Rear hatch latch.
This solenoid does work, with the electronic deadbolt feature.
But the linkage to the lock is missing.
Anyone have a pic of what's supposed to be there?
Remembering that I am a complete nube re: RVs, clue me in here.
City water hose on the right.
What are the 2 inlets on the left for?
One line goes inside under the bath sink, the other does the same but loops and goes back out the floor.
Could one be a black tank flush?
Hillsburgh
, Ontario
Originally Posted by bkahler
It appears I was wrong about the screen although for some reason I remember getting a small section of screen and a rubber gasket when I ordered some 10 years ago. However at Vintage Trailer Supply all I could find online were the vent pipe gaskets. The gaskets provide a tight seal around the ABS vent pipe.
However Out of Doors Mart does show a screen in the top of the vent which is what I remember seeing previously. Attachment 305035
My 310 had door screen aluminum mesh under the vent covers, but unsure if stock or added by PO.
As for aluminum covers to cap the vent stacks, I seem to recall Steve (Keyair) made up some very sweet covers for the covers around his stacks.
Cheers
Sidekick Tony
wauw the nautikflor looks awesume!! do you still know the price of one box and how many square meter is one box? we have a 350le so i am wondering how many we must buy..
I would like to get one of those nifty Derale transmission pans.
The only tag I see says Hydramatic 13TK P 6
So what model do I have?
Thanks!
Check out this GM transmission oil pan ID website. Figure out which transmission you have and order the correct Derale pan.
If your transmission has OD then I'm betting it's the 4L80e.
1975 24' Argosy Motor Home
While you are under there, take a close look at the clearance between the rear of the pan and the transmission crossmember. I had to notch my crossmember to fit the deep pan.
