Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-03-2019, 08:57 AM   #621
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by mayco View Post
I see now. If tambour doesn't suit your needs, you could kerf out a section of 1/4" thick plywood. Just kerfing out enough to make the bend, and running your kerf "with" the grain of the exposed veneer of the ply. I would do it on a table saw and set the blade at 1/8" high. I think you can buy kerfed plywood but I couldn't find it on a quick search. I know I used it on a job years ago...very floppy and bendable.
Mike
I was trying to kerf 1/4" ply for a few hours on Sunday but it wasn't working out. I think the problem may have been cheap wood, any minor warp was changing the depth of cut significantly enough that it would want to crack at that location, even after soaking.
I picked up a sheet of better looking 1/4" Luan yesterday, will give it another shot
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 09-03-2019, 10:41 AM   #622
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You probably already know this but make sure your kerf "grooves" run WITH the grain of the exposed side. Plywood axle strength is against the grain, like laying subfloor in a house is perpendicular to the floor joists. It will bend with the grain if laid parallel. In your case, you want the bend.
mayco is offline   Reply With Quote
Old 09-03-2019, 01:57 PM   #623
mayco's Avatar
Oh geeeeezzzzzz, senior moment. Should read “strength axis......”
Old 09-03-2019, 02:48 PM   #624
Magnet18's Avatar
No worries, I got ya!
Seems like it majes it more prone to breaking though, correct?
-Rob
Old 09-03-2019, 02:53 PM   #625
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Maybe I am over simplifying but can't you just use a radius-ed corner finisher similar to used in kitchen cabinetry?
Its just a very large quadrant milled section, you can see it on the island counter in the picture below.
martin300662 is offline   Reply With Quote
Old 09-03-2019, 03:58 PM   #626
mayco's Avatar
It makes it more bendable as opposed to trying to bend it perpendicular to the grain. If you took a 3' square piece of ply and set the ends on concrete blocks, then step on it in the middle, you would notice the difference depending on which way the grain is running.
Old 09-03-2019, 04:05 PM   #627
mayco's Avatar
Attachment 351225
I'm not sure Martin, we need Tony to chime in....I am a retired "carpenter" who built structures not cabinets, while Tony is a true cabinet maker. We both worked with wood but big difference in skills and knowledge. I could build you a house while Tony could furnish it
Old 09-03-2019, 08:31 PM   #628
Magnet18's Avatar
Attachment 351225
That's exactly what I'm trying to do, and the simpler the better!
Not sure why that never crossed my mind
Can i buy it at orange/blue/green hardware stores?
Tried searching and didn't find, maybe I don't know the right keywords?
-Rob
Old 09-03-2019, 08:33 PM   #629
Magnet18's Avatar
Indeed, I'm waiting for Tony to chine in and shame us all any minute
-Rob
Old 09-03-2019, 10:58 PM   #630
Keen amature
1975 20' Argosy 20
Chestfield , Kent
It's not exactly helpful, but in the UK I can walk into any kitchen cabinetry/joinery outlet, not the generic big box stores, and pick up that part.
They come already matched to the kitchen cabinetry finish/quality
Old 09-04-2019, 03:40 AM   #631
,,,,,I could build you a house while Tony could furnish it
Cool!!! When can you start?
1975 24' Argosy Motor Home
Old 09-04-2019, 08:18 AM   #632
Keen amature
1975 20' Argosy 20
Chestfield , Kent
In Sedona? Looks quite a nice place!
Old 09-04-2019, 10:02 AM   #633
Sedona? Not for me, more like southern Colorado or Northern New Mexico
Old 09-04-2019, 10:36 AM   #634
Keen amature
1975 20' Argosy 20
Chestfield , Kent
With two car ports to keep the rain off?
Or isn't there any rain in southern Colorado/New Mexico
Sorry Rob, please have your thread back!
Old 09-04-2019, 11:25 AM   #635
Magnet18's Avatar
Sedona looks nice, as does southern Colorado
Weather depends greatly on elevation and microclimate, i would definitely go for somewhere alpine, skiing in the winter, hiking in the summer
Not a lot of rain I hear, but hail is a risk depending on the location, definitely want to keep that off the airstreams
-Rob
Old 09-04-2019, 12:39 PM   #636
Magnet18's Avatar
https://www.woodworkerexpress.com/Radius-Moldings/
They are MDF but it looks like one of these might work if I get the proper radius measurements (which I will also need if I go to a cabinet shop)
-Rob
Old 09-04-2019, 08:48 PM   #637
Magnet18's Avatar
So I did what I normally do when I have no idea what I'm doing... Wander around the hardware store aimlessly until something jumps out at me
Being a jack of a couple trades and a master of none (at least none relevant here). I grabbed a piece of double wall vent pipe that looked about the right size.
The outer wall was thicker gauge steel, which would probably work better, but i don't have the tools on hand to properly work
The inner wall, however, was both about the right size, and aluminum
I think it'll work!
ID:	351341   Click image for larger version
-Rob
Old 09-05-2019, 06:37 AM   #638
mayco's Avatar
Hahahahaha, nice work Rob. Field expediency!
Old 09-09-2019, 09:13 PM   #639
Magnet18's Avatar
Chuggin along when I get the chance
-Rob
Old 09-10-2019, 12:09 PM   #640
mayco's Avatar
That corner turned out great
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 05:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 09:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 05:01 PM
