Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 07-25-2007, 06:43 AM   #1
philippes
philippes's Avatar
Profile:  Cincinnati , Ohio
Lower Compartments - orientation of locks
Do you know how should be orientated the locks for the lower outside compartments. It seems that I have all possible combinations. In closed position, some are horizontal, some are verticl. In order to open them, some are rotated clockwise and some counterclockwise. What was the factory standard?
Philip
philippes is offline   Reply With Quote
Old 07-25-2007, 09:33 AM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
The type of lock used on these compartments can be oriented as you wish. You can easily remove the lock and invert it and also invert the lever. It will then operate the opposite way.
When these locks are installed at the factory, it can go either way as the lever can be flipped to perform the locking function.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 10:20 PM
Storage Compartment Locks Jim Clark 1968 Globetrotter 13 06-25-2006 07:40 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
Door Locks on older MH thenewkid64 Airstream Motorhome Forums 3 03-05-2002 06:27 AM
