Old 04-29-2011, 07:52 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Mo/ho hidden discovery!
Cleaning out the roadside upper compartments today, I found this piece of electronics that I'd never seen. I think it's the doorbell (which never worked), but the wiring schematic in my manual shows no colored wire to the what-ever-it-is. It's on the middle inside of the dual compartments. Like I care about a doorbell, most people bang on the windows and ask, "Is this a Airstream", or, "how much did you pay for it?" I wonder which terminal that loose wire goes to? (tried the obvious one). I like that term, "do not oil".
ID:	128632   Click image for larger version
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-29-2011, 08:08 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
That looks like the remnants of a doorbell alright, you are just missing some parts. There should be a piece that moves in the coil and a flat bar at each end, one larger than the other. The flat bars are the "bells", they work like the bars on a xylophone, just lots smaller. They fit vertically in the clips on either side of the fuse in your first photo. The coil fist horizontally between the chimes. Moving between the two chimes gives it the ding-dong effect. Or usually in an Airstream, the tink-tink effect.
Vaughan
Old 04-29-2011, 08:32 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
Maybe bench test it . . .
Old 04-29-2011, 08:41 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
Without the flat bars, the chimes, there is nothing to make any sound.
Vaughan
Old 04-29-2011, 09:21 PM   #5
richinny's Avatar
2011 34' Classic
test it for power and if you get power, replace it from a hardware store. you can use a buzzer or chime.
Ricky
Old 04-30-2011, 03:41 PM   #6
I replaced mine with one identical to my original for like $27 at Lowe's. Now my dogs go nuts every time somebody rings a doorbell on TV!
8rmesse is offline   Reply With Quote
Old 04-30-2011, 04:24 PM   #7
Mike Leary's Avatar
Images: 11
That sounds like some kind of Zen saying. However, I found these today, each bar has a different tone, I think the rod has something to do with activating both tones?
Old 04-30-2011, 04:57 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Exactly!
After a couple of days saying to myself, "I know I have a photo of mine while I had the sofa out somewhere!", I finally found it.
You can see that the rod fits in the coil supported by a hair spring. The rod is moved by the current when the coil is energized and strikes the bars. You can also see the plastic mountings that fit in the holes in the bars and snap into the plastic standoffs to mount the bars.
The photo helps a lot. Much clear than "The sound of the rod striking nothing," Zen stuff.
Vaughan
Old 04-30-2011, 05:07 PM   #9
Mike Leary's Avatar
Images: 11
Well done, Vaughan! Damn, I remember seeing that spring (somewhere)
Old 05-28-2011, 06:22 AM   #10
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Very helpful. Miraculously, my door bell still works, I can see the pins going up and down, but I've lost the chime bars so no noise! Now I've seen your picture I should be able to put it back to fully working order. How thick are those chime bars and is there any chance you could set out the exact measurements for me?
thanks
Nick
Boom Sounds is offline   Reply With Quote
Old 05-28-2011, 10:59 AM   #11
Mike Leary's Avatar
Images: 11
thanks
Nick
I'm not going to repair mine, the body is too trashed. I'll see if I can find the chimes (they are tuned). You'd be welcome to them, send me a pm.
Old 10-01-2012, 12:10 PM   #12
Aluminated
1987 29' Airstream 290
El Cajon , California
Images: 14
I tried mine the other day and to my surprize it sounded nice! This also makes my dog go crazy.....
ericjan2 is offline   Reply With Quote
Old 10-02-2012, 06:12 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
My Airstream has a door chime??????
I have a feeling this is going to be the way it is
"Like I care about a doorbell, most people bang on the windows and ask, "Is this a Airstream", or, "how much did you pay for it?"
Old 10-02-2012, 10:00 PM   #14
Mine...
Best receiver: Curt, Drawtite, or Hidden Pacerized Hitches, Couplers & Balls 7 03-21-2011 08:13 PM
Hail Discovery! DanB Off Topic Forum 5 03-09-2011 05:01 PM
Trailer size for a 2003 Land Rover Discovery runyandm Tow Vehicles 5 10-30-2003 09:09 PM
