Old 03-06-2006, 04:15 PM   #1
canton , tx
missing latches/locks
Still moving along (ok slowly moving along) with Wanda's (79 Excella mh) restoration...one of the latches/ locks on the outside compartment is missing...sure could use some help finding a replacement...thanks for your assistance...joe...
rvlover is offline   Reply With Quote
Old 03-06-2006, 05:51 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Inland RV has them
Andy's got them out there. The pirate PO who had mine stripped all the small compartment door latches out of mine. They're pricey; I think Andy told me they're like $55 each.
- Jim
JimGolden is offline   Reply With Quote
Old 03-06-2006, 06:01 PM   #3
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Are you talking about the small lock tumblers with the latch finger that locks the roll-out bins?
Robfike is offline   Reply With Quote
Old 03-06-2006, 06:31 PM   #4
canton , tx
My 79 doesn't have rollouts. Each outside bin has a door that is hinged at the bottom. The door has 2 latches at the top. Each latch has a lock that twists to open the latch when it is unlocked with a key. Wish I could post a picture but, haven't worked out the details of this porcedure yet...thanks for the help...joe...
Old 03-06-2006, 07:13 PM   #5
JimGolden's Avatar
Chicago Lock
I'm not sure of the correct terminology, but I always called them "baggage doors". Basically the small doors on the outside of the coach that allow access to the batteries, the rear trunk, the side trunks, for like your tire irons, hoses, chords, stuff like that.
The ones on my '77 are made by Chicago Lock Company, part number 4260.
Andy's got them as the complete assembly, but they're not cheap. Still, at least they're available. Good luck with it.
- Jim
Old 03-06-2006, 09:26 PM   #6
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Look at Your local RV store SOBs use the same locks as Airstreams and they are not as costly as some poeple charge for them in the Airstream World.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 03-07-2006, 01:39 AM   #7
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
We got ours from Mr.Lock at a fair price...
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 03-07-2006, 04:53 AM   #8
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I believe what you're referring to are called 'cam locks'. They're quite common and you could probably find them at your local Ace Hardware.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-07-2006, 08:15 AM   #9
JimGolden's Avatar
Are you guys sure on that? I took the lock cover over to a Fleetwood dealer and he had a million locks in the back and none of them fit. He told me "...the rest of the world uses this kind...Airstream uses a different one."
I'd be happy to find some cheaper route. I will check Mr. Lock.
Thanks!
- Jim
Old 03-07-2006, 08:27 AM   #10
Pschoerrn's Avatar
1971 29' Ambassador
I am shure with the Mr.Lock Chicago Locks 4260, but you´ll get a cylinder that looks totally different to the old ones, as it has a "round" key. The housing and the T-Handle looked the same like the old ones on our 1971 Ambassador!
Not shure which part number the Cam-locks have... Does anyone have a service manual to look it up or anything written on the inside/backside of the lock??
Bjoern
Do you want a picture of my new installed lock??
Edit 2: What you need to keep from the old ones is the latch that locks the door as the old one is for the depth of the C-Channel... Better post a pic... I´ll be back in a minute...
Björn H. Adam
unknown irish
davetheairstream
Old 03-07-2006, 08:51 AM   #11
Pschoerrn's Avatar
1971 29' Ambassador
Ok here are some pics of our new Chicago Locks 4260 replacing the Compartment door locks on our 1971 Ambassador... Hope you can see, that what I mean with the "old latch"... It´s a little rusty, I know...
Name:	Chicago Lock 4260 005.jpg
ID:	19065   Click image for larger version
Name:	Chicago Lock 4260 010.jpg
Name:	Chicago Lock 4260 011.jpg
Björn H. Adam
unknown irish
davetheairstream
Old 03-07-2006, 11:22 AM   #12
canton , tx
Thanks for all the help. My latches do not look like the picture. There is a rectangle hole in my cargo doors about 3 or 4" by 2 or 3" with a smaller half circle cutout on the top of the rectangle hole. Not sure if trailers have the same latches as motorhomes. My Excella is a motorhome. joe
Old 03-07-2006, 02:11 PM   #13
Pschoerrn's Avatar
1971 29' Ambassador
Does it look like this one??
Probably Andi is the best source for a lock like this... Anyone else a clue??
Björn H. Adam
unknown irish
davetheairstream
Old 03-07-2006, 05:38 PM   #14
JimGolden's Avatar
Bjoern,
Thank you for the photos. This will help me. Your trailer looks like mine. The only piece that I have is the outer housing. I am missing the entire inner part, including the latch. I will get with Mr. Lock.
Thanks!
- Jim
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Missing Electrical Outlets gklott 2001 - 2005 Classic 2 04-21-2004 01:03 PM
Aluminum underbelly missing Joe C 2002 - 2005 International 10 11-10-2002 09:41 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
