08-17-2016, 08:53 AM
1979 28' Airstream Excella 28
Albuquerque
Kyote's '81 Excella 280 TD
Hello everyone,
Picked this old girl up more or less on impulse. It was advertised locally for well below what they seem to be going for in CA. So, I am right at the point of diving in for big $$$$ like tires, so consider this a soft advertisement if someone wants to plop down $20k or so cash, I would strongly consider it.
Odometer says 23k, most likely 123k judging from wear and tear on interior. I drove it across town to my house, up to 45mph. Tires and lack of brake pressure kept me from driving faster.
I've been lurking on this thread for a few weeks, absorbing information. I don't want to be 'that guy' that asks a bunch questions without researching myself, but please comment or give links to anything
done so far:
fuel tank drained, easy to do, almost too easy? any thoughts on securing the nut so the fuel can't be stolen? now have to find a place to take 20+ gallons of 10 year old bluish diesel. put in 5 gallons with 1/3 can Seafoam, less smoke and will rev up to 2k RPMs now without stuttering. Oil pressure and turbo appear good.
transmission seal was leaking, so seal and filter replaced (easy except for a single bolt under the frame - 1/16 turn, flip wrench, repeat 40 or so times). seemed insanely cheap at NAPA for $12! filter looked original. fine dust in pan and filter, but no large metal bits. torqued bolts @ 11pds in cross pattern, replaced fluid and no leaks!
AC shrouds cleaned and panted with primer, metallic paint, clear coat
AC motors replaced, AC runs, but one is a bit colder than the other
Onan genset 6.5 with 250 hours: plugs replaced, area cleaned; regulator replaced bc was leaking. to do: oil, filter. other maintenance listed recommended like points? necessary, or if it ain't broke don't fix it? runs well and takes the load of both AC units
to do (short term)
engine oil and filter
converter isn't charging batteries when plugged in to house power
heater isn't coming on
water pump leaks if switch left on, hoses coming are some sort of garden hose grade that need replacing
water heater leaks. haven't gotten in yet to inspect. easier to bypass with an inline on demand and leave old one in place? pull and replace? or would tank be repairable?
to do (long term)
tires, and bolts in front wheel only have 5 bolts, not 10 (?!)
pull out carpet, seems obvious as everyone I have seen advertised has solid flooring of some type
inspection by a mechanic that knows what to do with this Isuzu motor
brake inspection, fluid change
coolant test and probably replace
has an over/under transmission thingy installed on dash and behind transmission. not sure how it works, but my understanding is it effectively gives 6 gears instead of 3?
dash AC and cruise aren't working, but did in recent history according to previous owner
seals around windows
replace vent and motor
Kyote
08-18-2016, 05:58 AM
Richmond
, Kentucky
Kyote, congrats on your new motorhome!
Originally Posted by kyote
Hello everyone,
Hopefully you're not having buyers remorse already
done so far:
....Onan genset 6.5 with 250 hours: plugs replaced, area cleaned; regulator replaced bc was leaking. to do: oil, filter. other maintenance listed recommended like points? necessary, or if it ain't broke don't fix it? runs well and takes the load of both AC units
It's great that the generator handles both. I'm assuming the generator is propane powered and if so would explain why it is still running good without you having to touch it.
to do (short term)
You should figure on replacing the power converter. I know of few if any rigs that still have the original univolt. Every motorhome I've owned I've had to replace the converter.
Requires DC voltage from the coach batteries. This could be related to your converter problem.
Don't bother trying to repair. A decent propane/120vac water heater combo costs around $450 or so and is well worth installing.
to do (long term)
5 lug is standard at the front with 10 lugs at the rear.
Sounds like a Gear Vendors overdrive. That's a nice upgrade! Others will be able to explain how to use it.
1975 24' Argosy Motor Home
08-18-2016, 08:08 AM
Albuquerque
Brad,
Thanks for the input. All your points make sense.
No, no buyers remorse. I knew I was buying well below what these seem to go for. The continued financial investments will tie me to it, but also the more I fiddle, the more emotionally invested we will be.
I wasn't looking for an AS, or even a MH to begin with. But, the AS seems to be a solid platform to invest time and money in.
I will continue to post what I do as a record for myself, and I welcome any and all input.
thanks in advance
08-18-2016, 10:46 AM
Richmond
, Kentucky
Sometimes the best deals just fall into your lap and it's a no brainer that you have to go for it
Definitely post pictures and keep this thread updated with your progress.
08-25-2016, 06:17 PM
1994 36' Classic 36 Diesel
Colorado Springs
Congrats and welcome!
Have you considered a locking gas cap?
Circular locking door
More options
1994 36' Classic Diesel Pusher
08-26-2016, 07:48 AM
Albuquerque
I have, and I will be getting one. I was referring to 1/4 square plug underneath the coach to drain the diesel tank. With enough containment, one could steal the contents quickly and easily. Doesn't look to be easily securable though...
