02-18-2018, 05:16 AM
#21
Richmond
, Kentucky
Originally Posted by cinerama3
There are numerous electrical issues.
This switch bank isn't, original, is it?
Only the ceiling sw. works.
Under sink wiring:
A small fire? And plenty of hackery.
Good pictures of the typical Airstream build quality. Scary isn't it......
1975 24' Argosy Motor Home
02-18-2018, 05:18 AM
#22
Richmond
, Kentucky
Cracked threshold.
Couldn't find the part from the usual suspects.
Maybe I'm using the wrong search term?
Some have replaced the plastic insert by fabricating a nice wood entry way. Dan (Smartstream) is one that comes to mind that made a beautiful wood replacement.
02-18-2018, 06:45 AM
#23
Mike
1992 35' Airstream 350
Indianapolis
, Indiana
Thanks, Brad, I'll look for that.
02-18-2018, 08:57 AM
#24
1982 31' Airstream 310
champaign
I did mine to match the flooring.
02-18-2018, 03:59 PM
#25
2007 22' International CCD
Corona
Looks superb. Every bit of it lines up, and looks slick. Nicely done!!
What is the floor material?
02-18-2018, 04:55 PM
#26
Mike
Indianapolis
, Indiana
Outstanding!
02-18-2018, 05:14 PM
#27
champaign
Thanks fellas. It is a rigid PVC click lock plank flooring in teak n holly by Nauticflor. I installed it about 1.5 to 2 yrs ago I think. We like it so far. It cleans very easy and really no maintenance. Pricey but considering there is so little sq ft to cover it wasn't that bad. It's pretty big in the marine/boating world because it is water proof.
02-18-2018, 05:19 PM
#28
Corona
It really has a yacht vibe to it. My dad was captain on a yacht that was all teak. This floor looks so realistic. Very nice job.
02-18-2018, 05:27 PM
#29
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Show Off ! LMAO !!!! Regards, Bob
02-18-2018, 05:31 PM
#30
north blenheim
, New York
Mike....It appears That you may have "Indexed" your screws..... Is your camera lense dirty or is it possible that you might be a little OCD like me ???
02-18-2018, 07:36 PM
#31
Mike
Indianapolis
, Indiana
Had to be a dirty camera.
Or were you talking to Mayco?
02-18-2018, 07:40 PM
#32
Dazed and Confused
Hillsburgh
, Ontario
Wasn't Mike, it was Lynn who did the fine detailed touches; indexed the screws and applied blue Loctite with a very fine Japanese caligraphy brush.
Cheers
Sidekick Tony
02-18-2018, 07:45 PM
#33
Mike
Indianapolis
, Indiana
I clearly don't understand how the Kwikee steps controller works.
Went to move the MH out of the shop but could not get the steps to retract, with ANY combination of attempts.
Switch on, switch off. Engine on, shift to neutral, etc.
So I disconnected them from the motor and tied them up.
Then I backed her out and the motor started working again.
So what HAS to happen for the steps to work?
Any help appreciated!
02-18-2018, 07:48 PM
#34
1984 31' Airstream310
Honokaa
, Hawaii
Sorry if this is obvious, but you did have the door shut, right?
02-18-2018, 08:01 PM
#35
Mike
Indianapolis
, Indiana
Yes I did.
From the Kwikee manual:
With the new IMGL and Control Unit logic:
WHEN THE OVERRIDE SWITCH IS ‘ON’,
THE STEP IS LOCKED IN THE EXTENDED POSITION.
IF THE IGNITION IS TURNED ‘ON’
(WHETHER THE
OVERRIDE SWITCH
IS ‘ON’ OR ‘OFF)
THE STEP WILL FOLLOW THE DOOR.
Door Open = Step Extended
Door Closed = Step Retracted
I swear on a stack of bibles I tried it with both ign on and engine started.
Bewildering.
02-19-2018, 05:10 AM
#36
champaign
OF COURSE I indexed the screws, just like every electrical cover plate in the house! (hell I can't remember).
02-19-2018, 10:29 AM
#37
Corona
Ok, now I feel better about my OCD-related issue on properly indexing screws, and making absolutely sure all the switches on a 3-way circuit line up in the same position when the light is off.
I thought it was just me!
02-19-2018, 03:39 PM
#38
Mike
Indianapolis
, Indiana
What is current practice for proper indexing of screws these days?
Horizontal or vertical?
(OT: Hey Mr. Rum, my brother is a ham! W9TC.
73s!)
02-19-2018, 05:44 PM
#39
north blenheim
, New York
It depends on whether they are Phillips or slotted......Regards, Bob
02-19-2018, 06:54 PM
#40
1982 28' Airstream 280
Port Angeles
If you an Allen or Torx head it won't matter.
Cheers, Dan
~ Margaret Thatcher ~
