Old 01-25-2015, 10:43 PM   #1
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Lug nut covers?
Hi all,
I would like to replace all my lug nut covers. I ordered some Wheel Master 1", but they don't quite fit...too small, and the flange on the bottom was not large enough. Any ideas and good pricing.
Thanks, Sebas
SebasSF is offline   Reply With Quote
Old 01-26-2015, 05:14 AM   #2
r carl's Avatar
Lin , Ne
Best for less.
20 Mcgard Lug Nuts Bulge Acorn 1 2 Chrome Chev GMC C10 No Rust | eBay
Old 01-26-2015, 06:10 AM   #3
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Here are factory original lug nuts that came on my '07 -- split, bent, rusted and corroded after just a few years. Airstream's cheap lug nuts will leave you unable to change a tire when you need to in the worst way. I replaced them with the beautiful McGard lugs that R Carol recommends, which are solid steel and guaranteed forever. But will the McGards fit SeBassSF's wheels? Dunno.
JBinKC is offline   Reply With Quote
Old 01-26-2015, 06:31 AM   #4
SteveH's Avatar
Common Sense , Texas
I recently bought some new tires at Discount Tire, and when I asked them to be careful with the lug nuts, they took one look at them, and gave me all new chrome lug nuts at no additional cost.
Can't beat Discount Tire IMHO.
Regards,
Steve
Old 01-26-2015, 08:19 AM   #5
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Another happy McGard customer here. Their products are very nice on our TT. Good customer service, too. I bet that if you contact them they will help you pick out the right ones for your RV.
Rocinante is our 2014 International Signature 27FB
Old 01-26-2015, 09:35 PM   #6
SebasSF's Avatar
Thanks for the ideas folks. I have 10 lug Alcoa rims. I'll check out the recommendations.
Old 01-27-2015, 09:57 AM   #7
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
If you go on Ebay and search 1 1/16 inch nut covers I think you will find them. The nut covers on my coach are the same size
shepherd57 is offline   Reply With Quote
Old 01-27-2015, 10:28 AM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have a new set of Mcgard lug nuts. Problem is I can not get any of my lug nuts off. Either they are on too tight or the caps just spin. I guess I am going to have to take the trailer down to my local heavy truck and trailer tire shop.
MICHAEL
Old 01-27-2015, 10:31 AM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Lug nut covers?
Have you checked to see if a 6 pt. metric size might be a better fit? Tap it on, remove and tap it out, throw em away.
When I replaced I bought Guerrilla brand very nice.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-27-2015, 12:24 PM   #10
AWCHIEF's Avatar
Images: 33
Believe me I have tried every wrench size and shape available, standard and metric and even some English standards left over from my MG racing days. They were put on by the shop I am taking it to by one of there guerrillas with an air tool.
MICHAEL
Old 01-27-2015, 12:48 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Don't replace the covers, get solid lug nuts to replace the whole thing. I started having trouble with one a couple of years after we bought the trailer. At first I thought the lug was loose since the cover rocked a bit when I tightened it. That's when I found out they were just cheap covers over the nuts—another way Airstream saved a little bit of money and angered customers of their "premium trailers".
I wish I had been at Discount Tire when it happened because new lug nuts cost a lot at the local aftermarket parts store. Since I got tired of being ripped off there, I spotted shopping there since they had a similar business model to Airstream—charge whatever you can get away with.
I think Michael's shop overtightened the covers causing the inside to wear down and spin. Since a bunch of them seem to be spinning, it sounds like an air tool gone crazy. I'm not sure of the torque on those, but before '08 it was probably 120 lbs. They may have to be drilled out, no fun.
Gene
Gene
Old 01-27-2015, 02:00 PM   #12
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I wrecked a cover within a week of taking ownership of my new trailer, re-torquing the lugs as directed in the Airstream manual for new aluminum wheels. Since then I bent and pulled off two more flimsy covers. The wheels started looking trashy so I just replaced all 24 of them with these solid steel chrome plated lug nuts for $21. Now they look great!
Amazon.com: DPAccessories D3112-HT-2305/24 Wheel Lug Nut: Automotive
kscherzi is offline   Reply With Quote
Old 01-29-2015, 05:15 PM   #13
AWCHIEF's Avatar
Images: 33
Success, the shop where I was going to take the trailer to get the nuts swaped suggested I run by Harbor Freight and pick up a set of impact wheel sockets ($10.50 after 20% off). Did that. Along with a 5 ft length of black pipe to use as a giant breaker bar they worked as advertised. Wheels now have shinny new solid lug nuts and are properly torqued to the recommended 120 lbs.
MICHAEL
Old 01-30-2015, 05:21 PM   #14
SebasSF's Avatar
Ok, so I just need to figure out what size McGard lug nuts I need for my motorhome.
Lug nut covers russ240 Sprinter and B-van Forum 27 03-07-2017 07:34 PM
Wheel / Lug nut covers bkahler Classic Motorhomes 3 04-13-2008 12:10 PM
lug nut/bolt question.... Kistler Wheels, Hubs & Bearings 13 01-25-2006 02:15 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
