The wife, her brother, and I took the MoHo for her Maiden Voyage this weekend up to Seattle for the AMA Supercross MC race. Great time. We stopped at Rife Lake (a little off the path) Fri. night, and it was a great first night.
Two things that I'd like to fix first, that I need help with:
1. I need to replace the heater core. I went to a couple parts shops, but they didn't have the right one. I might have the original core repaired, but if it's 2x as much, it makes sense to just replace it. They were all about $20, but I couldn't find the right one. I didn't really need the heat, but I did need the defrost in the morning.
2. My front left air-bag leaks, and the rear air system is totally by-passed. The compressor is missing, and the leveling system is disconnected. Right now you have to go around the coach with an air source and fill the individual bags.
the by-passed leveling system
I'm pretty sure the OEM compressor goes here.
There are air fillers at each wheel well.
2. a. How does the original air system work? I can see how it can shift air to either side to balance the load, but did it allow for lowering or raising the rear end? Could you level the coach L and R?
2. b. I'm thinking of installing a small
12V compressor, tank, and some switches so that I can manually control the airbags from the cockpit, and use it as a leveling system. (and install air horns
and an aux. air source) I'm thinking of using a system that off-roader's use for airing down tires, and airing up overload bags.
Are the front air-bags special? where do I get them? If I wanted to replace the rear airbags, where do I get those?
Thanks in advance!
-Kevin
