04-29-2011, 07:52 PM
1984 31' Airstream310
Ajo
Mo/ho hidden discovery!
Cleaning out the roadside upper compartments today, I found this piece of electronics that I'd never seen. I think it's the doorbell (which never worked), but the wiring schematic in my manual shows no colored wire to the what-ever-it-is. It's on the middle inside of the dual compartments. Like I care about a doorbell, most people bang on the windows and ask, "Is this a Airstream", or, "how much did you pay for it?" I wonder which terminal that loose wire goes to? (tried the obvious one). I like that term, "do not oil".
04-29-2011, 08:08 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
That looks like the remnants of a doorbell alright, you are just missing some parts. There should be a piece that moves in the coil and a flat bar at each end, one larger than the other. The flat bars are the "bells", they work like the bars on a xylophone, just lots smaller. They fit vertically in the clips on either side of the fuse in your first photo. The coil fist horizontally between the chimes. Moving between the two chimes gives it the ding-dong effect. Or usually in an Airstream, the tink-tink effect.
Vaughan
04-29-2011, 08:32 PM
Sioux Falls
, South Dakota
Maybe bench test it . . .
04-29-2011, 08:41 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Without the flat bars, the chimes, there is nothing to make any sound.
Vaughan
04-29-2011, 09:21 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
test it for power and if you get power, replace it from a hardware store. you can use a buzzer or chime.
Ricky
04-30-2011, 03:41 PM
I replaced mine with one identical to my original for like $27 at Lowe's. Now my dogs go nuts every time somebody rings a doorbell on TV!
04-30-2011, 04:24 PM
Ajo
That sounds like some kind of Zen saying. However, I found these today, each bar has a different tone, I think the rod has something to do with activating both tones?
04-30-2011, 04:57 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Exactly!
After a couple of days saying to myself, "I know I have a photo of mine while I had the sofa out somewhere!", I finally found it.
You can see that the rod fits in the coil supported by a hair spring. The rod is moved by the current when the coil is energized and strikes the bars. You can also see the plastic mountings that fit in the holes in the bars and snap into the plastic standoffs to mount the bars.
The photo helps a lot. Much clear than "The sound of the rod striking nothing," Zen stuff.
Vaughan
04-30-2011, 05:07 PM
Ajo
Well done, Vaughan! Damn, I remember seeing that spring (somewhere)
05-28-2011, 06:22 AM
1991 25' Airstream 250
Oxford
, Oxfordshire
Very helpful. Miraculously, my door bell still works, I can see the pins going up and down, but I've lost the chime bars so no noise! Now I've seen your picture I should be able to put it back to fully working order. How thick are those chime bars and is there any chance you could set out the exact measurements for me?
thanks
Nick
05-28-2011, 10:59 AM
Ajo
thanks
Nick
I'm not going to repair mine, the body is too trashed. I'll see if I can find the chimes (they are tuned). You'd be welcome to them, send me a pm.
10-01-2012, 12:10 PM
Aluminated
1977 31' Sovereign
1987 29' Airstream 290
Norman
, Oklahoma
I tried mine the other day and to my surprize it sounded nice! This also makes my dog go crazy.....
10-02-2012, 06:12 PM
Dazed and Confused
Hillsburgh
, Ontario
My Airstream has a door chime??????
I have a feeling this is going to be the way it is
"Like I care about a doorbell, most people bang on the windows and ask, "Is this a Airstream", or, "how much did you pay for it?"
10-02-2012, 10:00 PM
Foothill Ranch
Mine...
10-02-2012, 10:37 PM
moderator
2016 27' International
Wilton
Thats funny. Thanks for posting.
10-03-2012, 10:53 AM
1989 34.5' Airstream 345
Silverton
For whom the bell tolls...
Ya know, a cheap alternative would be to put a small sign next to the doorbell button that reads something like (PUSH HERE AND SAY 'DING-DONG')...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
10-03-2012, 11:03 AM
Foothill Ranch
Or a sign saying...
"The bell left because there was already a Ding-Dong in residence."
10-03-2012, 12:27 PM
1982 34' Limited
Brunswick
, Georgia
My door bell is under the front pano windows... doesn't look like it has worked for years. I just let the butler answer the door! Haha
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
