Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 06-20-2006, 03:39 PM   #43
Whipsas270's Avatar
Profile:  Benbrook , Texas
Sequential turn signals
The sequential turn signal is a cool idea. Ford put them on both the Mercury Cougar and the Thunderbird in 1967 and 68. OH BOY another trip to the junk yard!
Every day is a holiday!
84 Excella 270
95 1100 ACE
Whipsas270 is offline   Reply With Quote
Old 06-20-2006, 04:05 PM   #44
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
I was thinking about replacing the backup light with an amber lens and making it my directional. Seems like two marker/brake lights and one amber turn would be more visible. Since the MoHo has big backup spots on it lower down,
BTW - I gto this idea sitting behind a school bus. Hard to miss those big amber led signals
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 06-20-2006, 08:57 PM   #45
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
LED lens need changing
I tested the new LEDs tonight and found the Airstream lens are much to dark and have a lens pattern that focuses the light from a point source. This severly limits the effectiveness when compared to the as purchased LED fixture. It is clear that I will have to find a way to install the lens that came with the LEDs to take advantage of the LEDs. My first thought was to cut the center out of the Airstream lens and insert the lens that came with the LED. The problem there will be the limited amount of material at the edge of the Airstream lens after cutting.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-28-2006, 08:39 AM   #46
higgy116's Avatar
Profile:  1972 29' Ambassador
Edgewater , Florida
LED Tail Light
I am trying to replace the tail lights on my 72 ambassador and have found it very hard to find a replacement for the 4" round. The entire light needs to be replaced because it has rusted beyond help So I have been looking at all my options and was wondering if anyone has used these led lights? http://www.florawrecker.com/cgi-bin/...y_Code=LEDSTOP I think I may be able to reuse the lamp housing if I do some work on them but I was wonderong if anyone has used these lights in the original housing?
Did that make any sense??
higgy116 is offline   Reply With Quote
Old 06-28-2006, 09:47 AM   #47
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
Originally Posted by outofcontrol
I'm wondering how these bare curcuit boards hold up to the elements?
Howie, is there a protective layer on the board? I don't know about the rest of the country, but we in the PNW have about 9 months of drizzle, and moisture will get in there, no matter what you do.
Those water-proof boat trailer lights are obviously water tight, but was that a function of the lens and housing?
And if they short out with rust, we'll just figure out how to protect them on the new set.
-K
The Blazer Boat Trailer Lights LEDs are set in clear Epoxy front and back. The case and lens are not that water proof. I haven't wet them down to see, but I think they are pretty safe from rust or corrosion.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-28-2006, 12:53 PM   #48
Commercial Vendor
Profile:  Corona , California
We have the correct LED tail lights for your year Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-28-2006, 01:58 PM   #49
HowieE's Avatar
Images: 11
LED tail light update
As I mentioned last week the original tail light lenses were too dark to be effective with the LED lights.
I took the original Airstream lenses and cut the centers out to accept the round lenses that came with the LEds. Once cut to size I glued the new lenses into the old and sealed the lens to the fixture with RTV. The complested fixtures have been mounted and the next project is to convert the backup light to a third tail/brake light and sequence the three lights.
I will most likely use Web's STS-1 generic ssequencer.
http://www.webelectricproducts.com/products.htm
Name:	Tail light lens.JPG
Old 07-01-2006, 11:12 PM   #50
Profile:  Marietta , Georgia
Send a message via MSN to 85/345
HowieE,
If what you tried doesn't work you might try making your own with this stuff http://www.alumilite.com/howto.cfm?ID=24. Not sure how expensive it is or how well it works. Keep us posted on your progress.
85/345 is offline   Reply With Quote
Old 07-13-2006, 04:22 PM   #51
HowieE's Avatar
Images: 11
Well I think the project is done. I have mounted a third tail/stop light in the center position and installed a sequencer. Now when I hit the brakes the lights sequence from center out and remain on as long as the brakes are on. When either directional is turned on the lights will sequence from center out each time the flasher closes.
Sorry I can’t give a picture of the sequence but at least you can see all 3 lights late.
Now when I turn on a directional those BMWs that attempt to pass before I come out may think twice. Doesn’t matter if I see a BMW behind me I start the pull out before I turn on the directional anyway.
Name:	3 tail lights.JPG
Old 07-21-2006, 01:36 AM   #52
Profile:  1992 34' Limited
Falls Church , Virginia
Looking in GREAT Howie!
Sorry! have been gone on family health issues for about a month so I admit to possibly missing a few LED somethings, or 3.....
Just to catch me up, Howie..... The lights you used, where from?? Part #? Supplier???
The install looks great! Details with photos?
Is there a part # for the sequencer you used, as I have the same light/ Lens fixture set up? Is there any special wiring required? Anything out of the ordinary????? Walk us thru it....
This looks like a possible solution for the LED adapation that many are thinking about..... in the early to mid nineties TT.... Update or die...
Any and all additonal info (with PHOTOS!!!!) will be appreciated by all!
Thanks again for your info. Post with answers!!!!!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 12-31-2008, 10:00 AM   #53
McPlaidpiper
Profile:  Colleyville , Texas
Hello. I have a 1982 28' diesel AS MH. I am also interested in converting to the LED tail/brake/turn lights. In this discussion the pop in bulb is discussed but only in the context of a 'straight' type replacement. I noticed Superbright now has 30LED turn/brake led conversions with a 45 degree angle which should address the directional light issue. Has anyone tried these type bulb replacement, or is it just better to use the flat board style? ANY
mcplaidpiper is offline   Reply With Quote
Old 12-31-2008, 10:29 AM   #54
HowieE's Avatar
Images: 11
Please do not attempt to use any Bulb Replacement type LEDs. All tail lights are designed with a given light source and a lens that is designed to maximize that source. Any change in the placement of the light source will reduce the effect of the lens. If you question my comment think of the work that goes into the construction of a lamp and lens assembly at a light house.
If you make a change due it with a complete assembly of light source and lens.
Old 01-26-2009, 07:35 PM   #55
outofcontrol's Avatar
Profile:  Portland , Oregon
HowieE,
Although you have a great point, I think with reasonable judgement, a guy could make LED replacement bulbs work. If you look at the lens and reflector of my rig, there's obviously not too much science and research that went into the design. The reflector, if you can call it that, is flat on the back and barley rounded on the sides. Comparing the fixture on my airstream to that of a lighthouse is, at the least, a stretch.
Some of the applications that I've seen used on Airstreams drastically improved the brightness, distribution, and focus of the LEDs.
I would agree that one could get into trouble by just replacing the bulbs without any sensibility to go along, but at the same time, a blanket warning against their use is a little too conservative. (for me)
I think someone else tried to use the 90 deg. bulbs only to find out that they ended up pointing the wrong way.
I'm still looking for a cheap alternative for interior lights. I haven't counted, but I must have 30-40 interior bulbs. I'm not going to spend $800 replacing them all. I'm sure there will be some cheap alternatives that come to the market soon enough.
-Kevin
1981 Airstream Excella 28' MoHo
outofcontrol is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 08:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 05:51 PM
replacement tail lights for 69 Airstream bgow 1969 Overlander 0 08-06-2002 11:03 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 02:58 PM
