Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 06-05-2007, 08:26 PM   #1
Looking for a seat control switch
Our 84 310 came without the passenger side seat control switch. I've attached some pics of what the drivers side looked like.
Anyone out there know what vehicle these might have been used in besides an airstream? I've browsed the web and as near as I can tell they might be a mid 80s Chevy product but I've yet to see one that looks exactly like it.
I'd like to find at least one and possibly two.
Or is there a substitute out there that would work?
Any help would be greatly appreciated
Name:	310-seat- control-1.JPG
ID:	38722   Click image for larger version
Name:	310-seat- control-2.JPG
Name:	310-seat- control-3.JPG
1975 24' Argosy Motor Home
Old 06-06-2007, 02:38 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
You can have the two off of my coach, I think they work OK. The motors in the power bases died and the new power bases are set up for different controls. PM me with a mailing address if you want them.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-07-2007, 09:52 PM   #3
Guy99, PM has been sent. Thanks!
Old 07-02-2007, 09:10 PM   #4
seat switch
I also lost th function of two motors on the passenger seat and wondered if the switch shown in your picture is the problem. Let me know if it gets yours working and I will attempt to find another one.
mlmarch is offline   Reply With Quote
Old 07-02-2007, 11:34 PM   #5
guy99's Avatar
Images: 16
More likely that the motors have shorted (at least that's what happened to mine).
Old 07-03-2007, 05:41 AM   #6
We verified the motors on the passenger seat by moving the drivers switch to the passenger side. Once I determined the motors were good I started looking on the web for the correct switch assembly. On our 310 the switch AND the housing were missing. Guy99 kindly supplied us with replacement switches and housings from his MH. Moving the switch from drivers to passenger side is real easy, 2 screws and then pull the switch connector from the switch.
In my searches I did find that the switch itself seems to be a mid 80s GM product easily found on ebay. I never did find what the chrome housing was used on.
What I would suggest is try moving the your working switch to the other seat to determine whether its the motors or the switch that is bad. Of the two switches I got from Guy99 one was good and one was bad. If its the switch then check ebay for a replacement.
Hope this helps.
Old 07-24-2007, 02:34 PM   #7
1985 34.5' Airstream 345
Fishers , Indiana
The switch you are looking for is a "Standard Prof. Quality Automotive Parts" DS321 Power Seat Switch which can be gotten at most auto parts stores or on eBay. This switch was used on many models of cars and trucks in the 1980's from both GM and Ford.
Wayne Olson is offline   Reply With Quote
Old 07-19-2015, 03:13 PM   #8
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Found this old post from Brad looking for the electric seat control switch.
Anyone seen any replacements?
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-19-2015, 03:21 PM   #9
Peter, it's a Ford product.
Get this one while he gettin's good!
Thunderbird switch
Old 07-19-2015, 05:05 PM   #10
Airstream Driver
1994 30' Excella
Images: 49
Can't believe you found 2, I looked all over ebay AND in the meantime, I took the old apart and actually managed to fix it.
But thanks, probably get it for a spare
AIR #13
Old 07-19-2015, 05:07 PM   #11
Actually I found more than two I just didn't list the others
What did you find wrong with the switch?
Old 07-19-2015, 05:30 PM   #12
Airstream Driver
1994 30' Excella
Images: 49
the forward motion did not work. I found a plastic part inside that switch to be broken. I used a special plastic bonding system from loctite
to glue it back together. Since it was a 4-way switch, I rotated it 90 degrees internally to use the unbroken plastic part for the back and forward motion and the repaired part for the less used left and right motion. And it worked, imagine...
AIR #13
Old 07-19-2015, 05:37 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The both of you watched MacGyver over and over again didn't you.
Goodwork, Cheers
Tony
Old 07-19-2015, 05:59 PM   #14
Airstream Driver
1994 30' Excella
Images: 49
Goodwork, Cheers
Tony
Pssst, Brad last name is MacGyver...
AIR #13
Old 07-20-2015, 07:11 AM   #15
Good job on fixing the switch! I've got one switch that came out of the 310 that's not working. I think I'll dig into it and see if I can do the same thing.
In my spare time of course....
Old 07-20-2015, 07:13 AM   #16
That's just wrong on so many counts
Old 07-20-2015, 07:14 AM   #17
Peter, did you buy the switch on eBay?
Old 07-20-2015, 03:05 PM   #18
Airstream Driver
1994 30' Excella
Images: 49
Yes, thanks for the link
AIR #13
Old 07-20-2015, 05:54 PM   #19
Good
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
Control indicators smily Electrical - Systems, Generators, Batteries & Solar 10 01-16-2007 08:09 PM
Ultrasonic Pest Control Cracker Our Community 5 04-19-2004 12:50 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
