Old 10-05-2005, 06:11 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Mechanic refused to smog my MH!
He said that I'm missing the PVC air injection system that's supposed to go from the exhaust manifolds to I think the carb. The vacuum hose is plugged with a golf tee! When I had the Doug Thorley headers installed I was told they are street legal in all states. Apparently these didn't have the attachments for the hose, so they left it plugged out. Does anyone know if headers come with the smog control stuff? I may have to order OEM manifiolds to replace since the old ones were cracked. Hopefully they can "install" the PVC onto the headers or just pass the smog test without.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 10-05-2005, 06:40 PM   #2
uncleneal's Avatar
PCV and AIR
There are two different smog systems on the older engines. PCV is positive crankcase ventilation - it should be a pcv valve that plugs into one of the valve covers and runs a fairly large vacuum line to the base of the carburetor. It's purpose is to suck the blow-by from the crankcase and burn it off in the engine, rather than just vent it out into the air. Has nothing to do with the exhaust.
The other is the AIR - air injection reaction (I think I got the "R" name right). It has a smog pump that runs off one of the fan belts, and vacuum lines hooked to the carb and other valves on the intake manifold, as well as a hose about the size of a water hose connected to a set of metal fittings on the exhaust manifolds. Its purpose is to inject air into the exhaust manifolds to help complete the burn of the fuel and polutants in the exhaust. If this is missing it should be possible to add it to the headers.
Neal
uncleneal is offline   Reply With Quote
Old 10-05-2005, 06:56 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I don't think in California that you can pass a smog inspection with headers. At least that used to be the case. Once upon a time, if you had headers it wouldn't pass the "visual" inspection, regardless of the emissions output.
Roger
Old 10-05-2005, 07:01 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Astrodokk,
What State are you in. I had some real adventures getting my 1984 310 with Banks headers smogged in California. I did suceed. One thing you have to do is make sure he is looking up the requiremnts for the right chassis. The first guy who looked at my MH looked up the 1984 motorhome chassis. That's not the chassis Airstream uses, they use the regular P30.
I ended up going to the smog referee, they told me what I needed, I had it done, and then passed the smog.
guy99 is offline   Reply With Quote
Old 10-05-2005, 08:51 PM   #5
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
God I am glad I live in a county in Nevada that doesn't require smog!
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 10-05-2005, 09:40 PM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
No kidding. I don't have to smog my 88 454 Sub. 8600lb GVWR makes it exempt in GA. When they do smog they don't even look under the hood. My 4Runner failed because of a problem with the EGR. I unplugged my EGR and it passed the sniffer just fine.
Stupid Cali even though the truck is within their requirements at the tail pipe they would have failed the truck.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-05-2005, 09:49 PM   #7
North Central , USA
Does Calif. require all vehicles to pass the same smog test or only 'as built'? ...grandfathering old, antique, etc.
RivetED is offline   Reply With Quote
Old 10-05-2005, 10:07 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Roger
Roger,
Wrong, You can have headers if you also have all other smog equipment. My 1973 PowerWagon has headers, but it did not have an air pump. Having an air pump makes headers more difficult since you need the air line fittings. Calif requires that any vehicle after 1976, I think, meet the emission requirement in effect when the vehicle was produced. My Lincoln is a 49 state car and only has to meet the 49 state requirements, not the tougher Calif 1977 requirements. My Dodge is now exempt from testing.
Bill
Just my personal opinion
Old 10-06-2005, 05:03 AM   #9
85MH325's Avatar
Tipton , Iowa
Images: 37
I only found out what little I know 'cause in 1994 I bought a '78 LandCruiser FJ40 with headers on the 2F engine... WITHOUT the air pump that it should have had... actually the former owner had saved all of the parts including the exhaust manifold, so it was fairly easy to return to smog-legal condition. As I said, it was a long time ago, and I didn't know all of the stuff even then... I just know that they can be tough on header-equipped engines. I understood that within a short time after that, they began producing CA "smog legal" headers... hmmm...
Roger
Old 10-06-2005, 05:44 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
In Georgia we are exempt due to weight. Over 10,000lbs. Maybe you can sell those headers if you get stuck and have to replace them. Hope it does not come to that though.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-06-2005, 07:17 AM   #11
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
In Kentucky we voted out the VET (Vehicle Emissions Testing) centers two years ago as nearly 98% of the cars taking the test passed on the first try. Seemed like a revenue generator more than a true safegaurd for the environment. Tractor Trailers and vehicles over 15,000# were exempt.
About the same time the centers were closed down I put on my headers, ripped out all of the AIR system and the rig runs better and burns less fuel now then when it was stock.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-06-2005, 08:06 AM   #12
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
In California, they require the air injection system. We went through this same ordeal years ago, on a small block chevy in our 72 Blazer, that is now in storage. You can purchase headers with the air injection fittings, and basically plumb it as if it had factory manifolds. Or you can try the referee method. Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 10-06-2005, 02:46 PM   #13
Astrodokk's Avatar
Thanks for all the replies. Just got a call from the folks who installed the headers, and they said that after looking up the info in the book, this one HAS TO HAVE the air injection system, also called "smog pump", which happens to be missing. Asked why they installed if the pump was missing, and he said that it was missing with the old manifolds and they only matched what was there. But good news, it'll only cost 1-2K to replace!
They are looking into getting a new set of headers with the smog attachments built onto them (to attach the hoses), but I have to cough up the smog equipment. Time to go to a junk yard I think. California !
Old 10-06-2005, 06:34 PM   #14
2002 27' Safari
Images: 14
I'd go the junk yard route first, plenty of tried chevy trucks laying around, just find a air pump that you can rotate the drive pulley with your hands, and the rest of the parts, brackets, hose, etc. are easy. Jeff
AIR: 649
TAC: CA-40
Smog Pump Removal & Header Info. 89_370LE Mechanics Corner - Engines, Transmission & More... 37 09-17-2004 02:55 PM
CA. smog - am I in big trouble ? guy99 Mechanics Corner - Engines, Transmission & More... 14 06-27-2004 09:12 PM
California smog test report on MH Astrodokk Airstream Motorhome Forums 16 09-27-2003 05:56 AM
Bad Smog Pump? torin knorr General Motorhome Topics 2 07-03-2003 09:25 AM
Cal Smog? 1988 Airstream 345 nglase Airstream Motorhome Forums 4 04-30-2003 07:34 AM
