Old 11-06-2006, 04:18 PM   #1
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
monitor board
The darn thing just quit - nothing works on the board - still has power to it -
any sugestions?
Pop Rivet is offline   Reply With Quote
Old 11-06-2006, 04:28 PM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
any sugestions?
Fuse on board, open cap, broken trace, bad ground. Start poking around.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-06-2006, 06:55 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What he said. These things are notorious for bad grounds. Hook a test light up to a good ground, and touch the other end to the ground lug on the panel. If the light lights, you have a bad ground.
Old 11-08-2006, 05:47 AM   #4
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Monitor panel
Hi Overlander63; The most effective and least time consuming troubleshooting of open circuits in DC is as you said, is use a test light.
However, there can be a hitch in some instances. Test light does not require much amperage to indicate a closed circuit, but in places as the distribution panel where amperage demand is high, partial open can drive you to having too many beers. The best way is as you said, check for continuity.
To check for open negative circuit place the test light clip on the positive battery terminal, and test each negative terminal. To check the positive wires reverse the process. This will identify the polarity of the tested wire, as well as any open circuits. The hitch may occur in case of corroded or weak connection where required amperage delivery across that connection is insufficient. The weak connection may provide enough amperage to light the test light, but you still may have a problem with high demand circuits. This is why it is easier to ensure that all connections on power supply side are solid and clean, on the battery and the distribution panel. Most of the time it is dirty or corroded terminals, rather than broken wire inside the skins that is a problem. That is the most prevalent scenario in the marine application. If the terminals are good and clean, only then we need to break out Ohmmeter to check the Resistance in the wire. Load tests on wires usually result in fire especially in unprotected circuits.
Problems in high amperage demand circuits lays most of times in bad connections. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 11-08-2006, 06:04 AM   #5
hendrie42's Avatar
1968 20' Globetrotter
Albuquerque , New Mexico
it sounds like the ground might be the problem good luck -----hendrie 42
hendrie42 is offline   Reply With Quote
Old 07-03-2007, 08:01 AM   #6
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Hi boatdoc, here is my scenario; resistance on tank wires-but fresh-grey-black all read "E".
But the battery indicator is working fine...
Tank gauges quite working about 1 month ago.
Does this mean the board is toast?
Where to find replacement for 89 vintage system?
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
