01-22-2016, 05:24 PM
#361
1982 31' Airstream 310
champaign
01-23-2016, 08:24 AM
#362
1987 32.5' Airstream 325
dripping springs
Nice!😀👍
-Bill
01-23-2016, 08:41 AM
#363
Foothill Ranch
Nice pic! Looks so cozy. I am really impressed with your last trip, and hope to do something similar in the next couple of years. Mammoth or Big Bear is not so far from me.
01-23-2016, 10:15 AM
#364
champaign
We sure had fun. Looking forward to heading east in May. Wish it wasnt so far for you Key, especially since your contributions to the forum are so valueable. It should be an interesting and fun group at the get together.
01-23-2016, 11:57 AM
#365
Foothill Ranch
I wish too, but my plan to win the $1.6b on the lottery fell short.
Suffice to say, it would have involved a '95ish 360 pusher, so that nobody would have ever known... Live like a Billionaire, look like an average Joe.
Thanks for the compliments.. I wish I had more to show for it 5 years + in...
Your trip, and the other trips posted have proved it can be done, and have my appetite whetted. I think the "Cold weather use" thread will add some real world knowledge of what simple mods can be done to improve the comfort and reliability to our rigs!
02-07-2016, 02:05 PM
#366
champaign
Had a generator problem today. Went out and started up my propane Onan 6500 for its monthly running time. It started right up and after letting it warm up for a few minutes I put a 1500w load on it. Checked my voltage and it was great at 119. I was out there for about 15 mins doing chores and then came inside to let it run for a half hour. Went back out and the generator had stopped. Turned the load off and tried to restart and it cranks over just fine but couldnt get it to start back up. Its been running just fine, has fresh plugs, plug wires, and oil. Checked the oil level to be sure and it was good. It cranked and cranked but no fire. Sounds like its not getting fuel. Checked the plug wires to make sure they were tight, pulled the 5a fuses and they were good.....no faint smell of propane when cranking. Dont know much about these generators but its a direct feed from the propane tank and has its own propane regulator. I dont have any idea if its the original regulator or not.
Any ideas on next step? If it was getting fuel to the cylinders I would think I would smell some residue from the exhaust if it wasnt burning it up. I dont have a manometer to check pressure. Just seems odd that it would quit like that since its been running well with good voltages under load and all. I would need to drop the unit to change the points, which I have not done...I would have to take it in for that.
Any ideas or suggestions on next step that I could check are greatly appreciated...as always, thank you fellas for any help
Mike
02-07-2016, 02:12 PM
#367
Richmond
, Kentucky
Mike, if it's cold outside I'm betting the carburetor or regulator iced up. Not sure what else could cause a fuel feed problem with propane.
What's your outdoor temps right now?
1975 24' Argosy Motor Home
02-07-2016, 02:49 PM
#368
champaign
We are in a warm spell Brad, 45F
02-07-2016, 03:24 PM
#369
Richmond
, Kentucky
Well, so much for the freezing idea
02-07-2016, 05:09 PM
#370
champaign
Went out and manually worked the throttle linkage back and forth, used some spray lubricant on the linkage. Cranked it over and it eventually started, ran for about 45mins till I shut it down with no issues. Well, that was weird. Maybe my linkage was hanging up but that would be too easy. Try again in the morning. Eventually I need to bite the bullet and bring it in to the Onan service center about 45 mins from home. Have them put a new set of points in it and give it a good once over.
02-08-2016, 05:39 AM
#371
1995 36' Classic 36
Ludington
, Michigan
I believe there is a filter in system. Might have some moisture in the system that is freezing as the propane evaporates at the engine.
02-08-2016, 07:58 AM
#372
champaign
I have been trying to track that down Dave. I saw some reference to a fuel filter in reading last night. It did start this morning and its running right now but if there is a fuel filter it needs changed!
02-08-2016, 01:41 PM
#373
champaign
Well Ive exhausted my search abilities to find any specifics in regard to a fuel filter on these Onan 6.5 generators. Cant find anything specific to a filter but ran across some reference to a screen in the solenoid gas valve. My valve of course is discontinued and cant find a schematic. It is an Eaton 1014 3-b.
It started this morning and I ran it for quite awhile, so maybe the no-start yesterday after it had run for 30 mins was a fluke. Probably wont happen again until Im boondocked somewhere with low batteries .
In fact, I couldn't find much information at all about the conversion from gas to propane for our Classics.
02-08-2016, 04:59 PM
#374
Richmond
, Kentucky
Mike I know this will sound contrary but I still think you had an icing problem. From what I've been able to find while searching is if your tank is either to small or low on fuel the vapor pressure will be less and at certain times when the temperature and humidity are just right icing can occur and create the systems you experienced.
You might want to post your question on the SmokStak site. Great people and they really know generators. They've helped me out a bunch of times when I was working my Kohler generator and on a few other generators I was playing with at the time.
02-08-2016, 06:53 PM
#375
champaign
Thanks Brad. You are absolutely correct about SmokStak. Thats where I spent a good deal of time reading today. Tons of generator information and knowledge.
02-08-2016, 07:04 PM
#376
Wildwood
Mike,
I have nothing to add and really no technical ability.. But I do have the service manual and a spare propane filter in the original package with the numbers if you want the info.
Dave and Felicia
02-09-2016, 10:04 AM
#377
champaign
That would be really great!! A picture would help so I know what Im looking for......couldnt find even a picture of the filter on my Google search. Thanks so much Dave.
02-09-2016, 05:47 PM
#378
Wildwood
Filter; Onan Emerald Plus NHE (LPG)
Mike here ya go. Send me your email for more.
Dave
Dave and Felicia
02-10-2016, 04:33 AM
#379
champaign
Dave thats just great. Thanks so much. Ill send my email.
02-10-2016, 11:20 AM
#380
Foothill Ranch
Little did you know a couple of years back Dave, you would be a "Rivet Master" wading in with such good info!
Nice one!
