04-09-2018, 09:45 PM
#81
Churubusco
, Indiana
Yea, roughly the same size as ontheroadagns though, his fill is on the side instead of top so it gets extra inches. Looks like a 60 gal should fit right in.
1983 Airstream 310 Class A Motorhome
-Rob
04-10-2018, 11:54 AM
#82
Churubusco
, Indiana
So my guess is something happened to the 60 gallon tank, and someone replaced it with a readily available 40gal replacement. I see 40 gallon tanks for $180, but the only 60 gallon i see is a $500+ custom looking job.
Not sure it's worth $500 to me at this moment. The search continues.
-Rob
04-10-2018, 07:22 PM
#83
Churubusco
, Indiana
So my speedometer is totally wack, it tends to tell me I'm going approximately 170 mph.
The airstream came with a replacement, not 100% sure it's compatible. For one thing, different max speed, for another, not threaded speedometer cable.
Need to do more research. Electrical engineering is my thing, first time replacing gauges though. My default is replace with digital.
04-28-2018, 08:10 AM
#84
Churubusco
, Indiana
Finally have some time to get around to airstream maintenance!
Started with the intermittently failing front right turn signal.
My mind immediately went to the splice connectors, but after replacing i realized it's just that the bulb sockets are so corroded.
Are these still available new? They look pretty generic. I couldn't find a part number anywhere, closest I could find on ebay was the plastic lenses. My shop manual didn't seem to have the correct part number either.
I'm also gonna see if I can replace the plastic surrounds at the same time, they're about a couple potholes from turning to a pile of plastic chips
Also trying out my new wide angle lens
04-28-2018, 08:49 AM
#85
1982 31' Airstream 310
champaign
04-29-2018, 05:16 AM
#86
Churubusco
, Indiana
Thanks mayco, i saw those but wasn't sure they were right, the mounting is different. Guess I'll have to rig something up for the mounting, airstream riveted mine in. (Upside down I believe! Probably why the corrosion is so bad!)
-Rob
04-29-2018, 06:35 AM
#87
champaign
Martin found those a while ago. They look like they could work. I guess the GM part is NLA
04-29-2018, 06:51 AM
#88
Churubusco
, Indiana
And the other turn signals I ordered
https://www.ebay.com/sch/i.html?_fro...socket&_sop=15
Unfortunately, it looks like only the road side front banana wrap is available, I couldn't find the curb side anywhere. Looks like I might need to break out the fiberglass.
-Rob
04-29-2018, 06:55 AM
#89
Churubusco
, Indiana
Well, I ordered them, I'll post if they do or don't fit
-Rob
04-29-2018, 07:04 AM
#90
Churubusco
, Indiana
While I'm at it, checked for the rear tail light bezel, looks like those are also NLA, darn
-Rob
04-29-2018, 07:06 AM
#91
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Brad installed GM# 916558 on Peanut, and they are still listed on eBay
https://www.ebay.com/itm/Chevrolet-G...AAAOSwhiZaVURo
04-29-2018, 08:26 AM
#92
Richmond
, Kentucky
Originally Posted by martin300662
Yeah, these are exact bolt in replacements identical to the originals.
I opted not to rivet the replacements back in place. Instead I made some U shaped brackets to hold them. I'll post pictures when I get home next week.
04-29-2018, 09:01 AM
#93
champaign
Bad information on my part, sorry about the that. Good to see they are available.
04-29-2018, 09:05 AM
#94
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
More likely that I found some the looked the same when searching previously!
05-06-2018, 02:12 PM
#95
Churubusco
, Indiana
Got some camping in this weekend!
Also a 60 second project, closet light auto shutoff switch, works like a charm!
05-06-2018, 07:07 PM
#96
_
, _
I'm jealous, I really wish I had a 310 instead of the 280.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
05-06-2018, 08:01 PM
#97
Churubusco
, Indiana
We like it, the rear bed layout was a requirement when shopping
05-06-2018, 08:08 PM
#98
Churubusco
, Indiana
The polishing begins!
Fixing a leak above the door, the whole area is dried out sealant.
Previous owners sealed the drip rail with generic double sided tape stuff, it wasn't up to the job. This is the first thing I'm resealing, any opinions on what's the best way to seal that? Butyl tape, or a thin bead of trempro before screwing back down?
05-07-2018, 04:32 AM
#99
Richmond
, Kentucky
The double side tape is factory. At least all the windows and trim pieces that I've removed have had double sided tape on them.
1975 24' Argosy Motor Home
05-09-2018, 05:18 PM
#100
Churubusco
, Indiana
Huh, wouldn't have expected that, shouldn't be surprised though
Finished sealing that all back up yesterday, cleaned some of the excess today, pretty happy with the results!
A set of cake decorating fondant balls helps make a nice bead when wet, and provides an easy line for cleanup
