Old 08-25-2015, 07:30 PM   #1
1982 31' Airstream 310
Henniker , New Hampshire
Motor swap '82 310
I have been slow to post anything but after getting my 310 home from it's misadventures in IN, I pulled the motor. Click image for larger version
Name:	ImageUploadedByAirstream Forums1440548955.694894.jpg
ID:	246351Click image for larger version
Name:	ImageUploadedByAirstream Forums1440548995.881044.jpg
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 08-25-2015, 07:34 PM   #2
After removing the hood, grill, radiator, bumper and everything else from the front, I could actually see the motor! It was a tight fit coming out. Click image for larger version
Name:	ImageUploadedByAirstream Forums1440549228.582845.jpg
ID:	246359Click image for larger version
Name:	ImageUploadedByAirstream Forums1440549283.253094.jpg
Old 08-25-2015, 07:35 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Is it too early to know what failed yet?
martin300662 is offline   Reply With Quote
Old 08-25-2015, 07:36 PM   #4
Unfortunately I didn't get any pics on the way out. The photos from Brad were a great guide for my project!Click image for larger version
Name:	ImageUploadedByAirstream Forums1440549379.406566.jpg
Old 08-25-2015, 07:42 PM   #5
Moved the motor into the garage and onto a motor stand. Found lots of shrapnel when I pulled the pan. Click image for larger version
Name:	ImageUploadedByAirstream Forums1440549510.787469.jpg
I could see the #5 piston was shattered. Pulled the head and found a valve snapped off and driven through both the top of the piston and the head.
Old 08-25-2015, 07:45 PM   #6
The head is junk. The piston is in a dozen pieces. The rod is bent, the pushrod is bent and the wrist pin has badly scored the cylinder wall. Not much left to work with. Click image for larger version
Name:	ImageUploadedByAirstream Forums1440549907.817983.jpg
Name:	ImageUploadedByAirstream Forums1440549930.219018.jpg
Old 08-25-2015, 07:46 PM   #7
New 502 crate motor on order. I'll try to update when it goes in.
Old 08-25-2015, 08:06 PM   #8
1982 28' Airstream 280
Redwood City , California
Motor swap 82 310
Yup certainly looks like a giant paper weight. Please let us know the specs of the 502. I'm also curious as to the mileage on the engine and what condition the timing chain and gears are in.
I have an '82 with 140k on it. I wish I had the shop replace the timing chain and gears when they had the radiator out for re-core.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 08-25-2015, 08:21 PM   #9
58,000 miles on the 454. Not sure why the valve failed. I believe the PO had the heads off before I purchased it.
Old 08-25-2015, 09:01 PM   #10
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
looks like you had to unbolt the exhaust manifolds to get it out? Were they stock or did you have headers and whats your plans for that?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-25-2015, 10:05 PM   #11
1987 34.5' Airstream 345
northern IL , Illinois
Your second picture reminds me of the Board Game Operation.
Hans 34.5 is offline   Reply With Quote
Old 08-25-2015, 10:28 PM   #12
Did you go with the 502 HO.
502 HO Big Block Crate Engine | Chevrolet
If not does your 502 come with a roller cam.
Old 08-25-2015, 10:47 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Glad to see the coach made it home safe and sound.
Funky LED headlamps. How are they in comparison to the original sealed beam halogens?
Goodluck with the 502. Just wondering are you updating the fuel system or sticking with the carb setup? Which reminds me of the post I posted on your original thread.....This would be a great time to replace fuel lines.....power steering lines.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-26-2015, 05:23 AM   #14
1995 36' Classic 36
Ludington , Michigan
I think a little JB weld on that piston and head and you'll be good to go!
I visited Timeless when they had just gotten a classic back from the shop that installed a 502. Very nice clean retrofit. Fit well and looked great. Might be a source for a little info.
Kota is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
1983 Airstream 310 Motor Home 51,200 miles Ex Condition eBay Watch Airstreams on eBay 0 12-27-2010 11:10 PM
I Need a new Motor 4 my 310 JMChrystie Mechanics Corner - Engines, Transmission & More... 5 09-21-2003 02:39 PM
