Old 02-27-2016, 10:05 AM   #15
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Interesting. I had the CAC rebuilt and pressure checked when the motor was rebuilt.
SebasSF is offline   Reply With Quote
Old 02-29-2016, 06:38 PM   #16
1995 36' Classic 36
Ludington , Michigan
More power Scotty
Did they recore it or just clean and test it?
Kota is offline   Reply With Quote
Old 03-05-2016, 08:04 AM   #17
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
I too received a boost output of 30-35psi with the banks system. I did not see any noticeable increase in MPG, so I reviewed the PO's maintenance logs. They did an upgrade to 300hp shortly after getting it, but everything is stock. That's when I started reviewing my notes and issues she's been having (lots of smoke on acceleration, and diesel fuel residue on the toad). Their 300hp solution was to replace the fuel plate and adjust the p7100 star wheel. So really, just fuel. After undoing the star wheel adjustment, and removing the turbo silencer the best I got was 15MPG no toad, no wind, level ground. Usually I get 13.5-14mpg and with toad 12-13.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-20-2016, 11:50 AM   #18
KB6YAF's Avatar
Olympia , Washington
Mo Power
My local diesel mechanic suggested that I have all the injectors rebuilt along with the injector pump to get more power. I think it was around $200 per injector and $450 for the pump. There is a more power now even though the turbo boost indicator is off the scale!! I do have to watch the EGT temps. While the motor home was in the shop, I did have a Gear Vendors overdrive unit installed. That was money well spent.
Russell Decker
Olympia, WA
1983 Airstream 310 TD
KB6YAF is offline   Reply With Quote
Old 06-23-2016, 12:21 AM   #19
SebasSF's Avatar
I have been tinkering with mine. I adjusted the arm on the turbo bypass actuator shorter and it's running much better now. Still only gets up to 25 on the boost gauge but has more power and runs cooler. Traveling on flatland the turbo is running at 10 psi boost. Drove up to Oregon last weekend and got around 11 mpg...was hoping for a bit better.
Old 06-23-2016, 10:37 PM   #20
1995 36' Classic 36
I see about 30 lbs on hard acceleration. About 5 lbs better than before I patched up the CAC. They do rot out. Mostly thermal expansion cracks. They pressure test them regularly on commercial trucks. It's also running cleaner. I did back off the star wheel a couple teeth. Sacrificed a little power for not having to watch the EGT while Ann is driving.
Old 06-23-2016, 11:33 PM   #21
1991 25' Excella
Stanfield , Oregon
One place to look that gets missed a lot is the exhaust manifold. They crack on the bottom side where you dont look and lower the exhaust energy to the turbo.
SpletKay06 is offline   Reply With Quote
Lil' Miss Scotty :: 1964 Serro Scotty Front Kitchen InsideOut Airstream Registry Discussions 1 06-21-2012 10:26 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Vintage Mallard 13 foot camper travel trailer serro scotty shasta airstream eBay Watch Airstreams on eBay 0 11-05-2011 07:30 PM
Vintage Mallard 13 foot camper travel trailer serro scotty shasta airstream eBay Watch Airstreams on eBay 0 10-14-2011 07:00 PM
We need more power Scotty! thecatsandi On The Road... 10 08-09-2008 08:54 AM
