07-26-2016, 05:23 PM
1992 35' Airstream 350
Ennis
MH Classic slider side window insert
I am searching for the upper and lower plastic channel slider inserts for the side windows. Does anyone know of a sourse?
07-26-2016, 05:32 PM
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Maybe Inland RV can help. Regards, Bob
07-29-2016, 04:16 PM
Richmond
, Kentucky
I spent a lot of time searching for those plastic channels several years ago with zero luck.
If you get lucky and find some please lets us know!
08-26-2016, 09:33 PM
1987 34.5' Airstream 345
Menomonee Falls
, Wisconsin
Gray sliders
Hey,
I got an85 325. I got a shop, at this moment making me a prototype of those gray inserts. I got to see if they ll work, before I talk it up to much. Anybody interested? If you take a close look at those inserts, you ll see they were nibbled off on the bottom edge. I think airstream adapted them for their windows. The weak point is that lip that goes over the aluminum. Most of mine are cracked there. When i did the fuzz on the windows, I broke them future trying to get the windows out of the channels. Price right now is 14.00 per channel, if I buy 500 of them each coach takes at least 30 of them 2 per window. 345 and370s would take more. If y'all are interested, I may get a better price if I order 1000 of them we would need at least 33 owners to buy a full set. I may be able to get a lot better price with a big quantity order. Anyone interested?
08-27-2016, 05:37 AM
Richmond
, Kentucky
These tracks are used in every Classic motorhome made. However I'm not sure where you got the number 30 for each coach. A 310 should only use 14 of them which would be about $200 plus shipping. Considering how important these are to keeping the windows functioning properly I would think $200 would be a small price to pay for having a complete set on hand.
I need to look closer at my Argosy windows to see if they use these same tracks. If they do I'm in for a few.
08-27-2016, 05:41 AM
Ennis
Classic slider side window inserts
I am interested. I have a 1992 350LE Classic. I will get a photo of how they are made and send it.
Before this one we had a 1981 Excella Diesel Classic and did get some from Inland RV many years ago but have not been lucky to find any now. I tried to remove the ones in the 1981 coach but they are now brittle and was not lucky to get one in one piece.
Van
TVFD Chief in Texas
08-27-2016, 06:04 AM
1986 25' Sovereign
1975 20' Argosy 20
janesville
, Iowa
Post a photo someone please. it is dark out so I can't go look at lzzy, our 75 argosy, but I have an idea. I think I can make a plastic injection mold.
....rich
08-27-2016, 06:15 AM
Richmond
, Kentucky
Rich, I'll go look at my 74 Argosy and I'll also look at Peanut which is a 77 Argosy to see if the tracks are used.
From what I remember of the gray tracks is I had thought they were an extruded piece of plastic. I suppose it's possible to make a mold and have them fabricated that way.
08-27-2016, 06:40 PM
1991 35' Airstream 350
Mentor
, Ohio
Window Insert
I am interested in these as well. I would probably buy two sets.
Dave
08-27-2016, 09:06 PM
Menomonee Falls
, Wisconsin
Window tracks
Hey all,
Your right, that was polish adding my 325 has 8 windows that need those channels two per window is 16 . Sorry about that. The guy making these will basically make them on a proffessional grade router. I've seen their work very good, tight tolerances. I'm impressed with what I've seen . I gave him one of my channels. I should have the prototypes next week. If they work, I'll get back to y'all and we will map out a plan I think these will be better than the originals. I don't think those channels were made specifically for that window. That little nibbled off edge was supposed to be a reinforcing for the weight of the frame. I think that these channels sag in the middle and opening up a window pushes on thee edge of the channel. When they were new, they could handle the stress. ,but as age and uv took its toll, I think that is why they break off that lip. My channels will have the bottom side of the channel a solid plant in the aluminum rail that way the rails will have strength when opening the window. That's the plan anyway,. I'll keep you informed. Dj
08-28-2016, 08:42 AM
north blenheim
, New York
Great news on those grey plastic window slide channels....thanks to the efforts that you are making it makes it possible for those of us that want to do a restoration correctly possible.....If you are successful, put me down for a complete set for my 370LE. I had a bear of a time with them when I did the job on my 325LE. Regards, Bob
08-28-2016, 09:57 AM
1985 32.5' Airstream 325
Calgary
, Alberta
I will take a set as well.
08-28-2016, 02:31 PM
1986 34.5' Airstream 345
Alliance
, Ohio
Well count me in as well. I was putting off doing the windows and this take away the last excuse. I'll get a count on my 345 and let you know when the time is right.
08-28-2016, 07:09 PM
1986 25' Sovereign
1975 20' Argosy 20
janesville
, Iowa
I have looked at Izzy and cannot see plastic channels on the windows. all I see is fuzzy schlegels which I got from Andy. I got a full package of window seals and gaskets from him.... Inland RV ... not all installed yet. But... if they can be extruded ... extrusion dies are quicker to make and cheaper. We injection mold, but do not extrude, which is why I suggested injection molding.
Izzy's (1975) problems seem to grow greater in number every time I look, so window seals, etc are now low in priority.
