Old 09-01-2015, 10:15 AM   #29
1982 31' Airstream 310
Henniker , New Hampshire
Progress has been slow this week. Stripped parts from the 454 and got most of them on the 502. Quadrajet does not fit. Waiting for parts to finish swapping over. I'm hoping everything comes soon so I can get the motor in this weekend. Click image for larger version
Name:	ImageUploadedByAirstream Forums1441120449.702811.jpg
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 09-01-2015, 01:23 PM   #30
Originally Posted by chiefair View Post
Progress has been slow this week. Stripped parts from the 454 and got most of them on the 502. Quadrajet does not fit. Waiting for parts to finish swapping over. I'm hoping everything comes soon so I can get the motor in this weekend. Attachment 246984
That's interesting about the quadrajet. What is the fitment issue? You might look into using an Edelbrock carburetor. I plan on running an Edelbrock 1406 600 SCFM caruburetor. With a 502 you'd likely need a slightly larger one!
Old 09-02-2015, 01:54 PM   #31
The Quadrajet bolt pattern is too narrow for the GM supplied intake. GM recommends a Holley 850 for this motor, so that's what I got. Should be painful at the pumps! (not that it wasn't before). I would love to have gone with fuel injection but this project has run up against financial reality.
Keith
Old 09-02-2015, 02:31 PM   #32
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Despite all the hassle and financial set backs you went through, I share your excitement about having a new Motor. It will be well worth it !!
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-02-2015, 03:55 PM   #33
1995 36' Classic 36
Ludington , Michigan
Keith
A properly tuned carb will be pretty close an EFI system. Especially some of the aftermarket stuff. Maybe even better.
Kota is offline   Reply With Quote
Old 09-02-2015, 05:02 PM   #34
1987 34.5' Airstream 345
northern IL , Illinois
I think that new engine could be better on fuel you won't have to smash the right foot to the floor to get the MO moving. And going down the road it should sound Bad Azz.
Hans 34.5 is offline   Reply With Quote
Old 09-02-2015, 05:46 PM   #35
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
There is some truth to your reasoning, as I remember in the early 90's my girlfriends parents at the time were looking to buy her a car, a Ford Taurus with 4 cylinder. Just out of curiosity I remember asking the salesman what the difference was in MPG between the 2.3L four and the 3.8 six was. The four got 1mpg better in the city but the six got 3 better mpg on the highway.
However apples to oranges, an 850 double pumper on a 502 punching a 8.5' x 10.6' 15,000 lb hole in the atmosphere is going to cost you a lot more than the 650 double pumper 340 in my 69 Dart GTS convertible that I use to own. Yes it sounded Bad Azz too.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-05-2015, 08:47 PM   #36
Preparing to install the 502.
Name:	ImageUploadedByAirstream Forums1441503828.275609.jpg
Tight fit!
Name:	ImageUploadedByAirstream Forums1441503932.737226.jpg
Name:	ImageUploadedByAirstream Forums1441504025.062154.jpg
Name:	ImageUploadedByAirstream Forums1441503981.690802.jpg
Old 09-05-2015, 08:54 PM   #37
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Can't wait to hear how it runs; maybe born of out necessity but that is a serious performance improvement.
martin300662 is offline   Reply With Quote
Old 09-05-2015, 11:47 PM   #38
Mission , Texas
Really dumb question ...
why not a diesel?
7.3/7.4 or 8.2?
nrgtrakr is offline   Reply With Quote
Old 09-06-2015, 12:50 AM   #39
I think it would be a lot more work. And you need to change the rear end gear ratio and the list goes on. You would need to keep it a long time for the diesel swap to pay off. I can see doing it but would I do it I hope not.
Old 09-06-2015, 04:18 AM   #40
mayco's Avatar
champaign , Illinois
Beautiful!!! Is that the first 502 anybody has heard of being installed in a classic? Wish you the best of luck through the rest of the install!!
Mike
mayco is offline   Reply With Quote
Old 09-06-2015, 06:10 AM   #41
why not a diesel?
7.3/7.4 or 8.2?
I looked into a diesel replacement. The motors were really expensive, even with high mileage used motors. It would have dramatically increased the time required for the swap to custom fit everything. I would need to add a second fuel tank or switch the generator over to propane. As Hans said, I would have probably needed to change the rear end gearing to get into the correct RPM range for a diesel. I felt it was too much work, too expensive and would keep me away from enjoying camping trips for too long to justify the gains in fuel economy and torque. This was a big enough project with a direct bolt in replacement!
Old 09-06-2015, 07:37 AM   #42
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Edelbrock 650
I think the Quadrajet is not going to give you the fuel needed as it is.
Your going from what was it 280 hp to 450. You may know all this.
Keep a eye on the plug color. It's going to be a fun MO to drive.
I'm running an Edelbrock 650 cfm on a 327 cui and it makes my pickup truck scream. It might be a tab bit to much but for the cam, heads, and intake combo it works well. The new aluminum heads greatly reduced the weight from the cast iron heads. IHMO, I'd stick with the stock exhaust manifolds. Less chance of warping and having to replace manifold exhaust gaskets.
tsunami is offline   Reply With Quote
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
1983 Airstream 310 Motor Home 51,200 miles Ex Condition eBay Watch Airstreams on eBay 0 12-27-2010 11:10 PM
I Need a new Motor 4 my 310 JMChrystie Mechanics Corner - Engines, Transmission & More... 5 09-21-2003 02:39 PM
