04-05-2019, 03:34 PM
Huntington Beach
Looking for Wheel Well trim, and a Part of a lower Z Rip
Hello,
does anyone salvaging an Airstream or knows someone who has a few parts?
I'm looking for wheel trim wells (2, single axle, apparently they are all the same front and rear) and a piece of the Z rip (lower end passengers side) where the outside skin is riveted too. I need to repair some damage.
Thank you very much
04-05-2019, 05:58 PM
Richmond
, Kentucky
What model? What year?
04-06-2019, 02:12 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Originally Posted by clemensk
Hello,
Thank you very much
As Brad said, what year, what model?
They aren't all the same, as some models had 16.5" diameter wheels, some 19.5" so the wheel wells are different sizes.
04-08-2019, 02:38 PM
Huntington Beach
My mistake. I thought they are all the same. It is my 1982 310 with 19.5 wheels.
04-08-2019, 04:05 PM
1982 31' Airstream 310
champaign
First of all, you have the only other '82 310 Ive seen here on the forums, woooohooo.
I replaced the rear passenger side wheel well trim on mine. It came from a different year and may have been off an Argosy. Bought it off a fellow member here. It was not an exact replacement and I ended up having to cut it and piece it together. It turned out great though and you wouldn't see the joint unless I pointed it out to you. Anyway, there is an inner and outer piece to the trim. I was able to use the existing inner piece and only replaced the outer. You install the inner piece first and then the outer goes over it. The length and bend of the trim varies as to the model. So as you look for a replacement, be sure to know if you need both pieces or just one (outer).
04-09-2019, 08:40 AM
Henniker
, New Hampshire
Only if you ignore my '82 310!
1982 310 motorhome 502
Henniker New Hampshire
04-10-2019, 06:54 PM
champaign
Didn't notice that Chief
