Old 02-25-2015, 10:56 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Lock n Lube
http://www.amazon.com/LockNLube-Grea.../dp/B00H7LPKKU
Has anyone used one of these or something similar? Im thinking about the water pump on the 6bd1.
Mike
mayco is offline   Reply With Quote
Old 02-25-2015, 12:30 PM   #2
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
I don't think there is enough space to get that in I can hardly get my finger in there.
On another subject are you still looking for the wheel well trim
shepherd57 is offline   Reply With Quote
Old 02-25-2015, 01:18 PM   #3
mayco's Avatar
Yes I am. Its a two piece trim apparently. Thought I had one but it fell through.
I was wondering if that gizzmo might be too large to get it in there. Ive never attempted to grease mine with everything put together. I gave it a good shot when I had the front end broken down all the way to the pump.
If youve got a line on that trim I would be interested. I did find it new on some web site, I hope I saved it. Good thing the other deal fell through cause come to find out I could order it new for less than the guy wanted for the salvaged one. I got distracted with other stuff in the mean time.
Mike
Old 02-25-2015, 02:25 PM   #4
shepherd57's Avatar
Lindsay , Ontario
I have a 28 Argosy that I am parting I think it is the same size, I don't know how much they are new. I will be going to Sturgis SD in Aug if you are not in a rush. I could swing your way so I don't have to go through Chicago
Old 02-25-2015, 03:06 PM   #5
mayco's Avatar
That would be really great. I think they measure the same but Im not sure if the Argosy is a single piece or two piece like the 310. The 2 pieces cost about $45 bucks each new. So for that kind of money I wouldnt want you to make a special trip to swing through unless you just wanted to avoid Chicago to our north..we are about 120 miles south of the city. But I would certainly be delighted if it worked for you. My to do list on the 310 never seems to get shorter, knock one off add two. So not in any hurry.
Are you going to drag Tony along to Sturgis? Nawwwwwwwww
Thanks and just keep me posted.
Mike
Old 02-25-2015, 07:33 PM   #6
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mike
That thing will not fit in the space. My fitting was damaged so when I replaced it I put a 45 degree fitting back and it's much easier to grease.
Cheers, Dan
~ Margaret Thatcher ~
Old 02-26-2015, 05:32 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mike
Just as well...the last time a crazy Brit went south to the U.S your precious White house went up in flames circa 1812.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-26-2015, 07:21 PM   #8
Dazed and Confused
Isuzusweet's Avatar
I'm going to apologise for my previous post, bad form no excuse, my bad.
Cheers
Tony
Old 02-26-2015, 08:13 PM   #9
2007 22' International CCD
Still funny.
Rich, Two peoples separated by a common language.
KE4GNK/AE
Old 02-26-2015, 08:38 PM   #10
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1425008289.184734.jpg
Top-end Diesel Lube IndyAnne Tow Vehicles 16 12-10-2009 09:52 PM
Vent riser lube walter1 Roof Vents, Skylights & Fans 2 08-18-2007 02:16 PM
lube for door hinge? edwmart Doors & Locks 7 07-07-2006 04:01 AM
How do I lube the tongue jack 63air Jacks, Stabilizers, Lifting and Leveling 4 06-29-2006 10:32 PM
window crank lube Jabba Windows & Screens 7 06-08-2006 08:22 PM
