Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-15-2008, 02:11 PM   #1
swinginping's Avatar
Profile:  waynesboro , Virginia
Lifting a 345.
Finally got my rear airbags, i know some of you have replaced air bags in the past.... bottom bolts are easy of course..however the tops one are the tricky ones, i know you must lift the moho to get the old bags out and new ones in, but where is the best spot to jack it up at, and are there any secrets to gettin the top bolts out???
1989 345LE
swinginping is offline   Reply With Quote
Old 05-18-2008, 12:18 PM   #2
M Hohnstein
Profile:  germantown , Wisconsin
I use a ten ton floor jack placed under the differential center section. The frame is supported by 4 jack stands placed on the chassis frame rails in front of and behind the tag axle. I lift the front under the cross member and place two jack stands ajacent to front levelers. Speaking of levelers, I moving my rear jacks to the space between the rear axles, as the present location in front of the drive axle is too far forward for effective use. This mod will require moving the air tank forward. Hopefully you have a level cement pad to work on for saftey reasons, both you and the motor home. Pay close attention to the coach frame members fabricated from 2 inch square tubing. Mine are rusted out over the axles, replacement is imminent.
M Hohnstein is offline   Reply With Quote
Old 05-18-2008, 07:07 PM   #3
Profile:  1973 25' Tradewind
Romulus , New York
Take the top bolts out first
jayray5 is offline   Reply With Quote
Pingbacks are On
Lifting my 2007 flint Jacks, Stabilizers, Lifting and Leveling 5 03-29-2008 03:41 PM
Lifting my '64 Tradewind campngirl Jacks, Stabilizers, Lifting and Leveling 2 06-14-2007 08:14 AM
lifting a trailer fanerd Jacks, Stabilizers, Lifting and Leveling 1 09-12-2006 01:08 PM
Window lifting arms/gearbox Walker's Wanderer Windows & Screens 2 03-25-2004 07:46 AM
Window Lifting Arm Repair Davydd Windows & Screens 9 08-22-2003 07:23 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
