Old 02-25-2011, 11:35 PM   #15
audiv8q's Avatar
1986 34.5' Airstream 345
Longview , Washington
Send a message via MSN to audiv8q Send a message via Yahoo to audiv8q Send a message via Skype™ to audiv8q
So now you just need to install the blinker relay from a 1965 T-bird, or from a 1968 Cougar, where the blinker starts with the inside light, then first and second, then all 3, and back to the first...
How awesome would THAT look!
audiv8q is offline   Reply With Quote
Old 02-26-2011, 12:17 AM   #16
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
....On the subject of lights, has anyone ever replaced the front overhead cab clearance lights (not just the bulbs or lenses, but the entire fixture)???
Mine are not looking so great, and I'm not sure what they're made of, if they can be polished, or if they are available new.
Thanks for any info,
Charly
streamquest is offline   Reply With Quote
Old 02-27-2011, 06:36 PM   #17
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
That would be great. I saw your website with the tow dolly accident. I flat tow my jeep. Back to cougar, so you think I can do that? The new mustangs do that as well.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 02-27-2011, 07:05 PM   #18
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Charly
Yes I have. I replaced them with LED from walmart. $7 a light. Just remove the cover and then remove the two phillips screws. Then you can pull the wire from the old light and put a new connector on the new light to hook to the old wires. I also like to put a little valulken sealer where the screws go. Basically they are exact replacement from your old. I recommend the LED lights they use less power, much brighter and less maintenance .
Athens GA
Old 02-28-2011, 08:44 PM   #19
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
I used the Blazer brand when I replaced mine, but these should fit fine as well. Have used this company for many of my LED re-lighting projects. Great selection and great prices. superbrightleds.com
I would also use all Stainless screws when you do this. I replace even the ones holding the housings to the coach.
Here is a link to the running lights on their site.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 02-28-2011, 09:43 PM   #20
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Ones from walmart are Blazer brand.
Athens GA
Upgrading to LED lights denali Lights - Interior & Exterior 17 02-20-2011 09:10 AM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
Where do the roof A/Cs drain on 345 moeriv Classic Motorhomes 4 01-19-2011 08:20 AM
