Old 12-06-2015, 06:43 PM   #85
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
1991 35' Airstream 350
Images: 51
Originally Posted by chiefair View Post
...... I guess I will declare the projects done until spring.
1982 310 motorhome 454
Henniker New Hampshire
Almost done, you still need to change your signature to 502 from 454
Congrats on a job well done !
1991 350LE
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 12-07-2015, 09:45 AM   #86
1982 31' Airstream 310
Henniker , New Hampshire
Originally Posted by Gregsch View Post
Please elaborate on the A/F gauge. I looked at the website. Can you really get live data mounted permanently on the dash for $199 ? does it fit where the clock rests now?
The A/F ratio gauge was well worth the purchase price. It does provide live data with both a digital readout of your air/fuel ratio and a green-yellow-red LED bar graph readout. It also has a graphical view which provides a constantly shifting line graph of the reading, in real time. It can be connected to a data logger also, a luxury I did not have.
While I was tuning my carb, I had the gauge wire-tied to my handheld vacuum gauge so I could watch them together. After every adjustment I made, I would take a road test and a video of the gauges so I could compare each change with previous adjustments and judge their effects. After I had the carb dialed in, I did mount the gauge in the dash where the clock was.
The gauge is not really set up for dash mounting, it has no provision to secure it from the back. It is the proper size for the hole in the instrument cluster. I bought this mount from Amazon: Amazon.com: Blox Racing (BXGA-00106) 52mm Small Base Adjustable Gauge Holder: Automotive. I took the mount apart and used the band that is supposed to clamp around the gauge. I pushed the gauge through the dash and put the band on from the back of the dash to clamp the gauge in place. It worked fine.
In addition to displaying A/F ratio, the gauge displays voltage. My Teleflex volt meter reads 16V when the ignition is on, I can now use the new gauge for an accurate digital voltage readout. You cycle between the A/F and voltage displays using the touch screen on the front of the gauge. PLX Devices PLX Devices | Electronics & Automotive also makes modules for temperature, pressure, vacuum & boost. You can use the single gauge to monitor multiple sensors and scroll the displays to show each parameter. The gauge can receive data from up to 16 sensors. I plan to add temperature sensors for my engine oil and transmission oil temps soon.
It is a great way to add multiple gauges without cluttering up the instrument panel.
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 12-07-2015, 12:54 PM   #87
You're right!
Old 12-07-2015, 09:26 PM   #88
Awesome!
I will be installing my Innovate system this week I hope!
Old 12-08-2015, 06:39 AM   #89
You will like it, a great tool to see actual engine conditions.
Old 12-08-2015, 07:41 AM   #90
...I removed my non-functioning clock and installed my air/fuel ratio gauge in it's place.
Clock? What clock?!
Old 12-08-2015, 10:05 AM   #91
Wait... A Teleflex clock? Gotta have one of those! ROFL!
Old 12-08-2015, 10:10 AM   #92
Unfortunately (or forunately depending on how you look at it!) my dash only has 10 2" openings and they're all filled
Actually I was surprised to hear that any of these rigs had dash clocks.
Old 12-08-2015, 10:57 AM   #93
I am hoping that the Fuel/Air gauge will help me set the idle and low RPM mixture so I can pass this darn CA smog first time!
What does yours read at idle and say 2000rpm with no load?
Old 12-08-2015, 01:53 PM   #94
Why don't you just move someplace more civilized like Kentucky?
Old 12-08-2015, 02:42 PM   #95
I could... But its 80f here today and I am enjoying lunch looking out over the Pacific Ocean...
What's it like in Kentucky today?
It's all a tradeoff!
Old 12-08-2015, 02:56 PM   #96
55 degrees, sunshine. Very pleasant day. I get to look out over the woods and lake
I'll take the state with 4.14 million people over one with 38.8 million people!
Old 12-08-2015, 03:23 PM   #97
I hear ya... We are all good!
4m people and 20m guns... Liking that!
Old 12-08-2015, 03:35 PM   #98
I think 20s a little light...
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
1983 Airstream 310 Motor Home 51,200 miles Ex Condition eBay Watch Airstreams on eBay 0 12-27-2010 11:10 PM
I Need a new Motor 4 my 310 JMChrystie Mechanics Corner - Engines, Transmission & More... 5 09-21-2003 02:39 PM
