10-13-2020, 03:06 PM
#741
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by Magnet18
Just checked again, the flash makes it hard to see in the picture. The output shaft is threaded, and the yoke has a lip for a washer to seat on, and you probably throw some black rtv on for good measure
for comparison shaft thread on the 4l80e. The bolt needs to be grade 8 or 10.9 if metric with red locktide torqued to 82 ftpounds.
I just cant imagine not having a bolt there. You better have a solid first hanger bearing in place or you will have have all kind of wobble not to mention a distorted spline shaft.
AIR #13
10-13-2020, 03:35 PM
#742
Churubusco
, Indiana
We're on the same page Peter, it won't be going back on without a bolt!
10-13-2020, 03:42 PM
#743
Airstream Driver
1994 30' Excella
Austin
AIR #13
10-13-2020, 03:58 PM
#744
Churubusco
, Indiana
Thank you Peter! Saved me some time
10-13-2020, 05:38 PM
#745
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Got my box of window seals today, appreciate you selling them to me. I don't have to hunt for what I need now (hallelujah). I can now start on the windows if the weather cooperates. Already changed out the little rusty screws with stainless, glad of that what a nightmare.
10-13-2020, 05:52 PM
#746
Churubusco
, Indiana
Glad it arrived safe, best of luck!
You'll still need some vertical lip seal, but that'll get you started. If you've gotten the screws replaced without breaking any you're already well on your way!
10-13-2020, 06:35 PM
#747
Airstream Driver
1994 30' Excella
Austin
Rob, for your own peace of mind, I would closely inspect the shaft and yoke splines. To get a properly fitting yoke on the shaft, you often have to use blunt force, like a 2x4 or a Rubber mallet. I once spent an hour counting splines, because it seemed they were not lining up properly. (There are 32 btw )
AIR #13
10-13-2020, 09:49 PM
#748
Churubusco
, Indiana
Thanks Peter, will do!
1983 Airstream 310 Class A Motorhome
-Rob
10-13-2020, 09:55 PM
#749
Churubusco
, Indiana
Anyone have a good part number for the Transverse Rod Bushings?
The number I find here on airforums in this thread is
7572-102 Transverse Rod Bushing
I get exactly zero hits for that part on google though
good diagram of the system in the attached pdf
-Rob
10-13-2020, 10:00 PM
#750
Churubusco
, Indiana
Also, while I'm down there, what should be looked for to see if the leaf springs and other suspension components are still any good? I haven't seen much about the rest of the rear suspension failing.
-Rob
10-14-2020, 01:00 AM
#751
Airstream Driver
1994 30' Excella
Austin
The company to get the parts is no longer ACE or ACS, its Superide now
559-441-1460
Bushings 7572-102 ~$14 ea
Straddle Pins 5506-001 ~23 ea
https://www.airforums.com/forums/f15...ml#post2369270
AIR #13
10-14-2020, 01:02 AM
#752
Airstream Driver
1994 30' Excella
Austin
https://www.airforums.com/forums/f15...ml#post2224385
AIR #13
10-14-2020, 07:09 AM
#753
1982 31' Airstream 310
Tulsa
, Oklahoma
I installed my GVOD on the TH475 transmission and mine has the bolt and washer holding the drum on. Dave
10-14-2020, 07:20 AM
#754
Churubusco
, Indiana
Thanks Peter, you're bailing me out repeatedly here!
Looks like the original springs had 10 leaves (or is that 9/1)
What I'm seeing for replacement is
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=7394
Or.
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=7395
That's regular 3760lbs or heavy duty 4500
Given that ours are cut in half and we have the airbags, and it's an extra leaf over what the 310 had, it looks like the regular makes more sense to me
10-14-2020, 07:33 AM
#755
Airstream Driver
1994 30' Excella
Austin
I just know too well how it goes. If it wasn't for Brad and Chris, I would have thrown in the towel a few times in the past (well, at least for an hour or so)
Chris (cmadmaxman) would probably be a better source for info on the leaf springs. I have fortunately never messed with them
AIR #13
10-14-2020, 07:43 AM
#756
Churubusco
, Indiana
I'll send him a PM and see if he responds. I was hoping to leave mine, but when they bow down instead of up... I figure ignoring it is asking for trouble. If I replace them at least the entire suspension will be new, front and rear.
10-14-2020, 10:26 AM
#757
Churubusco
, Indiana
Chris said he ordered the 4500lb units, and they were too thick, he had to remove a couple leafs.
He recommended checking the pack height measurement, which makes perfect sense but hadn't crossed my mind, I'll take that measurement this evening
-Rob
10-14-2020, 11:17 AM
#758
Churubusco
, Indiana
Bearings on the way
ACDELCO 290280 (290-280) Wheel Seal
TIMKEN SET45 Wheel Bearing inner set
TIMKEN 15103S Wheel Bearing outer bearing
TIMKEN 15243 Wheel Bearing outer race
10-14-2020, 11:35 AM
#759
Richmond
, Kentucky
Rob, on my old 310 the leaf springs were cut off and the suspension action occurs with the air bags. I might be missing something but that means the remains of the leaf springs are nothing more than a pivot point for the suspension system.
Would it matter if the springs bow one way or the other?
What am I missing?!
1975 24' Argosy Motor Home
10-14-2020, 12:00 PM
#760
Churubusco
, Indiana
What am I missing?!
Brad,
I'll need to look at it again and think it through, not a mechanical engineer, but I thought it looked like you still get some spring action, since the axle is constrained against rotating when it goes up and down, if I'm picturing it right in my head, which I may not be
