Originally Posted by PeterH-350LE
Yes in theory! The thought is what counts. But just in case, I gathered up the essentials. That Battery alone should scare the ... out of you
The size of that battery reminds me of an event that occurred in my youth, i.e. many years ago in a galaxy far far away....
One of my first jobs while still in high school was working at a electric motor and power tool repair shop. One day I was tasked with repairing a huge corded (cordless hadn't invented yet) electric drill with a monstrous 3/4" chuck. It was a high torque slow speed drill meant to be used by REAL men
After a little tinkering I got the drill to run again. Before claiming victory, we always had to verify the fixed tool worked under load. So, I promptly chucked up a 1/2" drill bit and proceeded to drill a hole in 1/2" plate.
In case you haven't figured it out by now what happened next, the drill bit got stuck in the hole and before I could release the trigger the drill had me wrapped up in its power cord and sprawled on the ground.
I won't say I haven't made the same mistake again over the last 50+ years but
that particular mistake has been few and far between
