Old 01-29-2011, 08:59 PM   #1
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
LED Lights on 87 345 rear tail/turn
I found great led lights to replace the old bulbs. Takes about 30 min for all four lights.
These are the lights I bought from Auto zone.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-29-2011, 09:05 PM   #2
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
1.Next remove the lens cover from new light
2. Remove the 2nd light that is connected that has the brown wire. Held on with two Phillips screws. ( save that little light for something else)
ID:	120433   Click image for larger version
Athens GA
Old 01-29-2011, 09:35 PM   #3
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
3. Next remove the old cans from the light housing.
4. Cut wires to old lights.
5. Connect new lights. A. White connects to white
B. Yellow connects to the green wire on the new lights
C. The white wire connects to the white wire.
ID:	120436   Click image for larger version
Athens GA
Old 01-29-2011, 09:46 PM   #4
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
After all is connected put new LED lights in leave out back up lights so you can reach behind to hold the back as you put lens back on. Only two screws will hold the LED light housing in when you screw back on the lens. I chose to order new lenses and I used all back up lenses to show up the LED lights better.
The only other thing I may do when I get the chance I will remove the back up light and just make all three stop/tail. I already have two backup lights on the lower part of the Moho.
ID:	120438   Click image for larger version
Athens GA
Old 01-29-2011, 09:49 PM   #5
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Nice job!
blmitch5 is offline   Reply With Quote
Old 01-29-2011, 09:55 PM   #6
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
This is the final results.
First picture is the before the second is the after and the third is the lighted one.
Hope this helps.
ID:	120442   Click image for larger version
Athens GA
Old 01-29-2011, 09:56 PM   #7
blmitch5's Avatar
Olathe , Kansas
I cant wait to see how the inside turned out! Very nice.
Old 01-29-2011, 09:56 PM   #8
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by blmitch5
Nice job!
Ha. Thanks. This was my first time starting a thread.
Athens GA
Old 01-29-2011, 09:58 PM   #9
blmitch5's Avatar
Olathe , Kansas
You will be a rivet master in no time!
Old 01-29-2011, 10:00 PM   #10
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Hope this helps.
Each light cost about $24. And I have 4 little leftover LED lights to use somewhere else on the Moho. Yea! They were the little ones that need to be removed to make new lights to fit in the housing.
Athens GA
Old 01-29-2011, 10:13 PM   #11
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Got my dinette cushions done. Next is the sofa next week. I think I like them. Lol. Before and after pics. Anything is better. Lol. He still needs to add the tufting. But the last pic is what I was going for. Just the cushion.
ID:	120446   Click image for larger version
Athens GA
Old 01-29-2011, 10:17 PM   #12
blmitch5's Avatar
Olathe , Kansas
Very nice! We will have a open house at the rally! Maybe a progressive cocktail party.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
Old 01-29-2011, 10:24 PM   #13
New Lenses from whom?
I see you ordered new lenses. Did you get these from Vintage Supply?
Also did the color come out alright using the backup lenses. They look like the old "Monarch" 4" lens.
Steve
Sav'h Steve is offline   Reply With Quote
Old 01-29-2011, 10:27 PM   #14
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Steve
I did get from vintage trailer. Think $7 each. They are the 4" Monarch. Yeah the color of the red LED? the sine through great. You can use the old if you want. I liked the look of the clear backup lens.
Athens GA
Upgrading to LED lights denali Lights - Interior & Exterior 17 02-20-2011 10:10 AM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 06:40 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 11:50 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 11:14 PM
Where do the roof A/Cs drain on 345 moeriv Classic Motorhomes 4 01-19-2011 09:20 AM
