11-02-2019, 02:04 PM
#1901
1982 31' Airstream 310
champaign
It's copper Dave, from the tank to a 12" hose inside the generator cabinet.
That small hose looks ok but probably should be replaced.
11-03-2019, 09:37 AM
#1902
champaign
Tested the solenoid before I installed the unit. Got it in, fired right up, bubble tested all my joints, no leaks.
Yeeehawww
11-03-2019, 12:44 PM
#1903
1995 36' Classic 36
Ludington
, Michigan
Always feels good when repair project is a success! And you gain a better understanding of how everything works.
11-03-2019, 12:55 PM
#1904
champaign
It sure does Dave. I've learned sooo dog gone much owning this rig.
11-04-2019, 05:59 AM
#1905
Richmond
, Kentucky
Originally Posted by mayco
Mike, excellent job of diagnosing the problem and then fixing the problem!
1975 24' Argosy Motor Home
11-04-2019, 06:30 AM
#1906
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
mayco,
Where did you pick up your parts at for the propane rebuild.
11-04-2019, 07:49 AM
#1907
champaign
I was able to get the numbers off each component then do a search. I think the three major items, 2 stage regulator, demand regulator, and the gas solenoid valve all came from Amazon. None of them are Onan specific parts. I think I've got the part numbers around here still if you want them Cole.
11-04-2019, 07:55 AM
#1908
champaign
Here ya go:
Solenoid valve; Eaton glp valve snc 1014 3b
Two stage regulator ; camco 59313
Demand regulator; Garretson model KN
Was able to get all the fittings here locally
11-04-2019, 08:50 AM
#1909
champaign
Thank you Brad, I do enjoy the problem solving part. I also really enjoy learning more and more when delving into these situations.
Good for my 62 year old head, always curious on how things work.
11-06-2019, 07:59 AM
#1910
Churubusco
, Indiana
Well done Mike!
Just fyi, one of those camco regulators failed after about a week on me once, ended up with really really low pressure. Probably fine, but if things act up I'd check that first!
1983 Airstream 310 Class A Motorhome
-Rob
11-06-2019, 11:17 AM
#1911
champaign
Ya Rob, I looked for a direst replacement as the original but it was nla. This Camco was a cross reference....didn't really like buying it but I did so we shall see. Nothing special about it, probably should have gone with a Marshal.
11-06-2019, 11:41 AM
#1912
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
mayco,
Thanks the part numbers will come in handy as I go through my systems.
11-06-2019, 03:59 PM
#1913
champaign
My pleasure Cole. Hope they help.
12-01-2019, 04:39 PM
#1914
champaign
Has anyone here recently ordered the “beltline insert” for their Classic? I need to replace all of mine and I was hoping someone could share a part number or dims and possibly where they sourced it. It looks to me that different vendors use different terminology for the insert and different dimensions, some use the exposed dim and some use the entire width of the insert piece. Airstream calls it “beltline insert”. Thank you for any info!
At any rate, the stuff is expensive, I know that!
12-01-2019, 05:42 PM
#1915
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Mike, last I ordered from ODMRV for my 310's Center belt line double moulding was this stuff, but it was black. Now i only see it in dark gray
http://odmrv.com/catalog/index.php?m...oducts_id=1180
AIR #13
12-02-2019, 09:04 AM
#1916
champaign
Thank you Peter. Dog gone it, gray only. That’s a good price on the insert. If the bottom rub rail wasn’t black then I could get away with the gray in the beltline. I’ll keep poking around. Thanks.
12-02-2019, 09:18 AM
#1917
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Has anybody tried the gray inserts 1/4" and 1.5". My P/S is completely dry rotted on both pieces and I need to change mine and was wondering how the gray would look. Any pics out there
12-02-2019, 03:15 PM
#1918
Churubusco
, Indiana
Mike, my PO did 2 years ago and he kept meticulous notes on every part number he ever ordered. I also think I have some leftover.
I'll try to dig it up, but I'm away from home for a few days, if I don't get back to you within a week PM me so that I get an email.
-Rob
12-02-2019, 07:29 PM
#1919
1984 27' Airstream 270
West Chester
, Ohio
If you like blue, VTS has what you need. This is what we used, fit perfectly! It is recommended to install at 60-70 degrees to avoid shrink/sag in extreme temps
12-02-2019, 07:30 PM
#1920
West Chester
, Ohio
50-70 Deg...typo
