Old 02-10-2016, 04:33 AM   #379
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Dave thats just great. Thanks so much. Ill send my email.
mayco is offline   Reply With Quote
Old 02-10-2016, 11:20 AM   #380
Little did you know a couple of years back Dave, you would be a "Rivet Master" wading in with such good info!
Nice one!
Old 02-10-2016, 12:44 PM   #381
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
And when are you going to get started on your Cummings re fit. I would like to watch your progress before I tackle mine
shepherd57 is offline   Reply With Quote
Old 02-10-2016, 04:56 PM   #382
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
MAYCO's 1982 310 TD
Nice one!
I am the farthest thing from a rivet master, just a darned good researcher
Besides, as they say, even the blind squirrel will find his nuts occasionally!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 02-10-2016, 05:01 PM   #383
Dave,
To be honest if you're not a good researcher it would be extremely difficult to get anything done on these rigs. My guess is for every hour I work on the Argosy I spend 4 hours researching where to find something or how to do something.
Old 02-10-2016, 05:32 PM   #384
wxbuoy's Avatar
Excellent point!! I am looking forward to only spending 4 hours researching something!
Dave and Felicia
Old 02-11-2016, 04:57 AM   #385
Well I will admit I've gotten faster at researching the last few years...
Old 03-05-2016, 11:56 AM   #386
mayco's Avatar
Had the motor cover completely off doing some things and thought Id go ahead and grease the water pump. I greased it once 3 years ago but that was when I had the whole front end torn down back to the motor. Its been over 5000 miles since. I have no idea how often I should be greasing it but figured it wouldnt hurt for sure. Ive read what a nightmare it is to get to with everything in place.
It really wast that bad. With the motor cover COMPLETELY off, I laid on top of the motor and used a pneumatic grease gun with a rigid/angled tip. Was able to slide it between the upper radiator hose and the valve cover. Would have been a two person job, or impossible, with a manual pump grease gun.
Name:	ImageUploadedByAirstream Forums1457204164.124075.jpg
Name:	ImageUploadedByAirstream Forums1457204197.789369.jpg
Old 03-05-2016, 01:29 PM   #387
1995 36' Classic 36
Ludington , Michigan
It's more important to grease them regularly on engines that sit a bunch. Next time you have access you might consider replacing the zerk with a remote greasing tube that's easy to get the gun on.
Kota is online now   Reply With Quote
Old 03-05-2016, 03:15 PM   #388
mayco's Avatar
I wondered about that Dave. I wasnt sure such a device was even available.
Old 03-05-2016, 03:49 PM   #389
mayco's Avatar
I suppose just fabricate one myself to the exact length and angles.
Old 03-05-2016, 11:00 PM   #390
1995 36' Classic 36
http://www.saeproducts.com/grease-fi...on-blocks.html
Old 03-06-2016, 06:38 AM   #391
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by bkahler View Post
Dave,
If I'm honest, I know how the Canadian forces feel about their old Sea King helicopters, as for every hour of wheel time in my Mistress there has been twenty hours of research, twenty hours of work and $500.00 per hour.
I figure I have one or two more years at this ratio, what with redoing the electrics and the exterior still to do; but hoping I can get it to one hour research, one hour maintenance, and $50.00 per hour wheel time.
To all that make the research possible, and easier, Bkahler, wxbuoy, Mayco, Tevake, Smartstream, Steamquest, Kota, Keyair and last but definitely not least, Shepherd57, a great thanks mates. Without you lot I'd have no hair left, no wife, and would have sold the kids to pay for it.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-06-2016, 07:05 AM   #392
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by Isuzusweet View Post
.......... but hoping I can get it to one hour research, one hour maintenance, and $50.00 per hour wheel time.
Apparently I have paid for the next 5000 hours wheel time up front
And that is with with doing the majority of the research and a lot of the small fiddly work myself. For example, I 'wasted' (according to my wife) 6 hours yesterday experimenting with the best position/mechanism for fitting the rear view cameras on the rear light panel. That achieved I now have to modify the actual panel and drop it back to Airstream to refit this week.
martin300662 is offline   Reply With Quote
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
