Old 08-28-2016, 08:43 PM   #15
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Sign me up for a set for my 370, plus another 8 pieces for my 325 (which is not a typical 325). Thanks for your efforts!
Charly
streamquest is offline   Reply With Quote
Old 08-29-2016, 05:56 PM   #16
I just checked my 74 Argosy and the slider windows don't appear to use the plastic track insert. I then checked Peanut which is a 77 Argosy and didn't see the plastic slider either. Plus I have a slider from a 78 Argosy that doesn't have the plastic slider. So it would appear that all of the Argosy line did not use the plastic slider insert.
However, I don't think Airstream changed the window frames and I wouldn't be surprised if the seal and slider components from the later models could be retrofitted into the Argosies.
I have a windows from an 86 345 that I can use to compare the frame construction to my Argosy. I'll try and do a compare in the next week or so. It would be nice to know there are alternatives for repairing these windows.
Old 08-30-2016, 07:00 AM   #17
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I don't think my 250 has the plastic slide. It has the fuzzy schegel channel, but I think Out of Doors mart sold a better replacement product that Inland (IMHO). They also have the weep hole covers.
Out of interest, and not wanted to go off topic, but has anyone ever successfully refurbished the window handle/lock with the pillar system. Some of mine are only juts functional
Boom Sounds is offline   Reply With Quote
Old 08-31-2016, 12:46 PM   #18
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
I am very interested in a set for my 1984 310 - thanks for taking this on! I don't think A/S was thinking 30+ years down the line when they were constructing these shiny silver tubes...
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 08-31-2016, 04:33 PM   #19
Alumatube's Avatar
New Holland , Ohio
Meaning for all the windows in the 310, BTW...
Old 09-02-2016, 06:26 AM   #20
richstrike's Avatar
1986 25' Sovereign
1975 20' Argosy 20
janesville , Iowa
Extrusions? ?
Since Izzy (1975 Argosy) does not have the channels, I have not seen them, but if they can be extruded that might be the best way to go. Extrusion dies are relatively cheap to make and the cost of the parts produced would be low. We injection mold, but do not extrude, but if you Classic owners can find a sympathetic extruder it might be a good route.
richstrike is offline   Reply With Quote
Old 12-01-2018, 06:47 PM   #21
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
Help, need window tracks!
We are speaking of these window tracks, correct? We have need! Can someone please tell me where they can be ordered and for how much? We own a 1988 325 Classic Moho. Thank you in advance for your help.
3wd67rg is offline   Reply With Quote
Old 12-01-2018, 06:53 PM   #22
3wd67rg's Avatar
Originally Posted by davejay View Post
Hey all,
Your right, that was polish adding my 325 has 8 windows that need those channels two per window is 16 . Sorry about that. The guy making these will basically make them on a proffessional grade router. I've seen their work very good, tight tolerances. I'm impressed with what I've seen . I gave him one of my channels. I should have the prototypes next week. If they work, I'll get back to y'all and we will map out a plan I think these will be better than the originals. I don't think those channels were made specifically for that window. That little nibbled off edge was supposed to be a reinforcing for the weight of the frame. I think that these channels sag in the middle and opening up a window pushes on thee edge of the channel. When they were new, they could handle the stress. ,but as age and uv took its toll, I think that is why they break off that lip. My channels will have the bottom side of the channel a solid plant in the aluminum rail that way the rails will have strength when opening the window. That's the plan anyway,. I'll keep you informed. Dj
Hey Davejay, what happened with this?
Old 12-03-2018, 12:18 PM   #23
Magnet18's Avatar
Churubusco , Indiana
I think this unfortunately fizzled, davejay, is this project still alive?
My thoughts are it might be recreatable with some lengths of delrin and a tablesaw, haven't given it much thought yet, will hopefully be a spring project for me
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 12-03-2018, 12:36 PM   #24
You might be onto something with the table saw idea. Nothing says it has to be the exact shape, it just has to perform the same function. I have a strip of the channel laying on my desk. I'll have to take some time to work up a profile to get a better idea of everything the channel is supposed to be doing.
Old 12-03-2018, 12:57 PM   #25
Magnet18's Avatar
I also thought, delrin/plastic is so easy to cut, building a custom tool of some sort isn't out of the question (not necessarily a custom table saw blade, not sure I'm comfortable with that, but making a custom router bit seems within reach)
-Rob
Old 12-03-2018, 01:08 PM   #26
A modified router/shaper bit would make sense. It would likely require several different bits/profiles but even that's doable. There's a really good machinist just down the road that does work for me now and then. I've got to stop by there and have him machine some parts for my TR6 so if I remember I'll broach the subject with him.
Old 12-04-2018, 08:28 AM   #27
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I remember reading one post from davejay mentioning using long zip ties as replacements....unless I am going crazy, which maybe the case after another jet lag induced 3 hours of sleep.
Still only another 12 hours on a plane later today and I will be back home!
martin300662 is offline   Reply With Quote
Old 12-04-2018, 09:53 AM   #28
I suppose it's possible a properly sized zip tie might work to some extent. The shape of the insert is pretty unique which makes one wonder why Airstream went to the extreme of creating that shape.
I'll see if I can't create an accurate sketch and post it.
Screen window insert for rear/sink window? MaineStreamer 2007 Safari 0 08-02-2015 11:09 AM
Front Passenger Slider Window Handle JudgesArgosy Argosy Motorhomes 15 01-14-2013 08:28 AM
I3500 Slider Door Window Leak RoadJager Sprinter and B-van Forum 9 09-26-2012 06:42 AM
Side window insert mouth012006 Upholstery, Blinds, Walls & Interior Finishes 0 04-06-2010 07:34 PM
Drivers slider window. Inland RV Center, In Commercial Listings 0 10-18-2005 04:09 PM
