Old 07-03-2016, 01:43 AM   #463
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
I still have the kool-o-matic in ours. Uses a bit of electric but pulls lots more air than the maxxair in the bedroom. I like the two speed thermostat as well!
Kreimer is offline   Reply With Quote
Old 07-03-2016, 01:54 AM   #464
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
I love my teak and holly floor!Click image for larger version
Name:	ImageUploadedByAirstream Forums1467528755.897678.jpg
Name:	ImageUploadedByAirstream Forums1467528817.581147.jpg
Name:	ImageUploadedByAirstream Forums1467528839.182545.jpg
SebasSF is offline   Reply With Quote
Old 07-03-2016, 06:00 AM   #465
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Love the floor, especially the entrance step well. Is it a floating system or tacked down ?
bobmiller1 is offline   Reply With Quote
Old 07-03-2016, 06:57 AM   #466
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
http://thd.co/1mCNCzH
This is the one I used as it was a cheap laminate and I was in a bit of a hurry. There is a foil paper material similar to this that I used in my roof when I built the house 20+ yrs ago and it really works well.
http://thd.co/1VeCv5g
When I was installing it, you could feel an immediate difference where it was installed, even before insulation.
As for floor heating, I've used it in my master bath at home for years and if your budget allows I highly recommend it! I used SunTouch warm wire as its a very irregular shape, and plan to install it in the Moho when the boss finally allows the gutting and redo. SunTouch also has mats that would be easy to install right down the center and be highly effective. Hope this helps!
http://www.suntouch.com/indoor-solut...-heating-wire/
-Bill
gaiaenviro is offline   Reply With Quote
Old 07-03-2016, 07:09 AM   #467
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
SebaS, if I remember correctly that is real teak and holly wood correct?
mayco is offline   Reply With Quote
Old 07-04-2016, 11:51 AM   #468
mayco's Avatar
Well Tony, Lynn got my script refilled and Im back on the meds so the voices have calmed down.....a bit. In the middle of patching some subfloor, the biggest patch right down the center in the kitchen area extending in front of the couch. The highest traffic area of the coach. Bone dry just sagging and weak between the framing members, see previous post.
Thinking ahead a bit, my '82 has the battery hatch right inside the door step. Ive been contemplating the finished edging on the hatch door and the end cuts of the teak n holly where they meet the hatch door. I believe Im going to end up using some type of aluminum or chrome trim cap to cover the end cuts around the perimeter of the hatch hole.
So it will be an "L" piece with maybe a 1/2" leg and a 3/4" leg +-. Do any of you have a good resource for ordering this type of trim piece? Ill want something pretty thin.
Thanks for any info on companies that supply this sort of metal trim..
Mike
(where life is beautiful all the time)
(some old farts might remember that song lyric)
Old 07-04-2016, 12:29 PM   #469
SebasSF's Avatar
Correct...real tongue and groove teak and holly installed with marine epoxy. Won't ever come out!
Old 07-04-2016, 01:03 PM   #470
mayco's Avatar
Its beautiful
Old 07-05-2016, 05:48 AM   #471
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The best med is the love of a beautiful woman........
http://www.richelieu.com/ca/en/categ...-sides/1035863
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-05-2016, 06:06 AM   #472
mayco's Avatar
Thanks Tony
Old 07-05-2016, 06:13 AM   #473
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Mike
If you go to the carpet department at Home Depot, you will find a rack with aluminum and gold colored trim pieces in various length and shapes. I have used them for years in my Airstreams and real like them. They do make 90 degree ones with 1 side pre drilled and groves for slip prevention.
BTW, not to ruin your new med effectiveness , but plywood layers are cross grained to give them equal strength in either direction. A seam in the middle would cause a lot of other issues, imho.
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-05-2016, 06:46 AM   #474
mayco's Avatar
Thanks Peter, I wasnt using the right words in my search. I should have googled "aluminum angle" and I was searching outside corner. Ill check it out.
As far as plywood is concerned I guess I beg to differ. Yes, they are cross grained but the strength of plywood is along the 8' run with the top and bottom grain, the strength axis. Any google search will give you those results. Having been a carpenter for 20+ yrs Ive seen it up close and personal. Have you ever seen a roof or sufloor decked any other way?
Here is a simple video..
Old 07-05-2016, 05:19 PM   #475
Airstream Driver
1997 30' Excella
Images: 51
Mike, pass the pills, I stand corrected. I always thought that it was pure economics to run plywood that way, to have less waste. But I am not a pro carpenter.
Concerning the Airstream Flooring, I still think its better in the long run to not have a seam down the middle, especially on trailers, since the flooring is such an important part of the structural integrity of the hull.
1996 Airstream B190
AIR #13
Old 07-07-2016, 03:19 PM   #476
mayco's Avatar
Ive installed lots of 3/4" hardwood floors but this is my first time working with a click lock system. Im kinda learning as I go here. Im beginning to think this may be a two person job. One to install each piece and the other to help stabilize whats already down so the joints dont open up. ( stand on it) I dont think Ive ruined any material so far.
Like Tony had said earlier, the layout starts at the bathroom door or wall. I cut that piece into the doorway first and used its outside edge to start the layout line. I believe thats about the only way to lay this floor out.
I screwed some plywood cleats to the subfloor to help keep the runs from moving around when I tap the boards to tighten the joints.
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
