Old 03-20-2015, 08:11 PM   #1
morlach's Avatar
Let's Talk About Cruise Control in Classics
I have a 325 Classic 454ci P30. It has a cruise control in it, but it does not work. I am thinking that it would probably be simpler and more effective in the long run to just replace the system. Thoughts? Repair or replace. Bear in mind that I do not yet know exactly what is wrong with the existing one.
morlach is offline   Reply With Quote
Old 03-20-2015, 10:11 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I bought a control unit from Rostra. It is all electric and replaces the vacuum unit. The original control and speedo pick up work with it. All I had to do was mount it and connect it to the throttle linkage and connect the wires.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-21-2015, 10:30 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Mine is also a Rostra after market.
mayco is offline   Reply With Quote
Old 03-21-2015, 12:23 PM   #4
Redwood City , California
I have the original vacuum cruise control and it worked fine until about a year and a half ago. I would like to get it working again. There's no money for me to replace it and with the limited miles I drive it, replacing it would not be feasible. I was hoping it was just a fuse but no luck.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 03-22-2015, 11:55 AM   #5
1977 31' Sovereign
Lynnwood , Washington
I presume youi're talking mid-1980's vintage.
If it is, the transducer is usually the culprit. There's two speedo cables that attach to the transducer: one goes to the transmission; the other goes to the speedometer.
Transducer can be sent to a speedo shop for repair. Or, remove transducer and liberally apply WD-40 to both speedo cable connections.
Tom
TomKirk is offline   Reply With Quote
Old 03-22-2015, 01:21 PM   #6
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Your CC is probably repairable. That vintage is pretty basic, made up of components that you can likely find on eBay. Here's a piece from eBay that identifies the components and gives you some ideas on troubleshooting. The vacuum motor is easy to troubleshoot by any repair shop with a simple vacuum pump.
How to Test Your Cruise Control | eBay
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 03-23-2015, 09:17 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I found a control module/black box for a 1995 G20 van in a junk yard that fixed the cruise control, but that was in 1999.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Let's talk about Amazon some more... AIR-Quarius On The Road... 16 01-05-2015 03:05 PM
Let's talk Boundary Waters Caryl On The Road... 42 08-05-2009 12:05 PM
Let's Talk Batteries IrishRover2 Batteries, Univolts, Converters & Inverters 58 04-02-2007 01:24 PM
