some good You Tube videos on the carb and just cleaned it out and checked the jets were in place. I also changed the carb filter on the inlet line and replaced the old rubber lines. I have one plastic filter on the frame rail near at the mid point and a mechanical pump on the engine. Check the pump seal and lines for leaks. My rubber fuel line at the tank had rubbed thru where it goes through a hole in the chassis. I will be protecting it with plastic conduit or a metal line. The chassis hole could do with a some rubber around it's circumference to help here or just fix the line securely.
Would an electric pump help my 310??? Do I keep the mechanical one as well??
Loving Life, Chicks, Cars and Mummas Grits baby
montreal is offline   Reply With Quote
Old 10-08-2012, 05:08 AM   #13
You definitely need an electric fuel pump inline. On our 310 the electric pump is mounted along the frame rail approximately where the steps are. And yes, you need your mechanical fuel pump also.
Old 10-08-2012, 11:10 AM   #14
Del,
I sent you an email with a PDF of the official factory cure for vapor lock...
