Old 09-07-2015, 06:03 AM   #43
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by mayco View Post
Beautiful!!! Is that the first 502 anybody has heard of being installed in a classic? Wish you the best of luck through the rest of the install!!
Mike
Check this full monty with a 502 on a Classic moho. I don't know who he is or if he's on the forums site. Well dressed with a few toys.
There's a link to a fourth section as well at the end of the final movie.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-07-2015, 06:30 PM   #44
1982 31' Airstream 310
Henniker , New Hampshire
Wow. I thought I was in deep!
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 09-08-2015, 05:51 PM   #45
Does anyone have photos of the inner fenders on the front of their motorhome? I assume they should be closed in to improve airflow through the radiator and over the motor. My left side has an aluminum panel with a cutout to access the master cylinder from the wheel well. The panel blocks about 2/3 of the left wheel well, the rear 1/3 is open. The right side is completely open with no sign of mounting brackets that would indicate there used to be a panel there. I will probably build something to close that area off, it would be great to get some pictures to see what it should look like.
Old 09-08-2015, 06:28 PM   #46
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Passenger side, made out of thin aluminum. I will take that panel off in a week from Saturday and could give you the dimensions. It appears to be made from trailer underbelly material
ID:	247674   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-08-2015, 06:29 PM   #47
Airstream Driver
1997 30' Excella
Images: 51
drivers side made out of steel with master cyl access
ID:	247677   Click image for larger version
1996 Airstream B190
AIR #13
Old 09-09-2015, 07:21 AM   #48
Thanks for the photos. My drivers side panel looks the same. I will have to build a passengers side panel. I can see the bolts along the top edge of yours, but I don't see any signs of a bracket to bolt to on mine. Guess I will be starting from scratch. If you have it off and can get measurements, I would appreciate it.
Old 09-10-2015, 04:01 PM   #49
1982 28' Airstream 280
Redwood City , California
Another photo to help you out Chiefair...
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-11-2015, 10:49 AM   #50
Thanks for the photo. Interesting how different these two panels are. I found this on the web: http://truckroadservice.com/barth_at...2015983041.pdf. Just have to decide how fancy I am going to get.
Old 09-11-2015, 11:09 AM   #51
I like this panel.
Old 09-13-2015, 05:13 PM   #52
Finally started the 502 for the first time today! The excitement was short lived. The fuel line adapter I bought for the Holley has a bad flare and leaks fuel continually. Back to the speed shop on Monday for a replacement.
Old 09-15-2015, 09:06 AM   #53
Sounds like your startup went better than my Argosy 454 startup did. After about 5 minutes of running a couple of my spark plug cables caught on fire and and melted!
Melted plug wire video at post #53
Old 09-15-2015, 05:07 PM   #54
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Brad; not being mechanically I take it that the spark plug wires are not supposed to catch on fire?
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 09-15-2015, 05:35 PM   #55
I am now waiting for the arrival of my 3rd fuel line adaptor. First two leaked on the flare. Still plenty of opportunity for a fire here!
Old 09-15-2015, 05:41 PM   #56
I built a cardboard template of the GM inner fender I found on the Barth website. It was nice but the frame mounting points were not going to be fun to get to. I made a new template based on the GM one but attached to the body like the photos that folks here provided. I'm pretty happy with the way it worked out.
Name:   ImageUploadedByAirstream Forums1442360437.587729.jpg
Name:   ImageUploadedByAirstream Forums1442360479.671749.jpg
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
1983 Airstream 310 Motor Home 51,200 miles Ex Condition eBay Watch Airstreams on eBay 0 12-27-2010 10:10 PM
I Need a new Motor 4 my 310 JMChrystie Mechanics Corner - Engines, Transmission & More... 5 09-21-2003 01:39 PM
