07-20-2017, 06:16 PM
#1001
1982 31' Airstream 310
champaign
Thank you Brad, I may take you up on your offer depending on what I find. I didn't get a chance to get up there today.
Bob, that's a very cool idea. Did you go wireless or hard wired. Depending on where the existing wire enters he roof, I might be able to use it as a pull wire..it would be lucky but might work.
I use that camera quite a bit on the road. After it went kaput, I found myself glancing at it while driving and realized how much I use it.
07-20-2017, 06:42 PM
#1002
Richmond
, Kentucky
I didn't get a chance to get pictures tonight, was working on Peanut. I'll get them first thing in the morning.
Not a chance of using the old wire as a pull wire. The existing wire is tie wrapped, glued and clamped in place from front to rear along with all the other wires running along the top of the coach.
Hopefully Bob explains what wiring he used to go from the camera to the front of the coach. I do know the old cable is a multi conductor cable with probably 6 to 10 small gauge wires. I still have the entire bundle I removed from the 345. I would think you could make use some of the existing wires out of the existing bundle.
1975 24' Argosy Motor Home
07-20-2017, 06:53 PM
#1003
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
You can use the existing wiring....no problem. Regards, Bob
07-20-2017, 07:28 PM
#1004
Dazed and Confused
Hillsburgh
, Ontario
I'd imagine the Alpine unit that Bob installed probably pulls a lot less juice than the old OEM units, so Mike I'd say you're good to use the old wiring. Probably get a whole lot better resolution and panoramic view with a new unit.
I've read that wireless units get iffy at over 17' of length.
I never have to worry about my back up camera breaking down as I swear she'll drive me into the ground first. The big problem I have with my back up system, is the hands start out 3' across and then all of a sudden go to 2" if I so much touch the gas.
Cheers
Tony
07-21-2017, 10:30 AM
#1005
Richmond
, Kentucky
Mike, here's the pictures I promised.
I tend to agree with Bob and Tony about installing something new. However if you want to stick with what you've got and these match what your's then you're welcome to them.
07-21-2017, 11:45 AM
#1006
champaign
Thank you Brad. I got distracted and was doing some work on my genset...that never happens right? That looks very similar to mine, I need to get some pics up so I can show the wire that runs to the camera. There is some device in the wire, a few feet from the camera on the roof that's encased in some type of epoxy or something. It would be fantastic if I could use the existing wiring. I assume it's a multi-conductor wire. Its friggin miserable up here in central IL. Imagine its the same down in Kentucky. 95 degrees right now with 85-90% humidity so not doing a lot outside. I can't believe I used to put in 8hrs a day out in this weather...that's for the young-n-s.
07-21-2017, 11:48 AM
#1007
champaign
Cheers
Tony
Hehehehehehehe, but its purdy!
07-21-2017, 02:48 PM
#1008
champaign
07-21-2017, 04:49 PM
#1009
north blenheim
, New York
Time to upgrade !
07-21-2017, 04:59 PM
#1010
champaign
Originally Posted by bobmiller1
Time to upgrade !
Yup
07-21-2017, 05:16 PM
#1011
Richmond
, Kentucky
Mike, that's an interesting cable arrangement. On the 86 345 the cable went from the camera down into the shell and ran inside all the way to the front.
It's as if yours is more like an afterthought.
07-21-2017, 05:27 PM
#1012
champaign
I agree, it enters the skin through the refrigerator vent. I haven't tried to trace it after that. I found it under the dash though. Ill look more tomorrow. Heck it may run down and through the floor but I've not run into it while working on other things under the rig. It will be easy enough to find if that's what it does.
07-24-2017, 03:15 PM
#1013
champaign
I'm gonna put the camera on hold for the moment....man the options are unlimited. In the mean time I'm going to bite the bullet on new captains chairs. I thought we might start by taking a couple days and head over to Elkhart Indiana and snoop around at the numerous vendors over there. Not too far of a drive for us and we will just camp for a couple days.
I'd love to know what any of you have done if you've replaced your driver and navigator seating. I see three or more options, have the existing seats redone with new foam and fabric to match our rebuilt sofa, buy new seats, try to find used seats from CL or a salvage yard, or find seats from a different vehicle and repurpose them for our captains chairs. (I think that's what Martin did. Ive been poking around looking at seats out of Sienna vans)
Brad, what are you planning to do with your Argosy seating?
Any advice you guys could give me on what you have done or what you might do for replacement. Any preferred vendors or particular seats out of a vehicle for repurposing for captains chairs? Having my existing seats rebuilt is probably the most epensive option.
Manual seats are fine with us but nearly all the used or surplus seats I've seen are power. I'd like to use our existing seat bases, they do have the standard 8"x 11" bolt pattern.
I'd appreciate any thoughts or recommendations you might have for me. We don't mind traveling a ways to get this done. What do you fellas think about the options here?
Thank you as always for your thoughts,
Mike n Lynn
07-24-2017, 04:48 PM
#1014
Dazed and Confused
Hillsburgh
, Ontario
Steve (Keyair) used seats out of a Range Rover....which if I know the Lucas, the Prince of Darkness, will one day start inexplicably moving forward, jamming Steve up against the steering wheel or start tilting back for same reason.
Any seat can be made to fit IMHO, so go out testing some seats until you find the best fit. Toyota's tend to have good comfortable long distant seats as well as Volvo's. Stay far away from Ford, GM or Chrysler.
I can vouch for the Nissan Altima as my 3.5 SE seats are awesome and I can drive for hours in them. I do like Volvo seats as I did sit in a new Volvo XC90 at the autoshow......imagine your buttocks are cradled in the hands of God.
https://www.edmunds.com/car-buying/t...back-pain.html
Cheers
Tony
07-24-2017, 05:16 PM
#1015
champaign
Good link Tony
07-24-2017, 09:41 PM
#1016
1982 28' Airstream 280
Port Angeles
I bought a pair of seats from this outfit http://www.discountvantruck.com/
I had them made up the way I wanted and I have been quite happy for about 50,000 miles in them. I understand the fit of a seat in a nice sports sedan but I don't drive my moho like a sports sedan. I prefer a more relaxed comfort in the moho.
Cheers, Dan
~ Margaret Thatcher ~
07-24-2017, 11:22 PM
#1017
1986 34.5' Airstream 345
Alliance
, Ohio
If you go to Elkhart stop in the RV/MH Hall of Fame. A few years ago Rita and I spent an afternoon there. Many interesting older trailers and motor homes were on display.
07-25-2017, 05:35 AM
#1018
champaign
Thanks for that link Dan. Ive run across their web site before I think.
Will do Lance!
07-25-2017, 06:23 AM
#1019
Richmond
, Kentucky
Mike, I'm going down the same path Martin did with the Stow-n-Go seats out a Dodge Caravan.
I bought two 7" seat pedestals and two 6-way power pedestals to mount the seats on. Using some 1/4" x 2" flat bar stock I fabricated some adapters to bolt the power pedestals to the fixed pedestals and to the seats.
I can't vouch for comfort but Martin's been using them for a while now so hopefully he will chime in with comments. Total cost with power pedestals, seats and fixed pedestals was about $1000.
07-25-2017, 12:31 PM
#1020
champaign
That looks pretty sweet Brad.
