Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-26-2006, 06:20 PM   #1
klattu
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 854
LED Conversions
It started with the need to get a couple of floresent back working.
Priced a few replacement...$60 and up!
Just the ballast was going to be $30 each! dang....
Then stumbled onto some LEDs...hummmm
Well heres is the results for the price of one ballast, many lights are now LEDs.
Almost zero amps... .03 or less
These will be perfect for reducing battery drain.
And should still be working into my next life.
The way it was...
Gutted light fixture,
Just peal and stick in place...
4 sections compared to flor...
Went all out and run 6 sections...
Some fun for Halloween...black light bulbs in the still working flor...
Back bedroom with only 2 sections...
Spots have LEDs, Lamp still has bulbs...
Now onto the tail lights...
A dab of silicone on each corner...
Set in center....
Drying for 1 hour...
Running lights...
Brake lights on....
LEDs off, back up lenses used in all three places...
Front turns converted to clear lens with amber LEDs
klattu is offline   Reply With Quote
Old 10-26-2006, 06:24 PM   #2
klattu
Liberator
klattu's Avatar
Images: 854
Left these out...
6 sections...
Old 10-26-2006, 06:37 PM   #3
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Nice conversion
klattu,
You pulled off a nice conversion. Are the linear LED strips 12 VDC? At 30 milliamp per LED, your battery charge life may exceed 100 hours running several fixtures.
John
TIMEMACHINE is offline   Reply With Quote
Old 10-26-2006, 06:44 PM   #4
bill benton
bill benton's Avatar
Profile:  1991 34' Excella
Mansfield , Texas
Where do you find those type of leds
bill benton is offline   Reply With Quote
Old 10-26-2006, 07:38 PM   #5
Auretrvr
Auretrvr's Avatar
Profile:  Iowa City , Iowa
Source for LED spots??
I have been wanting to get LED spots, but couldn't figure out where or what to ask for. Please share!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 10-26-2006, 08:08 PM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Here is a place:
http://superbriteleds.com/
Silvertwinkie is online now   Reply With Quote
Old 10-26-2006, 08:14 PM   #7
klattu
Liberator
klattu's Avatar
Images: 854
Heres the light bars...
http://www.superbrightleds.com/specs/LB3.htm
They have lots of cool stuff.
Many more ways to have fun with LEDs.
Be sure to check out the auto section too.
You can get the Electronic flashers at Advance for about $6.
They flash 80 times a minute, reguardless of amp pull.
That meens no differance when pulling a toad, etc.
Old 10-26-2006, 08:16 PM   #8
klattu
Liberator
klattu's Avatar
Images: 854
In tail light photos...light is really very RED,
It looks kinda yellow in photo.
Old 10-26-2006, 08:30 PM   #9
klattu
Liberator
klattu's Avatar
Images: 854
These are the spots.
1156 is the one for spots.
http://www.superbrightleds.com/specs/1157-x24.htm
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Scroll way down, and be sure to pick correct color.
I used the 24 LEDs, also tried the 30, 30 was to wide to fit.
Notice that 6 LEDs are point sideways, so on the 24, only 18 point straight out.
Old 10-29-2006, 11:32 AM   #10
klattu
Liberator
klattu's Avatar
Images: 854
Liberator gets a 3rd Brake Light added to the Spare Tire Cover...
Fit perfectly inside the star of the 8th Air Force.
The wings and star are reflective at night.
Old 10-29-2006, 04:42 PM   #11
klattu
Liberator
klattu's Avatar
Images: 854
This is what the "Liberator" looks like at night...
Old 10-30-2006, 08:09 AM   #12
klattu
Liberator
klattu's Avatar
Images: 854
OK...so many have asked for part numbers...
Tail/Stop lights with a Red lens use
#1157
LED #1157-PCB-W36 White LED Lamp
These are the square lights on a board
Front Turn Signal with Amber lens
#1157 Amber
LED #1157-W24 White LED bulb
Inside spot lights
LED #1156-W24 White LED bulb
Now...
If you use Clear lenses,
Tail/Stop
LED #1157-PCB-R36 Red LED lamp
Front Turn
LED #1157-A24 Amber LED bulb
Old 11-10-2006, 12:02 PM   #13
outofcontrol
outofcontrol's Avatar
Profile:  Portland , Oregon
Klattu,
Now all we have to do is find LED headlights!
Great write-up, now I have to upgrade all my interior lights (I already did everything outside)
-Kevin
1981 Airstream Excella 28' MoHo
outofcontrol is offline   Reply With Quote
Old 11-10-2006, 05:04 PM   #14
klattu
Liberator
klattu's Avatar
Images: 854
For the spots...
Be sure to get the 24,
Not the 19 or 12, they are way to dim.
I have not tried the 3 watt, they look interesting, but dang $24 !
LED Lighting system Buttercup Electrical - Systems, Generators, Batteries & Solar 23 01-07-2006 05:00 PM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 06:00 AM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
