Old 10-23-2012, 12:31 PM   #1
SteelyDan's Avatar
1982 31' Airstream 310
Portland , Oregon
Lost ignition key, best solution?
Hey Friends,
Somehow, someway, the ignition key to Steely was lost. Whats the best solution to replace it? Is it relatively simple to replace the tumbler? In my experience working on some older vehicles, the wires going to the tumbler are armored with steel.
Any help is much appreciated!
Cheers!
SteelyDan is offline   Reply With Quote
Old 10-23-2012, 01:41 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Call a good locksmith.
Some can make a key without an original......
A call to Jackson Center with the VIN might yield a key code? A long shot no doubt, but you never know.
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-23-2012, 02:19 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I would vote for the locksmith. I have spare keys, but looking under a microscope, I see no numbers. You do NOT want to get into the rat's nest! If all else fails, I'll be glad to send you one of my spare keys, who knows? It may fit!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-24-2012, 11:00 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Locksmith...Mike L is absolutely correct about the rat's nest...I pulled my dash loose just enough to realize what a tangle is back there(and the wires are a very thin gauge), and very carefully reinstalled the dash...we used a locksmith familiar with older mohos...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-24-2012, 11:14 AM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I would take a flashlight check all the places you or PO hid a spare(all outside storage).
I found one in the Generator compartment after owning about two years :-)
Good Luck,
Dave
Old 10-24-2012, 04:30 PM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
The following information may or may not help.
I lost the key on an older pickup this year. Went to the trouble underscore trouble of removing ignition tumbler. Took tumbler to local locksmith, they said can do. Picked up new key, it sorta worked. Tried it and just decided, nope not good enough.
NEW IDEA, remove the door lock, very easy to do compared to ignition tumbler. Took key and door lock back, locksmith smiled said this is a cinch now. With the ignition tumbler, they had to "feel" the pins and make the key, with the door cylinder they could take it apart easily and make the key. They missed by one position on first try, nailed 2nd try.
Your results may be different.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 10-24-2012, 05:32 PM   #7
SteelyDan's Avatar
Portland , Oregon
Thanks for the suggestions! I'll find a good locksmith.
Old 10-24-2012, 06:37 PM   #8
It is a Chevy square headed standard style key.
The barrel has a code number on it, but need the key to turn it to position two, then use a pin or wire to release the barrel..
I heard that if you take the VIN number and proof of ownership that your Chevy dealer can order you a key... assuming that the ignition lock is the original. Call them... worth a try!
I did this with my 1984 Mercedes, and it was a slamdunk!
Old 10-24-2012, 07:21 PM   #9
crazeevw's Avatar
Saint Petersburg , Florida
Practically any locksmith will have a book of codes from all manufacturers. With you VIN number (Chevy, not the Airstream) contact local locksmith. Hope by the time you read this, you've been able to obtain your new key. Then, GO MAKE LOTSA copies......
Thanks, Derek
