Old 08-01-2015, 08:54 AM   #121
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Lynn n I had a great time with John n Anne. Man Tony, thats one heck of a story about your uncle and aunt.
mayco is online now   Reply With Quote
Old 08-08-2015, 02:09 PM   #122
1982 28' Airstream 280
Redwood City , California
Mike, I don't know if you have seen this diagram for the '82+- dash A/C wiring. It sure helped me out when I was trying to figure out my dash A/C.
Let me get out my sharpie and explain it to you!
dadstoy is offline   Reply With Quote
Old 08-09-2015, 05:36 AM   #123
mayco's Avatar
Thanks Dean, where did you find this? From the schematic it looks like the orange wire I disconnected goes to the blower motor sw for the dash AC. It was the one causing the parasitic drain. Good news is that the rig has sat now for several days with the chassis disconnect turned on and the battery is holding a good charge. Tested it yesterday afternoon and it was at 12.43v.
Question; on a charging system that is operating properly, no parasitic drains and battery at full charge, what would be considered "normal" drop in voltage over what period of time??
Thank you,
Mike
Old 08-09-2015, 11:15 AM   #124
It's out of the Chevy Light Truck repair manual. I only have a hard copy.
Old 08-09-2015, 11:41 AM   #125
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I got my service manuals for my 1975 and 1978 from 73-87ChevyTrucks.com (you have to use Goggle to search as the manuals seem to be in a tech area not the main site).... this is the the link for the closest year I can find (http://www.73-87chevytrucks.com/tech...ice_Manual.pdf).
martin300662 is online now   Reply With Quote
Old 08-09-2015, 11:55 AM   #126
I believe this is the one I have. It's a must have!
Old 08-09-2015, 11:57 AM   #127
Thanks a million for that link!
Old 08-09-2015, 02:19 PM   #128
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Your more than welcome Dean.
On the earlier models Chevy published a 'master' manual every major year change and then a supplement for each year; so for my 1975, I have the '74 manual and the '75 supplement. Not sure if it is the same for later models, but worth keeping in mind.
Old 08-09-2015, 02:41 PM   #129
Mike,
I'm pretty sure I have the 81 Chevy manual sitting on the shelf that I no longer need. If it's what you're looking for you're welcome to it.
Old 08-10-2015, 05:19 AM   #130
mayco's Avatar
Brad, if you find that manual Od love to have it. Just let me know and Ill send you my particulars. Awfully nice of you to offer!!
Martin, thanks for that link, Im going to open it up right now and check it out. Thank you!
Mike
Old 08-10-2015, 04:50 PM   #131
Mike
Mike I have the service manual and a supplement manuel sitting on the table. PM me your info and I'll get it shipped. I'm out of town until Sunday but should be able ship early next week.
Old 08-10-2015, 05:46 PM   #132
mayco's Avatar
You're the best Brad, thank you !!!!
Old 08-10-2015, 06:09 PM   #133
mayco's Avatar
Got around to a couple projects over the past few days. I needed to finish the dog house cover first of all. I had installed some temporary cup holders and a plastic waterproof marine head unit case to get us by till I got to the permanent install. When I got my rig there was no entertainment center or glove box AND the PO had carpeted over the bolts to remove the dog house for maintenance. Got the top covered in a combination of an aluminum cover for the front panel and then padded and covered the rest in the couch fabric a couple weeks ago. The past couple days I worked on building head unit case. Wanted an old school looking case like an older Kenwood receiver power amp. Built the box out of plywood and banded the front with walnut to match the fold out table. Then I laminated aluminum over the plywood. Added the head unit, map light with push button latching sw, and found a pretty cool Airstream logo to finish it off;
Name:	ImageUploadedByAirstream Forums1439247540.077792.jpg
ID:	245148Click image for larger version
Name:	ImageUploadedByAirstream Forums1439247566.394788.jpg
ID:	245149Click image for larger version
Name:	ImageUploadedByAirstream Forums1439247590.411080.jpg
ID:	245150Click image for larger version
Name:	ImageUploadedByAirstream Forums1439247625.461913.jpg
ID:	245151Click image for larger version
Name:	ImageUploadedByAirstream Forums1439247652.611512.jpg
Then Shepard57 (John ) was
Nice enough to bring down the rear passenger side wheel well trim to replace mine that had been boogered up pretty bad by the previous owner.Click image for larger version
Name:	ImageUploadedByAirstream Forums1439247851.844127.jpg
We thought it was a direct replacement but the one John had was about 3" too wide. So I ended up cutting out the 3" from the straight top part of the trim and ended up with a joint. I don't have a metal chop saw so I had to use my jog saw to make the cuts. Unless you were looking for it, I think the joint is pretty unnoticeabe.Click image for larger version
Name:	ImageUploadedByAirstream Forums1439248112.244145.jpg
Thanks again John
Name:	ImageUploadedByAirstream Forums1439248143.144888.jpg
Old 08-10-2015, 06:42 PM   #134
Nice setup! I like the light. I need a light on mine! It's cool to see what everyone does with their dashes.
Old 08-10-2015, 08:13 PM   #135
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
...The past couple days I worked on building head unit case. Wanted an old school looking case like an older Kenwood receiver power amp. Built the box out of plywood and banded the front with walnut to match the fold out table. Then I laminated aluminum over the plywood. Added the head unit, map light with push button latching sw, and found a pretty cool Airstream logo to finish it off;..........
Yes, proof is in the pudding, great minds think alike
This is what I did in 2001 to my 79 Excella "Entertainment Center". In time, I did add more gauges and switches and lights to the empty space on the right.
ID:	245176   Click image for larger version
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 08-10-2015, 08:29 PM   #136
mayco's Avatar
Was that the original Peter, painted and a new face plate? I struggled with designing mine, had all kinds of ideas and things I wanted to include in it. Finally I said forget it! Keep it simple and get it done already. So thats how I ended up with that rather simple design and configuration.
Old 08-10-2015, 08:47 PM   #137
Airstream Driver
1994 30' Excella
Images: 51
Yes Mike, it was the original plastic Entertainment center with an 8-track player. I painted it silver, cut out the "Airstream Entertainment Center" and replaced the flimsy face plate with a thick alu plate.
You still have lots of room to add lights and switches. Always nice to have an actual voltmeter for the coach batteries.
AIR #13
Old 08-12-2015, 12:27 PM   #138
Mike,
I forgot to mention the manuals I have are 1981. I think your coach is an 82. If you're still interested they're yours.
Old 08-12-2015, 03:43 PM   #139
mayco's Avatar
Yes Brad, I would still like to have that manual. Awful nice of you to offer. Sent you a PM with my particulars.
Mike
Old 08-13-2015, 08:24 AM   #140
Ok sounds good, I'll get them in the mail sometime next week.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