Speaking of which, I replaced the main door lock to the coach. The local AS dealer/repair shop had two from 80s Excella trailers. So, I though what are the chances the original key will fit either one? It fit both!! Society was a different place in the early 80s. I plan installing a shackle lock on the door as well. Seems like Excella trailers had deadbolts, but not the MHs?
I was able to dispose of the old, blue diesel at a hazardous waste place locally in a few trips. Oil change next, and I'll be posting more photos soon. Been reading through the threads and stickies here, and learning a lot. Is there a thread for the Isuzu TD motor and a scan of the manual? Can't seem to find one.
09-04-2016, 04:34 PM
Albuquerque
The engine says that it is an Isuzu 6BD1H?, but I can only find manuals for 6BD1? Will this work, anyone know a good source for a shop manual? A few on here say they have a 6BD1T.
I drained the radiator very slowly, over a couple of days because I am only getting about a drip per second. I then put in Prestone cleaner and water. Again, super slow draining. So, I kept the engine idling to keep the coolant warmer and this seemed to help. I took the coolant cap off to keep it topped off, but nothing came gushing out. So, is my water pump working? The top of the radiator is quite hot, the bottom is cool. A few have referenced a lube point on the water pump; is this worth trying to get to?
Also, the dash fans aren't working. The fuse box (really, all this space and has to there?!) has a 25amp fuse where it should be for AC/heater. Is there a separate fuse for the fan?
thanks
09-04-2016, 09:54 PM
1982 28' Airstream 280
Port Angeles
These guys are the gurus for the Isuzu.
Hamilton Engine Sales
5540 N.E. Columbia Blvd.
Portland, Oregon 97218 Craig (503) 280-1353
Is yours a turbo? If so it was built as normally aspirated and Airstream added an aftermarket low pressure BAE turbo. It has a maximum boost of about 10 psi. The engine isn't designed to handle 30 psi of boost. Isuzu did come up with a turbo engine about 1967.
If you really want to get the coolant out pull the lower radiator hose. With a light and a dental mirror or a bore scope you can see how much crud is in the bottom of the radiator.
To reach the grease fitting on the water remove the wood cover and carpet from the doghouse and the radio tape deck unit.. Forward of the doghouse hinge is a plate about 8" by the with of the cover, remove the 10 or 12 1/4" bolts and the entire doghouse cover will come off. Standing on your head while straddling the engine you will find the grease fitting. While you are there with a little luck you can reach the fuse block. Are we having fun yet?
I have manuals for your coach in pdf. Send me PM with your email and I'll send them to you.
Cheers, Dan
________________________________________
"Socialist governments traditionally do make a financial mess. They always run out of other people's money. It's quite a characteristic of them."
~ Margaret Thatcher ~
09-05-2016, 04:08 AM
1982 31' Airstream 310
champaign
Take a look at those numbers on your motor one more time kyote. It should be a 6bd1A. Like Dan says, anything you need for that motor can be purchased through Hamilton Engine. They are absolutely great to work with. You NEED to get your engines serial number to order any parts. The serial number is stamped on the block, drivers side, just above the oil pan I believe. The numbers are pretty big. Bring a wire brush and some carb cleaner under there when you go looking for it. Ive ordered parts through Hamilton and had them in my hands the very next day.......and Im in cantral Illinois. Your engine is old enough that it wont be on their computer, they will need to look it up in the book.
+1 on pulling off the lower radiator hose to flush, your drain valve is probably old and clogged up.
Mike
09-05-2016, 07:55 AM
Albuquerque
It is a Turbo. I think I read in the sticky that the 'H' is a designation for California emissions? I'll take a photo when I get a new phone. I took a photo of the seal on the top of the engine to post here, then I washed the phone in my shorts. This is why I am only allowed to buy $100 phones now
I was avoiding pulling off the lower hose cuz it may not come off without breaking. But I think Mayco started a thread I came across with a replacement option.
thanks for the info on the shop and how to get the cage off
09-06-2016, 11:54 AM
Albuquerque
Since the radiator cleaner is coming out so slowly, I decided to leave it in for a while to do it's job. I may even need to take the old girl slowly around the block on 10 year old tires to get up to temperature. But, I know I will probably need to pull the lower hose off to get it all out and completely flush the bottom.
