Old 09-05-2007, 06:33 AM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Question Moisture / condensation treatment?
Our '84 310 has the freshwater tank and water pump located under one of the twin beds in the back. Our old 280 had it under the couch. Both had condensation moisture and dampness, which promotes mildew and smells bad. We have removed everything, thoroughly disinfected, and sealed all surfaces with shellac. Now we are determined to prevent reoccurance, and any suggestions would be welcomed.
Jamie
jking is offline   Reply With Quote
Old 09-05-2007, 07:02 AM   #2
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Ventilation
This dilemma is difficult to overcome, a balancing act for sure.
Air flow prevents moisture buildup. However, you can even get the desert to sweat in the morning with one of those plastic sheets on the ground.
Freezing air will cause damage.
Warm air will rob the air conditioned space of comfort and cause condensation on the water tanks. The change of temperature causes it.
Keep the area clean, keep the unit at one temperature (impossible to do really unless stored in a temperature controlled garage) and keep the air moving.
Good luck.
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 11-12-2007, 03:09 PM   #3
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Controlling Mold
Jamie
Generally, good ventilation is the general answer to controlling condensation, and minimizing the opportunity for mold. Always, use the exhaust fans in the shower, toilet and kitchen. And crack a window open to let air get into the trailer. If its cold outside use the heater to keep the inside temperature from getting too cold.
If its hot outside run the AC unit, since it will dehumidify the air inside the trailer. I suggest to still use the exhaust fan in the shower, when showering, and in the kitchen, when cooking (still cracking a window), and running the AC unit.
However, if you are talking about what to do in a stored Airstream, say in a place like Florida in the summer, the answer is dehumdification. The air inside a stored trailer will be dehumidified by running the trailer's air conditioner. Using a chemical desiccant may work, but personally I like the idea of using the AC unit, coupled with timely inspections. There is a forum that has a great posting detailing using a chemical dessiccant.
Remember, in the summer when its hot outside, even the smallest opening or crack, will allow moisture to enter the trailer. In fact, it is forced in since the vapor pressure is higher outside, where its hot, versus inside, where its cool. That's why most houses have vapor barriers. You will notice that with houses vapor barriers are always installed on the warm side of the exterior wall. (In cold climates thats on the inside of the exterior wall's insulation, and in warm climates its on the outside of the exterior wall's insulation.)
If the shellac was used on the inside of the exterior wall it will not be nearly as effective as a good use of caulk, and tight joints on the outside.
The obvious complication for us Airstream owners is that we move our trailers from climate to climate. However, good ventilation remains the answer, but whether you use the heater, or AC unit depends more on where you happen to be parked.
SRW is offline   Reply With Quote
Old 11-23-2007, 12:37 PM   #4
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
Jamie,
We live in our 345 full time and have mostly overcome the situation you are talking about. I'd suggest:
1. ventilate the space (we removed all the doors to this area and/or replaced with perforated panels),
2. empty most of the water from the tank. (the water is a massive heat sink (it will cause the space under the bed to be colder and water to condense around the tank as warm day time air hits it), and
3. run a small fan or dehumidier (we use one of these in the winter months (West Marine: Air Dryer Dehumidifier Product Display)
it's low energy and seems to help a lot.
good luck,
nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Heat exchanger for moisture control? SilvrSausage Roof Vents, Skylights & Fans 3 10-13-2007 01:00 PM
new floor treatment crispyboy Repairing/Replacing Floor &/or Frame 2 05-21-2007 10:39 AM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
flooring treatment install ALANSD Floor Finishes 27 07-09-2004 04:24 PM
