Old 03-12-2016, 03:29 PM   #421
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Originally Posted by mayco View Post
........... Ill invest $1500 in spare/hard to get parts and break down in the middle of some swamp in Louisiana, it will be a $5 dollar part I'm not carrying
Actually with a 36 year old diesel, that would be a great place to have issues since all of their swamp stuff is from the same time period and Budreaux could fix it in 2 minutes with some bailing wire and parts he keeps on hand for his 40 year old diesel truck!
I speak from experience since I broke down in the middle of nowhere Alabama and the nearest Diesel shop happened to work on old cummins daily and was a nationally known early model cummins fuel pump rebuild shop for the marine and industrial folks.....
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 03-12-2016, 04:58 PM   #422
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I remember that Dave, and didnt the shop have some catchy name like....Dixie Diesel or something?
mayco is offline   Reply With Quote
Old 03-12-2016, 05:33 PM   #423
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Not having the five dollar part is part of Murphy's Law...just saying
bobmiller1 is offline   Reply With Quote
Old 03-12-2016, 06:01 PM   #424
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I don't know what world you boys are living in, but for the love of all that is holy.......What part on our Isuzu 6BD1 is five bucks. Heck even the K&N oil filter oil is a gazillion dollars an ounce.
The filters are not cheap and the rest is bloody unobtanium.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 03-12-2016, 09:04 PM   #425
mayco's Avatar
One rubber seal/washer for valve cover bolt is $1.73 but you need 5
Old 03-12-2016, 09:51 PM   #426
Dazed and Confused
Isuzusweet's Avatar
Dang it dear, I jest dropped that dang rubber seal for the valve cover bolt so we're stuck and we jest not going anywhere.....Doesn't count....
HOWEVER a stainless steel hose clamp that breaks costing less than $5.00 would leave you cursing on the side of the road, but not worried about getting a replacement.
Have you thought of taking a spare starter relay solenoid?
Cheers
Tony
Old 03-13-2016, 05:34 AM   #427
mayco's Avatar
Thats a good idea Tony.
Old 03-13-2016, 07:51 PM   #428
wxbuoy's Avatar
Yup Dixie Diesel. 6 hr drive from here. I am gonna take the beast there for all her diesel work.
AS far as parts What you mentioned and:
Hydraulic filter (if so equip)
a complete change of oil, antifreeze brake and steering fluid. Not that you will do a change, but enough to keep it full if there is a slow leak till you can get somewhere.
At least 3 spare primary and 2 secondary fuel filters if going remote or if you use special filters. The NAPA Gold for my engine are actually bad since they are too fine and clog very quickly... Not recommended by the manufacturer for that reason.
A torque wrench. I carry a 1/2 for the wheels.
A 1/4" torque wrench
feeler gauge (so you can set intake and exhaust clearances) Normal maint on a diesel.
Emergency repair tape.. for fluids
shark bite fittings. End cap and 2 junctions. So you can replace a pice that is leaking or just cap it off.
A few feet of pex (enough to do a bypass) I slid a length between the water tank and the wall
spark plugs for gene
Engine starter (with solenoid) The biggest killer is old wires and heat from a diesel. We have both! Ask me how I know....
small battery charger/minder. I keep it hooked up if I am parked for a few days since the locks and steps work off the start battery.
various screws
Various size rivets with pop rivet gun
a tube of tempro/sikloflex
a bottle of Capt Tully's creeking crack cure
spare primary fuel pump if you haven't replaced uours in last 10 years (rubber diaphragms rot ) This can always be kept at friends house and fedex'd
spare cork screw
spare fuses (bussman or equivalent) Inventory every fuse you have.
Spare belts for everything.
Can of either... Starting fluid....etc.
Box wrenches to bleed fuel system if need be.
Good Sam Roadside assistance card. I would never leave home with out it!
spare fuel line.
Dave and Felicia
Old 03-30-2016, 04:42 PM   #429
mayco's Avatar
Finally broke down and bought some new compartment door locks for the 310. Ill be able to flip flop some of the locks so these two new ones will go on the 2 lock compartment door just behind the entry steps. Yes, one more key on the ring. They are pricey little buggers from Mr Lock. The original locks were by Chicago Lock (no longer in biz) #4260-1. Mr Lock numbers are 19587 for the lock without cylinder and 19605 for the cylinder with 2 keys. Total price to my door was $125.13.
Name:	ImageUploadedByAirstream Forums1459374037.322925.jpg
One more little thing off the list.
Old 03-30-2016, 06:09 PM   #430
mayco's Avatar
Just a note on these locks. These locks were also used on Coleman popup campers and they call them "stepper door lock". The Coleman camper used only one lock per camper. If youve got a useable cylinder for your lock off the Airstream then you could use it in a salvaged lock from one of these Coleman popup campers. I found quite a few on Ebay and they are indeed the Chicago Lock #4260. You would also need the bar latch off the back of the lock because Coleman had a different mechanism. Might be able to save some money by finding one or more off of older Coleman popups. I wanted new. Just thought Id pass that along.
Old 03-31-2016, 05:48 AM   #431
Dazed and Confused
Isuzusweet's Avatar
That cost just as much as my front door lock set!
Getting her ready for May I see.
Cheers
Tony
Old 03-31-2016, 06:08 AM   #432
mayco's Avatar
"That cost just as much as my front door lock set!
Getting her ready for May I see."
As good excuse as any I suppose. When I got the rig NONE of the compartment door locks were operable. I was able to get all but one working. Ive put off buying these for some reason.
Old 04-16-2016, 09:14 AM   #433
mayco's Avatar
MAYCO's 1982 310 TD
We were able to get out and shake the dust off the rig this weekend. Just an hour away from home but a nice park, Moraine View State Park. All systems go so far on the 310, running real well.
Name:	ImageUploadedByAirstream Forums1460816053.518149.jpg
Name:	ImageUploadedByAirstream Forums1460816085.564803.jpg
Name:	ImageUploadedByAirstream Forums1460816012.474757.jpg
Old 04-17-2016, 09:15 AM   #434
1982 28' Airstream 280
Redwood City , California
Looks beautiful Mike...your coach and the park! I'm jealous since I'm working again this weekend.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
