Old 01-29-2011, 07:59 PM   #1
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
LED Lights on 87 345 rear tail/turn
I found great led lights to replace the old bulbs. Takes about 30 min for all four lights.
These are the lights I bought from Auto zone.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-29-2011, 08:05 PM   #2
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
1.Next remove the lens cover from new light
2. Remove the 2nd light that is connected that has the brown wire. Held on with two Phillips screws. ( save that little light for something else)
ID:	120433   Click image for larger version
Athens GA
Old 01-29-2011, 08:35 PM   #3
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
3. Next remove the old cans from the light housing.
4. Cut wires to old lights.
5. Connect new lights. A. White connects to white
B. Yellow connects to the green wire on the new lights
C. The white wire connects to the white wire.
ID:	120436   Click image for larger version
Athens GA
Old 01-29-2011, 08:46 PM   #4
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
After all is connected put new LED lights in leave out back up lights so you can reach behind to hold the back as you put lens back on. Only two screws will hold the LED light housing in when you screw back on the lens. I chose to order new lenses and I used all back up lenses to show up the LED lights better.
The only other thing I may do when I get the chance I will remove the back up light and just make all three stop/tail. I already have two backup lights on the lower part of the Moho.
ID:	120438   Click image for larger version
Athens GA
Old 01-29-2011, 08:49 PM   #5
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Nice job!
blmitch5 is offline   Reply With Quote
Old 01-29-2011, 08:55 PM   #6
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
This is the final results.
First picture is the before the second is the after and the third is the lighted one.
Hope this helps.
ID:	120442   Click image for larger version
Athens GA
Old 01-29-2011, 08:56 PM   #7
blmitch5's Avatar
Olathe , Kansas
I cant wait to see how the inside turned out! Very nice.
Old 01-29-2011, 08:56 PM   #8
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by blmitch5
Nice job!
Ha. Thanks. This was my first time starting a thread.
Athens GA
Old 01-29-2011, 08:58 PM   #9
blmitch5's Avatar
Olathe , Kansas
You will be a rivet master in no time!
Old 01-29-2011, 09:00 PM   #10
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Hope this helps.
Each light cost about $24. And I have 4 little leftover LED lights to use somewhere else on the Moho. Yea! They were the little ones that need to be removed to make new lights to fit in the housing.
Athens GA
Old 01-29-2011, 09:13 PM   #11
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Got my dinette cushions done. Next is the sofa next week. I think I like them. Lol. Before and after pics. Anything is better. Lol. He still needs to add the tufting. But the last pic is what I was going for. Just the cushion.
ID:	120446   Click image for larger version
Athens GA
Old 01-29-2011, 09:17 PM   #12
blmitch5's Avatar
Olathe , Kansas
Very nice! We will have a open house at the rally! Maybe a progressive cocktail party.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
Old 01-29-2011, 09:24 PM   #13
New Lenses from whom?
I see you ordered new lenses. Did you get these from Vintage Supply?
Also did the color come out alright using the backup lenses. They look like the old "Monarch" 4" lens.
Steve
Sav'h Steve is offline   Reply With Quote
Old 01-29-2011, 09:27 PM   #14
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Steve
I did get from vintage trailer. Think $7 each. They are the 4" Monarch. Yeah the color of the red LED? the sine through great. You can use the old if you want. I liked the look of the clear backup lens.
Athens GA
Old 02-25-2011, 11:35 PM   #15
audiv8q's Avatar
1986 34.5' Airstream 345
Longview , Washington
Send a message via MSN to audiv8q Send a message via Yahoo to audiv8q Send a message via Skype™ to audiv8q
So now you just need to install the blinker relay from a 1965 T-bird, or from a 1968 Cougar, where the blinker starts with the inside light, then first and second, then all 3, and back to the first...
How awesome would THAT look!
audiv8q is offline   Reply With Quote
Old 02-26-2011, 12:17 AM   #16
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
....On the subject of lights, has anyone ever replaced the front overhead cab clearance lights (not just the bulbs or lenses, but the entire fixture)???
Mine are not looking so great, and I'm not sure what they're made of, if they can be polished, or if they are available new.
Thanks for any info,
Charly
streamquest is offline   Reply With Quote
Old 02-27-2011, 06:36 PM   #17
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
That would be great. I saw your website with the tow dolly accident. I flat tow my jeep. Back to cougar, so you think I can do that? The new mustangs do that as well.
Athens GA
Old 02-27-2011, 07:05 PM   #18
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Charly
Yes I have. I replaced them with LED from walmart. $7 a light. Just remove the cover and then remove the two phillips screws. Then you can pull the wire from the old light and put a new connector on the new light to hook to the old wires. I also like to put a little valulken sealer where the screws go. Basically they are exact replacement from your old. I recommend the LED lights they use less power, much brighter and less maintenance .
Athens GA
Old 02-28-2011, 08:44 PM   #19
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
I used the Blazer brand when I replaced mine, but these should fit fine as well. Have used this company for many of my LED re-lighting projects. Great selection and great prices. superbrightleds.com
I would also use all Stainless screws when you do this. I replace even the ones holding the housings to the coach.
Here is a link to the running lights on their site.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 02-28-2011, 09:43 PM   #20
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Ones from walmart are Blazer brand.
Athens GA
Upgrading to LED lights denali Lights - Interior & Exterior 17 02-20-2011 09:10 AM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
Where do the roof A/Cs drain on 345 moeriv Classic Motorhomes 4 01-19-2011 08:20 AM
