Old 12-05-2006, 08:53 PM   #1
1981 27' Excella II
1981 28' Airstream 280
kountze , Texas
lighting
hi looking for info on how to change bulbs behind clear plastic panel overhead of 1981 280 excella joboy1
joboy1 is offline   Reply With Quote
Old 12-05-2006, 09:18 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
What type?
Joboy-
Welcome to Forums.. As new member, you should continue practicing using the "Search"tab above in blue bar.. Try clicking on it, and typing in words with a space between like: light fixture bulb change and see what you get back...
As for your specific, you don't say whther unit is flourescent or small incandescent bulbs.. Most of the plastic covers have tabs (breakable if plastic gets brittle..) that can be released by pressing in from one or two edges.. Without a picture or better description, it is hard to offer more specific advice...
If you still had owner manual, the process is described there for your fixtures.. If not, you can search here ( owner manual replacement ) and find two sources of replacement manuals, which are handy things to have around..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 12-06-2006, 11:54 AM   #3
1983 30' Airstream 300
Plantersville , Texas
Very carefully.
The frosted panels on our overhead lights were hard to remove. They just need to be compressed from the side and lowered. It helps if they are warm.
I was afraid they would break if I pryed on them. I applied a small amount of pressure with a screwdriver and was lucky when they came out without cracking. Mine use a tail light double filiment bulb as they can be bright or soft light. Hope this helps and Good Luck. I have an 83 Classic 300.
Kay
carnegie1935 is offline   Reply With Quote
Old 12-06-2006, 05:57 PM   #4
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
still trying to get ours out
same information from everyone though, get them warm and pry them out with screwdrivers. I have tried a few times but they have not popped out and I am afraid to break them. We were advised to keep the lights on, squeeze from the sides and pop the ends with screwdrivers. Our bulbs are fine, we just want to get the dead bugs out!!!
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 12-09-2006, 07:31 PM   #5
1981 27' Excella II
kountze , Texas
nx for the help! every one. jojoy
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 07:00 AM
Gas Lighting kzener40 General Interior Topics 4 11-06-2002 01:43 PM
Interesting lighting site FrankR Lights - Interior & Exterior 1 09-13-2002 12:22 PM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 11:13 AM
Lighting problems ramoore53 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2002 11:02 AM
