Old 03-06-2007, 10:04 AM   #1
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Motor Home Transmission
I have been experiencing for several years a transmission problem and I am contemplating if I should get it repaired. The problem is when it is cold 30 degrees F or less the transmission when cold ( motorhome sat overnight) will slip until the engine runs for a couple of minutes. During the summer or warm weather there are no problems with slippage and you can put it in gear and take off as soon as you start the engine after not having been run all night. I was told that the seals in the transmission are probably at fault and having shrunk. They swell to the proper size when warm. Has anyone else experienced this problem and what did you do to correct it.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 03-06-2007, 12:44 PM   #2
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I was having similar problems with my Explorer transmission and figured what did I have to lose, so I put in a can of Sea Foam conditioner and it works fine now. Sea Foam claims they soften seals and such. What the heck, cheaper than a tranny rebuild and if it doesn't work, then you still get the rebuild.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-06-2007, 01:03 PM   #3
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Exclamation tranny
Hello
have you had the trans serviced? new fluids and filters.. If it keeps slipping it will burn up the tranny real fast. and most likly it will happen when you are miles from home.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 03-06-2007, 01:24 PM   #4
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
In some ways, you are lucky - the transmission is telling you it's worn out and in the not to far future is going to fail. As with engines, a factory rebuilt replacement is, in my opinion, the only way to go. Automatic transmissions are fairly complicated and have several critical clearances and set points. As a complete unit, simple to replace. Good luck!
Pop Rivet is offline   Reply With Quote
Old 03-06-2007, 02:13 PM   #5
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Gunner,
I had a full size Buick that did the same thing. I thought I had plenty of time to get the trans overhauled, but it burned up on the interstate one day with an outside temperature of below freezing.
When we got our 345, the trans was leaking fairly badly on the ground. There is a transmission shop here in Indy that I have had good luck with, so I had them overhaul our trans. That has been 15 months ago and 9000 miles. Works great.
Good luck, Rob
Robfike is offline   Reply With Quote
Old 03-06-2007, 03:40 PM   #6
Gunter
gunner's Avatar
Greenville , Ohio
Had the fluid and filter changed, dropped the pan to do it did not have it flushed. Did not find any metal shavings or anything else in the pan other than fluid. When I purchased the unit in Alabama over Thanksgiving over five years ago I had no problems with the transmission because it was warm when I started and drove straight through to Ohio. Even then when it sat overnight during the winter it would slip. Mechanics have told me that basically the seals will swell and not to worry about it but like everyone else I don't want to get stuck on the road.
Gunter
Old 03-06-2007, 03:42 PM   #7
Gunter
gunner's Avatar
Greenville , Ohio
Rob can you provide an estimate cost for having the transmission pulled and rebuilt? What kind of warranty did you receive with the rebuild.
Gunter
Old 03-06-2007, 05:44 PM   #8
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hi gunner what you described is front pump leaking inside , when it goes 1st and reverse are lost. 1 giant netrual. been there done that on my chevy pickup.
Old 03-07-2007, 07:42 AM   #9
Robfike's Avatar
Speedway , Indiana
Gunner,
I believe the whole job was right at $1200. Their warranty is 12 months or 12,000 miles. This is the third transmission I have had them do for me. All have been great.
Rob
Old 03-07-2007, 10:51 AM   #10
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Gunner
To me it sounds as a torque converter drain back. The reason it take for few seconds before it starts moving is that your torque converter refils. Normaly the problem is the front bushing or the hub on the torque converter is worn out. Is your trans a hydro 400 3 speed? If your seals and o rings get hard they will also act the same way. It is a common problem for Ford.Chev. does not normaly do this, unless it is over 10 years old. The best way is to take the motorhome to a trans shop and leave it overnight so they can check it out cold.
Regards from Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 03-08-2007, 03:21 PM   #11
Gunter
gunner's Avatar
Greenville , Ohio
Thanks for everyone's input. I am having a automotive garage giving me an estimate of either rebuilding my transmission or replacing it with a rebuilt one from Jasper.
Gunter
Old 03-08-2007, 03:26 PM   #12
Pop Rivet's Avatar
Altoona , Georgia
Jasper - JASPER - JASPER!!
Good luck with whatever you decide - It's possible I could be slightly opinionated. But I doubt it.
Old 03-08-2007, 04:16 PM   #13
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
What's the possibility of putting in a four speed or an overdrive transmission? I am still in the market to lower my RPM and increase speed.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-08-2007, 04:46 PM   #14
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Kent's right. Now's the time to explore changing up to a newer 4 spd tranny. If you're going to go to a Jasper replacement why not go to an early 4spd without the computer stuff? I'm assuming the next version of the TH400 didn't need the computer and still shifted off vaccum.
So will the crowd now please educate us on what we would need to do... I'm sure the steering column would have to change for the 4spd unless a remote shifter leaver was used.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
What If I Replace The Transmission? Chaplain Kent Mechanics Corner - Engines, Transmission & More... 54 01-09-2007 12:14 PM
transmission heating aeriqua Tow Vehicles 15 08-03-2006 12:28 AM
Allison auto transmission O/D lockout davidz71 Tow Vehicles 0 01-20-2003 10:28 AM
Transmission questions jcanavera On The Road... 6 08-13-2002 09:36 AM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
