Old 07-12-2016, 05:34 PM   #491
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by mayco View Post
Its just so weird working on something where you throw plumb, level, and square out the window. Different experience for sure.
Mike, it's called "fair line" carpentry; used with shipping. If it looks good, then it is good. The only tool I used in the layout was a laser to mark out centreline down the whole coach.
I made the mistake of putting up both rear valences by cutting a board the distance from the couches I wanted the valence's to be. I placed the board across the couch platform and installed the valences; so they are exactly the same distance from the couch front to back. However if you were to sit on the couch and look at the valence, you'd swear I had installed them unevenly. It's a conversation starter...
Looking fantastic Mike, and yes, the old axiom applies; "take how long you think the job is going to take, and how much it's going to cost; then double it".
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-12-2016, 07:40 PM   #492
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thanks fellas...............I think
mayco is offline   Reply With Quote
Old 07-12-2016, 07:57 PM   #493
mayco's Avatar
When I was getting a quote from the company, they at first didnt realize that I was going to do the install. They quoted me something like $28 per sq foot installed. AHHHHHHHHAHAHAHAHAHAHA. nope!
Old 07-15-2016, 10:06 AM   #494
mayco's Avatar
Battery hatch and step pretty well wrapped up. Still need to poke a couple wires through the step side for the light.
Name:	ImageUploadedByAirstream Forums1468598517.865346.jpg
ID:	266831Click image for larger version
Name:	ImageUploadedByAirstream Forums1468598547.342534.jpg
Old 07-15-2016, 11:03 AM   #495
Looks really nice Mike!
Old 07-15-2016, 12:08 PM   #496
1989 34.5' Airstream 345
Ebro , Fla Panhandle
That new wood flooring really does look great Mike! But couldn't you use that gold colored trim to tie in with the facuits, shower etc. �� Bawahaha
Are you going full length of the coach with that beautiful wood?
Funky tho it may be, I really like the warmth of the carpet in the bedroom.
Are you doing any insulation under the wood?
Do the wheel wells intrude in the head floor in the 310?
Would require some interesting trim in a 345.
Will be following along as you continue the project.
Thanks for posting, May not be too far behind you in taking on the floors.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-15-2016, 01:25 PM   #497
mayco's Avatar
Thank you fellas. Richard Im going from the step-up to the cab area all the way back. Ill shoot some pics when I get there. Ive got maybe 4 or 5 boards left to install so Im close. Hope to finish the flooring this weekend and then figure out how in the heck Im going to trim it out. Some runs will just be a caulk joint to the wall and some areas will look better with some sort of trim. Dont know yet what type of trim Ill use, I may end up making some up out of some walnut because it matches the teak so well. (Dont kill me Tony)
This flooring has a thin layer of foam/insulation/pad adhered to the back, Im not adding any additional. Im not sure how much you would gain unless you insulated between the framing members with a rigid insulation. Even then Im not sure if its worth the effort.
My wheel wells are covered with the rear queen bed.
This flooring is pretty easy to work with once you figure out a few techniques. If anyone else here ends up using it I would like to share a few odds and ends Ive found to be helpful. It cuts real nice and leaves a good clean edge. Easy to make tight corners and curves using a jig saw with a scroll blade. Rips fine on a table saw. Im using a Delta Sidekick for butt cuts. (the Sidekick is like a portable radial arm saw for job sites)
Hopefully Ill have pictures of the entire floor minus edge trim early next week.
Mike
Old 07-15-2016, 04:07 PM   #498
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Attachment 266831Attachment 266832
What a nice Job, Mike. Remember perfectionism is not a virtue, its a curse
And don't listen to Richard (tevake), he is probably so jealous, he can't stand it.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 07-15-2016, 04:25 PM   #499
mayco's Avatar
Thank you Peter. I shoot for "pleasing to the eye", thats about as close as I can get....sometimes! or possibly the 30-30 standard, looks perfect at 30mph at 30 ft away.
Old 07-15-2016, 04:46 PM   #500
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Nice work mike....did you say " Butt Cuts...??? Is that like Butt Crack state park ??? Regards, Bob...dam auto spell.
bobmiller1 is offline   Reply With Quote
Old 07-15-2016, 08:03 PM   #501
mayco's Avatar
Hmmmmmmm, ya, in fact I think we stayed there
Old 07-18-2016, 09:30 AM   #502
mayco's Avatar
Flooring pretty much done now on to trimming out...Click image for larger version
Name:	ImageUploadedByAirstream Forums1468855700.858041.jpg
ID:	267132Click image for larger version
Name:	ImageUploadedByAirstream Forums1468855723.525458.jpg
Name:	ImageUploadedByAirstream Forums1468855747.039113.jpg
ID:	267134Click image for larger version
Name:	ImageUploadedByAirstream Forums1468855771.804876.jpg
Old 07-18-2016, 09:34 AM   #503
Very very nice, definitely something to be proud of!
Old 07-18-2016, 09:37 AM   #504
mayco's Avatar
Thank you Brad, very much.
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
