12-27-2015, 12:22 PM
#323
Foothill Ranch
Mayco,
Great pictures!
I was thinking about you comment about you boost being higher than you have ever seen.
Here is a thought... Combination of cold, dense air, and the Cetane/octane boost from the additive, making better combustion!
12-27-2015, 12:56 PM
#324
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Amazing what a few days and 4 / 5 inches can do to change the landscape.
Beautiful!
Mike I would plan on putting one of your space heaters under the coach for some time in the afternoon, and maybe screen the area with some plywood or cardboard, whatever comes to hand to free up those valves. And maybe a hot shower around that time too. I've poured a kettle of hot water down the head also. The exposed tanks and drain pluming is a challenge for our classics.
Nice to hear that you two are staying cozy and enjoying the trip. Good thing you are used to chilly weather from home.
Good move on the U Haul van :-)
Happy New Years , Richard
12-27-2015, 02:56 PM
#325
1982 31' Airstream 310
champaign
Good call on some hot water down the sink/shower and toilet. We have kept our gray water tank nearly empty the whole trip. I found a nice sized tupperware type tub that slides perfectly into one side of the kitchen sink. (Looked forever to find the right size) So all dishwater, bathing washing up water, etc etc etc has been done in that tub. Then we just take it outside and dump. The gray water tank hasnt even moved off empty. So thats worked out real well. In fact, Ill need to add water to the gray tank when we dump in order to rinse the slinky after dumping the black. I started out the trip by pouring one gallon of RV anitfreeze in each tank and then have added more with each use. We will need to dump the black tank within the next day so we will find out!!
Key, I think youre correct in that assumption. Those things along with the fact that our travels for the most part have been in and around the flat lands of the midwest. There are some REALLY LONG and fairly steep uphill grades on US36 in western KS. I really dont
know squat about turbo chargers other than the general concept on how they work. I ASSUME that seeing that kind of boost (12-13) on my gauge means the turbo is doing its job well. Ive read other threads where people have stated that they had trouble getting 10lbs of boost.
12-27-2015, 03:21 PM
#326
champaign
Oh ya, they have great heated shower facilities here at the campground and a nice laundry.
Hehehehehe, we HAVE been able to shower!
12-27-2015, 03:38 PM
#327
Dazed and Confused
Hillsburgh
, Ontario
I must admit when i replaced all my plumbing with expandable Wirsbo/Uponor Pex A it took most of the worry out of freezing pipes. It would be the pumps I would worry about most. May want to add some vodka into the tank as an anti freezing component and save your pump.
Cheers
Tony
12-28-2015, 07:34 AM
#328
Foothill Ranch
I always add vodka to my black tank, but I am not sure how effective it is in it's "post user" state...
Seriously though, we are planning some trips to altitude and I would like to worry less about freezing pipes and tanks. Maybe adding tank heaters and some insulation under there is an option.
12-28-2015, 07:54 AM
#329
Richmond
, Kentucky
Just yesterday as I was removing the black water tank I found something interesting about my Argosies black and gray water tanks. The tanks are enclosed in sheet metal boxes and the boxes are lined with 1/2" white Styrofoam insulation on the sides and bottom. I did not notice this on the 310 and the 345 I dismantled.
I wonder why Airstream decided to eliminate the insulation for the tanks? It would seem to me with the insulation my Argosy is already set up for cold weather camping.
The other thing of note that was different between my Argosy and the 345 was my Argosy has 1" Styrofoam insulation between the plywood floor and the chassis. The floors of the Classic series Airstream motorhomes are made of a grid of 1" x 2" steel tubing with a sheet of galvanized sheet metal laid down on top of the grid and then the plywood (later rigs used OSB) is laid down on top of the galvanized sheet metal. The grid is open from underneath.
The Argosies had a sheet of aluminum laid down and then the grid was placed on top of the aluminum, 1" white foam board was placed inside the grid and then the plywood was laid on top of the grid. Much better approach in my opinion
Was it a cost cutting measure to eliminate the Styrofoam or did they find it to be ineffective? No matter how you look at it the Argosies were better prepared to handle the cold.
12-28-2015, 09:50 AM
#330
champaign
Number 1 on the must have list when camping in this cold is warm slippers!!! The floor is ccccold.
This morning when I checked our gauges on the control panel, the propane is still reading nearly full. My gauge has been working fine and when I topped off wed it was reading 3/4 full. It took about 12 ga of LPG to top off the tank and the gauge responded and read full. I couldnt believe we hadnt used more propane than what the control panel was telling me this morning. So, I went out and checked the gauge on the tank itself and sure enough, it read between 3/4 and full. Im really surprised we arent using more propane than that. We havent been scrimping on the furnace use either. We keep it at 65 to 68 degrees. We have the two small electric heaters going and when the sun gets going the furnace doesnt kick on real often. But from 5:00pm till sunrise the furnace kicks on regularly. I guess I expected to be using a great deal more propane.
12-28-2015, 10:22 AM
#331
Foothill Ranch
I think it's an interesting topic, this cold weather usage and worthy of its own thread!
12-30-2015, 06:33 AM
#332
champaign
We left Golden yesterday and headed north to Fort Collins. Stopped in the tiny little town of Lyons right on the edge of the front range. Its just about 30 miles from Estes Park. Heres the 310 parked on the street in downtown Lyons. "Downtown" is about a block long.
12-30-2015, 06:37 AM
#333
1995 36' Classic 36
Ludington
, Michigan
And you took up 60% of the entire town's parking spaces! 😃
12-30-2015, 06:41 AM
#334
1995 36' Classic 36
Ludington
, Michigan
The 94-95 360s have insulated enclosures for the tanks with heat ducting to them. The floors are sandwiched metal-high density foam-plywood. They stay pretty warm.
12-30-2015, 07:42 AM
#335
Richmond
, Kentucky
12-30-2015, 01:27 PM
#336
champaign
Hehehehehe yuuuuup! Ahhhhh yes, Lyons Colorado. Gateway to the Rockies. (At least thats what the sign said back in 1980, the last time I was there)