Photos:
the first is the engine tag that shows 66BD1H and it is an 81, but the coach is 79
the second is three hoses that don't go anywhere. The hose in the left center runs straight off, so I assume it is an overflow for the oil. The thicker at the bottom left comes from the top left of the engine, but I have no idea what it does or if it should be attached to something. The third hose with shiney black connector looks to be for air. It comes off of a small cylinder on the bottom right of the engine . It appears to go to a T intersection just over where the transmission starts. I think I read on these forums somewhere that the dash fans run off of this system? Where do I find hose like this to repair it?
third is an oil leak on the upper passenger side of the engine, the oil pump? The cylinder spins while idling. The shiney nut just to the left of the cylinder seems to be where the oil leak is coming from. It isn't enough to reach the ground as a drip, but it does create a lot of smoke and collects grime on this side of the engine. Do I find a super-skinny wrench to tighten this nut or do I have an issue with where the cylinder connects?
thanks for any help for a diesel noob. I am slowly learning what does what on this engine.
09-17-2016, 07:21 PM
Albuquerque
thanks to Mayco for easy explanation of how to use the little pump clear the fuel line of air
http://www.airforums.com/forums/f159...-112252-3.html
I had drained the fuel tank, and guessed that I had air in the line. But, I had had it idling in the driveway to cycle coolant from a coolant change on and off for a couple of hours over several days, no problem.
So, I took it for a slow spin (old tires) around the block. And sure enough I give it a bit of petrol to get up the ramp to clear the curb... and it is dead in the water crossways on the street! Luckily my street isnt busy. Pumped a 100xs or so until it was hard to pump and she fired right up!
Next: fuel filters change. The turbo gauge is moving, but not much. So, hopefully the filter change will help with this and the billows of blue smoke that continue despite draining the tank
The photo is of a universal overflow tank from Autozone that fits. I tired to find the OE one from Napa, but no luck.
09-17-2016, 07:27 PM
champaign
Good deal!
10-06-2016, 08:12 AM
champaign
Kyote, Ive read good reviews on Progressive Dynamic products. Unless you plan on adding a great deal of electronics to your rig, or some solar power system, I personally dont think you need anything too fancy when youre selecting your new converter. Make sure that whatever you choose is at least a 3 stage converter to protect your batteries from frying due to overcharging. The PD converter in your link looks like it includes a new 12v distribution panel also. Many folks like to upgrade that panel so you can use modern blade fuses rather than the old glass type fuses.
I installed a PowerMax 45 in my 310 and its done a fine job so far, been in now for two years. This type of a converter is pretty much a plug n play install.
https://www.amazon.com/PowerMax-PM-4.../dp/B004YJ3WEO
Mike.
10-06-2016, 09:01 AM
Albuquerque
I do want to add about 400w solar, like this
https://www.amazon.com/WindyNation-4...=rv+solar+400w
So, it sounds like the PD4000 converter would be a good fit
I'd much rather tackle just about anything in the coach other than electric. but, there are some videos that make it look pretty simple
thanks, Mayco
10-06-2016, 02:15 PM
Richmond
, Kentucky
The PD4000 should work. You can buy a new one for around $175 so if you want a new one instead of used it wouldn't cost that much more.
Personally I like the Progressive Dynamic products.
10-13-2016, 09:29 PM
Colorado Springs
Kyote,
If you're going solar, beyond 100w for battery upkeep, I have a few recommendations.
1. Get an MPPT charger to maximize the use of your solar cells.
2. Research, and build your system on your own, much cheaper than bundles, and better quality parts.
3. Recommend using the AM Solar kit for affixing your panels on your rounded rood, yes they are $80/ solar panel, but they account for our rounded roof.
4. Consider upgrading your coach's power cell to maximize storage of all that energy. Many more options than just car batteries or deep cycle marine/rv batteries.
5. Consider adding an inverter for 120VAC on the go. If getting an inverter, consider install locations within 3ft of the coach batteries.
10-17-2016, 12:53 PM
Albuquerque
Finally got around to changing the fuel filters with help from Mayco's explanation in the Turbo working thread.
What else should I be looking at now that I have cover off? I think I saw that a lube point for the water pump was mentioned in a thread. The top radiator hose looks ragged, but doesn't seem to leak. The belts look surprisingly good, not cracked or brown and dry.
I'm posting a photo of the engine, FWIW
Also, a photo of the Racor filter I replaced. It is the same beige plastic as the twist handle. Any chance it is OE? I ask cuz I really don't know if it the coach has 23k or 123k miles. The tranny filter looked to be OE.
10-17-2016, 01:22 PM
champaign
I would inspect the fiber hose that connects your turbo to the air filter. There is a section about 12" long that connects your hard pipe from the air filter. Its buried in there on the turbo side of the motor. It is a BEAR to change (for me) but you want to make sure there are no cracks or holes in it or you risk ruining your turbo. I ended up using a silicone tube cut to length by NAPA. Just bring in your old hose or measure your ends.
There is a grease zerk on the top if your water pump. Some folks get to it from the wheel well I think, I was able to lay on top of the motor to get at it. Very tight space. I used a pneumatic grease gun with a rigid feed tube and it worked real well. Luckily, once youre sure youve greased it well, it wont need it again for quite some time
