Old 05-10-2011, 04:35 PM   #1
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Moho generater door
I'm trying to repair my generator door. I know there are two horizontal spring loaded pins that hold the bottom of the door and I assume act as a hinge to open the door. Mine are gone and I'm trying to fabricate new ones.
My door has been held on by four screws and wing nuts with are tacky and a pain in the rear to access the generator.
My question is what is the bottom of the door supposed to look like? Mine has about a 1/2" flange bent down and a similar flange bent down on the edge of the compartment floor. It looks like when the two flanges hit it would keep the door from opening very far. Maybe you open the door a bit and reach in to release the pins and remove the door for access? I can build the hinge pins so that the bottom of the door sticks out a bit to allow the door to open farther but I don't know exactly how it is supposed to be.
It almost looks like the bottom of my door is bent done a bit compared to the curve of the coach. If it was curved up a little more the flange might swing up above the floor of the compartment when opened.
I've attached a couple of pics. can anyone tell me how it's supposed to work or maybe post a picture or two?
Thanks, Dan
ID:	129569   Click image for larger version
Smartstream is online now   Reply With Quote
Old 05-10-2011, 05:55 PM   #2
I made up some tempory hinges to see what it looks like. If I match the bottom edge of the door the way it looks like it should. The bent down flange does clear the compartment floor and the door opens nicely. The problem is the door is now 3/4" to 1" too tall. Have I got the wrong door? I can't imagine they made these in different sizes. Am I missing something here?
I'm open to ideas.
Thanks, Dan
ID:	129573   Click image for larger version
Old 05-10-2011, 06:31 PM   #3
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Well I don't know if i will be any help since I'm an Argosy . But my generator door doesn't have hinges the flange on the door just sits inside the body between the body and another flange it also locks at the top. If you want I can take some pics.
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 05-10-2011, 06:46 PM   #4
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
hello S. S.
I would start the fit at the top
secure the top well and then work down to the bottom forming and shaping the door.
I think a hinge at the bottom. swing down door.
with a Positive latch of some form at the Top would give you good access.
John H. is offline   Reply With Quote
Old 05-10-2011, 07:00 PM   #5
Gypsy Jo's Avatar
1977 28' Argosy 28
Generator door
Looks like I am missing the solid piece that covers the screened area.
For what it's worth here are pics. The bottom of the door just sits inside the 2 L bracket looking things and then the lock is at the top .
Jo
ID:	129575   Click image for larger version
Gypsy Jo
Old 05-10-2011, 08:22 PM   #6
Thanks Gypsy Jo and John. It's interesting the little differences in these units when they all look pretty much the same. I like the idea of the whole door flange interlocking with the compartment floor. Mine is supposed to be held with 1/4" pins that are spring loaded into holes in the frame. Tin Crumpet had their door come off on the roadway. I'm working on a positive lock for the pins. The pic is the lock that I got from Inland RV. It fits the hole in the door which is now covered with a reflector. I'm a little concerned because the lock is heavier than the whole door.
I found this old pic of a creative solution for a door that decided to go it's own way.
My door is actually two pieces riveted together in the middle. I guess I can shorten it at that joint. It just drives me nuts when stuff like this doesn't fit.
Thanks again, Dan
ID:	129592   Click image for larger version
Old 05-11-2011, 10:45 AM   #7
Silverton , Colorado
My generator door has a segmented piano hinge, front-side of the unit, and the door is one piece. I have to lift up a little on the latch side to get it to close, and the latch is horizontal when closed. My 'flanges' inside the door are not flared...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-11-2011, 12:14 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That's strange, Dan. My lower door is screwed on and I think it's factory. Ya got me!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-11-2011, 05:33 PM   #9
Mine is two piece too, but different to what I have seen here...
My upper is a flimsy piece of pressed Aluminum, and the lower is bolted, I think 3 placed per side... Top bolts are between the rub strips, and you can see the hole for the mid one cos its missing..
Old 05-11-2011, 05:48 PM   #10
Mike Leary's Avatar
Images: 11
What's with the Buck Rogers vents? I've never seen them before, wonder what good they did/do?
Old 05-11-2011, 07:49 PM   #11
LOL, Are they not Factory?
I know they let the smoke from my oil leak out good!
Old 05-11-2011, 08:23 PM   #12
I have to admit I'm surprised at how many variations there are for mounting this simple door. One of the things that concerns me is how flexible the door is. With the original hinge that mine had on the bottom the door is so flexible that it would be very easy for it to flex enough that a latch at the top would simply pull past the latch tab. I think that is why some added the latches on the sides.
The piano hinge with the bottom secured and only the top half folding down solves that problem. To do that I would have to split my door and modify the inner baffle. By the way nobody else seems to have the inner baffle that is on my door.
ScrapIrony seems to have the best set up with a hinge on the leading edge and a single latch at the rear. Because of the curve the door doesn't flex in that direction and as long as the latch can support the door vertically this should solve all the problems and keep the whole thing pretty simple. Tomorrow I'm going shopping for a piano hinge.
Pretty interesting scoops there Keyair.
Thanks guys, Dan
Old 05-11-2011, 08:46 PM   #13
Mike Leary's Avatar
Images: 11
Ahh, "scoops" rather than vents, I didn't think of that. Maybe we need to put arrows denoting fore/aft in our close-ups.
Old 05-11-2011, 09:30 PM   #14
LOL, for the pedantic Classic owners....
They are forward facing... so scoops..
Now I am all worried that the extra drag is why my MPG is low...
Maybe NACA Scoops are better?
Dometic freezer door springs SafariGeorge Refrigerators 5 07-01-2011 09:44 AM
Door lock issues carlvs Doors & Locks 4 05-09-2011 07:57 AM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
RM 2410 and 2510 Freezer Door Widths pbearsailor Refrigerators 4 01-07-2011 07:16 PM
